Old 8th February 2012, 15:28   #106
sapl's Avatar
Thanked: 188 Times
Default Re: Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2
I have been reading a large number of posts regarding diesel tuing and thought I would put in my 2 cents too.
First and foremost, Diesel tuning has to be done with extreme care. The simplest approach is to increase fuelling (most commonly by rail pressure or by injector timing pulse extension). With more and more engines going the multijet way, rail pressure is becoming the most popular method.
The key question is how intelligently and adaptively can rail pressure be varied.
Most tuning boxes intercept the rail pressure signal going to the ecu and alter the signal so that the ecu increases the rail pressure above normal. (Of course you have the simple resistor trick also achieving the same result, albeit in a much cruder fashion !)
Since the devices are not connected to any other signal, they cannot adapt to other parameters such as boost pressure, throttle position, rpm etc. It is necessary to monitor these if a really intelligent tune is to be done. In extreme tunes, the tuning box should even monitor EGTs.
For example, at low rpms and low load, increasing the fuel by the same amount will only result in smoke and high EGTs. Similarly, if fuel pressure is increased indiscriminately at higher rpms and load, engine upper cylnder temperatures will shoot up and can lead to catastrophic damage to pistons and turbochargers. I have seen some mutilated internals of turbochargers as a result of such tuning efforts.
The right method is to increase rail pressure only up to a point if boost pressures are not increased.
Advanced units on the market can do boost control also. Boost control can be done a in a number of ways. On cars with VGT, an intelligent tuning box can easily control boost and correspondingly increase fuelling. In my experience, good results have been achieved with such an approach. Even on cars without VGTs, there are methods of doing boost control.
On such units, it is even possible to give acceleration compensation when the throttle is floored so that the driving experience is good.
sapl is offline   (6) Thanks Reply With Quote
Old 9th February 2012, 15:15   #107
ssh1979's Avatar
Thanked: 106 Times
Thanks for the write-up. Can you name any such boxes available in India or easily obtainable from here?
Originally Posted by Digital Vampire View Post
I have my own doubts on the "Cosworth" part or heritage. It's thought provoking that Cosworth offers remapping ONLY in INDIA. Go to any of their world sites and you wont see Remapping services mentioned anywhere...Not even in Europe which is the mecca of remapping scene!
I have posted a bit more at http://www.team-bhp.com/forum/modifi...ml#post2653627 (Swift VDi Remapped)
Food for thought?
Certainly food for thought; I find listing India as a separate region in itself "suspicious", for lack of a better word.
ssh1979 is offline   Reply With Quote
Old 25th February 2012, 02:23   #108
Endeavour333's Avatar
Thanked: 358 Times
Shyam just get a spider box. It blows my mind every time. Also what's the deal with you wanting 32" tyres?
Endeavour333 is offline   Reply With Quote
Old 25th February 2012, 02:35   #109
govigov's Avatar
Thanked: 431 Times
Any suggestions for such a box? Thank you
govigov is offline   Reply With Quote
Old 25th February 2012, 09:58   #110
amit_mechengg's Avatar
Thanked: 1,538 Times
The best tuning box i can see which does all the above is the TMC tuning box.
amit_mechengg is offline   (2) Thanks Reply With Quote
Old 25th February 2012, 10:47   #111
jaysmokesleaves's Avatar
Thanked: 1,159 Times
What does TMC stand for?
Who manufactures this and is it available in INdia?
jaysmokesleaves is offline   Reply With Quote
Old 25th February 2012, 12:10   #112
govigov's Avatar
Thanked: 431 Times
TMC Motorsport - Car Products
cool, they have most of the cars listed, costing about 320 GBP including shipping.
govigov is offline   (1) Thanks Reply With Quote
Old 27th February 2012, 05:20   #113
govigov's Avatar
Thanked: 431 Times
I have been doing some research. The TMC is costly at about 320 GBP.
Pete's has local support.
Any reviews on unichip?
Old 27th February 2012, 05:50   #114
Thanked: 23 Times
Smile
who is making oem manufacuring for german company
these boxes are called multichannel tuning boxes
with 2 or up to 5 connection in the engine for example
a mercedes c200 cg1 boxes have 5 connector including 1 for gear box also
since gear box limits engine for more power.
narry
doest matter what is made in china matter who makes it
have a look for audi 3.0tdi engine
Note from the Team-BHP Support Team: Please use the "edit" button if posting within 30 minutes of the first post, instead of creating another back-to-back post. Also use "Multi Quote" option for quoting Multiple posts.
Avoid quoting an entire large post. It inconveniences our small screen & mobile readers.
Take time to type your post. There are way too many punctuations and wrong spellings.
If you want your signature to feature in every post then do that in your profile page.
narry is offline   Reply With Quote
Old 27th February 2012, 13:41   #115
sapl's Avatar
Thanked: 188 Times
We generally use the following inputs for common rail engines when tuning with the Unichip:
1. Crank Position sensor
2. Boost pressure sensor
3. Throttle position sensor
4. Rail pressure sensor
However, this varies from car to car.
sapl is offline   Reply With Quote
Old 5th April 2012, 17:45   #116
Awaiting Email Confirmation
Many thanks for sharing the information on Unichip: -
with all the 4 sensors connected as compared to one only to the ECU on the after market Tuning Boxes, how much additional performance is enhanced from stock to tuned and also in comparison to the otherwise available tuning boxes in the market today.
alphamike is offline   Reply With Quote
Old 6th April 2012, 12:09   #117
Thanked: 358 Times
Thanks for this info. I also believe that Unichip is healthier and better for your car now. You've got me looking into it too! Any idea what the price range is? Tried contacting the Bangalore dealer but no response.
Old 10th May 2012, 14:04   #118
sapl's Avatar
Thanked: 188 Times
I am very sorry for the late response - have been travelling a bit.
When you do a scientific tuning with so many inputs taken into account, it is not just pure performance that you get - the main plus is the extremely smooth driving experience, the safety of the engine, the lack of smoke etc.
Of course, the performance is also enhanced. I am attaching a couple of dyno graphs to show the results - one on the Punto 90 and another on the Tata Safari Dicor.
We are also able to add features like giving acceleration enhancement - when the driver floors the throttle, we can give a transient enrichment of fuel which will give the extra punch on sudden acceleration.
Thanks for the comment. I am sending you a pm with the pricing. We are in the process of strengthening our Bangalore presence.
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2-punto-90-power.jpeg
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2-tata-safari-dicor-pwr.jpeg
sapl is offline   (3) Thanks Reply With Quote
Old 25th July 2012, 13:10   #119
artofzen's Avatar
Thanked: 54 Times
Gents,
I drive a Laura 1.9PD and recently bought a Cruze Automatic in April '12. A fine car except that the lag is killing the fun of overtaking on long drives, which is one of the key reasons we buy powerful cars. I am not interested in top end since I dont generally go beyond 130-140 , that too when overtaking only.
I searched the forum, but havent come across a thread that discussed resolving Cruze Auto's lag issue. Now I am thinking of remapping the car from Petes/Red Rooster/ any other .
Laura is 1.9PD Manual , Petes tuned as in Custom Code Stage 1 Remapped. I am very happy with the result and service from Petes and boy one of the reasons the cruze is not a favourite now is because we end up comparing it with the Laura.
My confusion is ,
1.Will remapping resolve this issue?
2.Which is the best remap available for Cruze AT?
3.Chevrolet Dealer claims they have a remap now. I dont know any details about that.
Your advise will be highly appreciated.
artofzen is offline   Reply With Quote
Old 24th January 2013, 17:41   #120
jkdas's Avatar
Thanked: 1,389 Times
Why wasnt the Safari given another run to see which is the best for it? I understand that the tuned version make approximately 160bhp; was it set to the same?
And would you have the info how the vehicle is now and how much it has run till date?
Product Review: Pete's Digital Diesel Tuning Box Rtech Modifications & Accessories 239 4th March 2016 13:38
Swift with Pete's Digital Diesel Tuning Box. EDIT : Green Filter added BUSA Modifications & Accessories 323 23rd August 2013 08:57
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
pete's tuning box for my diesel car karanbajaj Modifications & Accessories 2 13th April 2006 17:15
Pete's tuning box tsreekaranrao Modifications & Accessories 3 11th February 2006 23:37
