Old 2nd March 2006, 13:35   #16
nitrous's Avatar
Thanked: 285 Times
hi,
yes..i got the same in my car...the AutoGauge 3.75 incher has a shiftlight....
But, its not that separate one. ITs just a tiny LED which acts as a shift-light.
Can the 2 way tapes withstand the weight of the 5" tacho?? I personally do not want to drill on the dashboard to fix the tacho.
Even i didn't want holes in my dash.But, no way a double-sticker is gonna hold that guage. If u want 5" tacho, be prepared for just 2 holes.
Old 2nd March 2006, 15:06   #17
CaliforniaKnight's Avatar
Thanked: 46 Times
Even i didn't want holes in my dash.But, no way a double-sticker is gonna hold that guage. If u want 5" tacho, be prepared for just 2 holes.[/quote]
uuufff..thats gonna hurt. BTW I hope the process of setting the RPM to the tach is an easy one. I will be installing it this saturday...
CaliforniaKnight is offline   Reply With Quote
Old 3rd March 2006, 11:07   #18
rareone's Avatar
Thanked: 11 Times
Question Help Needed for Santro
I would like to know which is the best tachometer suitable 2 fit for a Santro.
How much wud it cost & How much time will it take to fit. Also will there be any tecnical errors since the Santro doent even have a RPM meter.
And wat difference will it make to my ride.
W8ing for Suggestion
Happy Revving...
rareone is offline   Reply With Quote
Old 3rd March 2006, 12:32   #19
cartouch_56's Avatar
as you have santro you can put auto guage ,that will cost you around 3.7k.if you want pm me.
cartouch_56 is offline   Reply With Quote
Old 3rd March 2006, 13:52   #20
rareone's Avatar
Thanked: 11 Times
Question
Thanks for the reply cartouch
BUT
I wud like to knw does tht auto guage 3.75" have a shift light
How much will it cost me with fittin.
Thanx
Old 3rd March 2006, 14:40   #21
speedsatya's Avatar
Thanked: 712 Times
yeah 2-way tapes will do ...use good ones...like 3M...to be safe u can use feviquick...
abt drilling holes ..u will have to do that for the wires
speedsatya is offline   Reply With Quote
Old 3rd March 2006, 15:38   #22
Thanked: 46 Times
any after effects to be expected after drilling holes??
Old 3rd March 2006, 17:59   #23
Smile
it doesn't have shiftlight,price is with fitting
Old 3rd March 2006, 18:05   #24
rareone's Avatar
Thanked: 11 Times
Cartouch Dude,
Actually i was looking to fit a Tachometer which is with a Shiftlight.
If u can arrage let me knw its details.
Thanx
Old 5th March 2006, 14:38   #25
Thanked: 13 Times
Rareone,
Originally Posted by s0uljah
Hi Sagar,
Iv seen the pricol one, my friend has it in his zen.
Now about the AutoGuage 3.75" @ Rs2150..... is this tacho a shiftlight model ?
Thanks.
http://www.autogauge.com.tw/
Originally Posted by Sagarpradhan85
hi,
Hope this helps.
Old 5th March 2006, 14:56   #26
nitrous's Avatar
Thanked: 285 Times
Cars with 'dual-coil ignition system' will have a problem.
Best place to get the rpm is from the ECU. But, u need to know the ECU diagram to get the correct point.
Old 6th March 2006, 09:15   #27
Thanked: 46 Times
Is the above said gonna be appicable for an carb esteem??
Old 6th March 2006, 11:07   #28
rareone's Avatar
Thanked: 11 Times
Question
Hey SoulJah
I check the site as per ur suggestion.
There are many models available.
Can u tell me which model have u installed or talking about.
Also where do we get those in Mumbai.
Thanx
Happy Revving...
Old 6th March 2006, 13:17   #29
speedsatya's Avatar
Thanked: 712 Times
no problems as such for a carb esteem
Old 9th March 2006, 11:52   #30
Thanked: 46 Times
but my mech says the RPM meter cannot be mounted 'cause its gonna foul with the windshield.. is it true?? Does anybody have a photograph of an esteem fixed with a 5" tacho??
need your suggestion urgently.. The mounting had to happen last saturday but it did not
Help reqd with installing OE tachometer in AStar VXi Sankar Modifications & Accessories 24 12th October 2016 10:33
Is a tachometer required on a CAR ? skamb Technical Stuff 72 6th December 2014 21:57
tachometer ... problems cooldude585 Modifications & Accessories 9 9th January 2009 15:23
Tachometer Needle Vibrates at High Revs - Help amannarwal Technical Stuff 17 28th March 2008 11:02
Tachometer Pricing dragger Modifications & Accessories 10 11th February 2005 17:47
