Old 10th February 2006, 18:07   #1
Sankar's Avatar
Thanked: 4,655 Times
Default Smoked lens taillamps.
Today i've seen a red swift with smoked lens tail lamps. Some cars also come with smoked lens headlamps.
I want to know how to get that smoked lens effect with the tail lamps. Are the stock lens modded or are such lenses available off the shelf in the market?
Old 10th February 2006, 18:40   #2
Jaggu's Avatar
Thanked: 8,693 Times
as far as i know those are OE, some stick sun control over the lens to get the effect lol
Old 10th February 2006, 19:13   #3
Sankar's Avatar
Ok. I got the answer here it is...
http://www.eautoworks.com/html/ast-A...over~Paint.htm
Now i would like to know if these are available in India?
Interesting thing is you can even paint the bulbs but the colour of light remains original. Comes as both temporary and permanent paints. They say the light intensity won't get affected... if that's the case smoked headlamps would look cool
Old 10th February 2006, 19:16   #4
adit1329's Avatar
No actually even I have seen the same kind and it is not sunfilm.....
yes, i have seen a few with sunfilm too, but quite a few lens have smoked glass...
adit1329 is offline   Reply With Quote
Old 10th February 2006, 20:08   #5
Sankar's Avatar
Its paint. It's not sunfilm. Check out that link i've posted.
I'm thinkin of getting those.
Old 27th December 2009, 23:58   #6
djlukan's Avatar
Hey
As far as I've noticed there is alot of confusion when it come so smoked lamps.
I've listed below the types of headlights that look smoked:
1. Aftermarket(or custom made) headlights which have a black plastic inlay instead of the regular silver ones. They usually have projectors(with angel-eyes/halos) with the rest of the area black instead of the usual silver. Many people consider them as smoked which is not true.
2. Tinting is also an option for smoking but a special "SMOKED TINT' is available(I don't know if it's available in India yet) which can be put directly on the lens. This is a tedious job as most headlamps have slight curves which cause the tint to wrinkle. The best way to do this is by using a heatgun. Some people also use the regular tints instead of the "smoked tints".
3. The most widely used method is spray painting. The paint used for smoking is not usual but a different translucent type of a paint ('VHT Nightshades' being a major brand). The headlights are removed. The lenses are sand papered and sprayed with multiple layers of the paint depending on the amount of transparency you desire. VHT Nightshade - Visual/Body Modifications
djlukan is offline   Reply With Quote
Mesh grills and smoked out taillamps on my Punto vigneshram Modifications & Accessories 36 18th October 2010 10:38
Smoked Headlamps yayaati Modifications & Accessories 2 5th May 2008 11:01
Smoked headlamps rishibravo Modifications & Accessories 2 14th August 2007 12:28
i was smoked by nitroxx's city cooldude585 Shifting gears 10 7th June 2005 23:00
