Old 8th November 2013, 22:36   #16
srinih75's Avatar
Thanked: 67 Times
Default re: Convert a manual transmission car to Automatic?
I see this is an old thread over an year old, but thought will share my view. I had attempted to put a product call "Auto Clutch". It was offered at a place near Shanthi Nagar bus stand. The cost was approx INR 13k with installation. I have test driven their car Ford Ikon petrol. It was pretty nifty. The feature had some kind of sensor or something, it did a half clutch in a gradient. I was having a ligament tear on my left ankle and so considered fitting it. But later bought my wife an i10 Auto and ditched the idea of putting this product to my Indigo Marina.
The only thing one need to watch out is accidental gear shifts at high speeds. Unlike an AT where there are mechanisms to prevent moving the gear to reverse while in forward motion, this product doesn't check all that. It can fall into reverse and destroy your tranny and more over cause a serious wreck and injury.
In all, it was a good product. I am not giving the guy's number as I am not sure if that number still works and he still sells the product.
Here is the link to a set of posts on this: http://www.team-bhp.com/forum/techni...-review-2.html (Autoclutch Review)
srinih75 is offline   Reply With Quote
Old 7th July 2014, 21:08   #17
autotranny's Avatar
Thanked: 217 Times
Default The practicality of installing an Automated Manual transmission
I have seen a separate thread discussing the advantages and disadvantages of the AMT (Automated Manual Transmission) but it does not dwell into the practicality of installing one in the car of your choice.
For the uninitiated here is a detailed description on the product -
Automated Manual Transmission (AMT, also called Freechoice) from Magneti Marelli is a electro-hydraulic mechanism for automating manual transmission which derives from Formula 1. It combines comfort of use with a reduction in consumption, and can be applied to any transmission, with production costs that are consequently lower compared to traditional automatic transmissions.
AMT is based on an electronic control unit and a hydraulic system that supervise the use of the clutch and the gear shifting, allowing the driver to change gear without using the clutch, either sequentially or fully automatically.
The device from Magneti Marelli operates on the manual transmission of a car in the same way as the driver would: it opens and closes the clutch, engages and disengages the gears and, when necessary, it also controls the choice of transmission (automatic or sequential mode for changing gear). These three control movements are ensured by three specific hydraulic actuators, controlled by hydraulic electro-valves.
All the components in the hydraulic unit are gathered together in a single kit. It is delivered to the car manufacturer sealed and ready to be installed in the gearbox. Once assembled in the gearbox, the hydraulic kit mechanically interfaces with the gear drive shaft.
The heart and intelligence of the gear control system is the TCU (Transmission Control Unit). Taking into account the driver’s requirements and the operating conditions of the vehicle, it manages the gear changes by controlling the clutch, the gears and the engine.
Thanks to the electronic optimization of the gear change and the coupling with the engine control means the AMT is able to ensure less consumption than a car with manual transmission: lower consumption also means lower emissions, especially of CO2. In some of the best applications of the AMT on mass-production automobiles, a 5% reduction in fuel consumption was recorded compared to the automatic transmission version of the same automobiles, as well as a reduction in emissions equal to 5 g/km of CO2.
The latest generation of AMT is known as “mechatronic”, as for the first time, it combines the electronic control part and the hydraulic actuation part of the transmission in a single kit. This allows considerable improvements to performance, both in terms of speed and comfort when changing gear. This is the latest step in the evolution of a product which was first introduced to the car market with the Ferrari 355 F1 in July 1997. The product is still undergoing “sharp” growth in performance.
So now to the most important question. Can this be retrofitted ?
autotranny is offline   (1) Thanks Reply With Quote
Old 20th January 2015, 14:37   #18
Thanked: 58 Times
Default Re: Convert a manual transmission car to Automatic?
With the Magneti Marelli AMT available as a proven technology now, are there any folks offering it as a retro-fitment on a conventional vehicle that I own ?
LonelyPlanet is offline   Reply With Quote
Old 29th July 2017, 00:28   #19
Thanked: 29 Times
Was just wondering if a manual xuv can be converted to an automatic transmission if aisin transmission is procured. Would be a good project.
Any ideas where the accident vehicles that get totalled end up? Curious if parts do end up for sale.
sk7671 is offline   Reply With Quote
Old 16th August 2017, 19:10   #20
Thanked: 17 Times
Converting an Auto to Manual will not only require the transmission, but also many other parts including the ECU.Since the XUV has an automatic variant , I believe it will be possible , however will require a lot of work which comes with a cost.
Considering the cost of the parts required , cost of the work and the perfection of the work , I personally suggest you to get yourself a Automatic XUV 500 as the factory fit will be more reliable and easy to maintain.
JozfGT is offline   (1) Thanks Reply With Quote
Automatic Transmission v/s Manual venkatrx Technical Stuff 331 19th February 2017 18:07
Mercedes Benz 300D (W123 series): Manual Transmission to Automatic Transmission. wartikars Post-War 5 3rd January 2014 12:39
query - Maruti Esteem automatic to manual transmission conversion kailashnj Technical Stuff 15 2nd March 2010 22:41
Convert Innova Manual into Automatic? Mumbaiya Modifications & Accessories 23 2nd March 2009 16:02
fuel efficiency b/w Automatic Vs Manual transmission cars. muni The Indian Car Scene 14 8th October 2006 21:56
