Old 9th March 2006, 11:56   #31
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by CaliforniaKnight
any after effects to be expected after drilling holes??
dude ...its a small hole for teh wires to pass through ...
speedsatya is offline   Reply With Quote
Old 9th March 2006, 23:04   #32
aZa
aZa's Avatar
Thanked: 17 Times
I have Santro Xing i want a RPM meter with Shift light tooooooooooooo .. anyone knows any good shops in delhi or noida ?
Old 10th March 2006, 16:37   #33
Rahulk76's Avatar
Thanked: 204 Times
Guys try this
I got my Tachometer for Indica DLS 2003 Model. Sent a cheque to them, and recieved the part in 2 days in excellent condition. 50rs paid to TASC to fit it. There was a wire coming into instrument cluster. Its black in color with little white line. Actually the wire from alternator to the instrument cluster.
Rahul
Anant Pithawalla
Website: www.n1engineering.com
Email : info@n1engineering.com
Tel: 0091 9821221791
Fax : 0091 22 24441796
Rahulk76 is offline   Reply With Quote
Old 10th March 2006, 18:19   #34
viper's Avatar
Thanked: 9 Times
but my mech says the RPM meter cannot be mounted 'cause its gonna foul with the windshield.. is it true?? Does anybody have a photograph of an esteem fixed with a 5" tacho??
need your suggestion urgently.. The mounting had to happen last saturday but it did not
I had a 5" Monster RPm in my esteem. Unfortunately no pics.You will have to fit it just above the AC vent.
Viper
viper is offline   Reply With Quote
Old 10th March 2006, 18:23   #35
Psycho's Avatar
Thanked: 95 Times
Originally Posted by nitrous
Cars with 'dual-coil ignition system' will have a problem.
Best place to get the rpm is from the ECU. But, u need to know the ECU diagram to get the correct point.
Other ways to install it too, you can avoid the ecu route altogether, easiest way set the selector to 2 cylinder and link it to the coil, if that is not possible hack into the wire on the orig RPM meter in the car, however please take care as this will have to be done by a skilled person.
Old 10th March 2006, 22:49   #36
hot_rod's Avatar
psycho how can this be done in a 800??
hot_rod is offline   Reply With Quote
Old 10th March 2006, 23:30   #37
nitrous's Avatar
Thanked: 285 Times
1) There is only 4,6 and 8 cyl option.
2) No OE tacho in my car.
Psychoji!! HELP
Old 18th April 2006, 15:57   #38
Praneet71's Avatar
Default Tacho meter - Help
Hi, Can anyone tell me from where in Pune can i buy a tacho meter for my Zen.
Praneet71 is offline   Reply With Quote
Old 27th April 2006, 14:39   #39
Thanked: 38 Times
Req Tacho for Gypsy. Price /Place . I am from Mumbai
lodhra is offline   Reply With Quote
Old 26th July 2007, 02:05   #40
Awaiting Email Confirmation
Are pricol tachos still available? if yes, then from wherE?
vidvai is offline   Reply With Quote
Old 8th July 2008, 12:01   #41
nishantgandhi's Avatar
Thanked: 151 Times
I am looking at a basic tachometer to be fitted in Getz 1.3. Which are the available brands (and prices) and where can I get it installed?
I remember having read elsewhere that Pricol is the cheapest at Rs 800. Does it have a shift light? (BTW what exact purpose does a shift light serve?)
Also, is anyone aware what will be the cost of retrofitting the GLX instrumentation cluster in GL model?
nishantgandhi is offline   Reply With Quote
Old 14th July 2008, 13:02   #42
yzfrj's Avatar
Thanked: 119 Times
Default My hunt for the illusive "Pricol" tacho
Response from shop's / dealers ?
1. Do they have Tacho ?
2. What is a Tacho ? (can you toll me if it'll improve mileage ?)
3. Its not available anymore.
4. I'll try and will get back (never gets back)
5. Its not available and we have xxx brand ranging from 2k to 8k.
Mails to id's in the Pricol sites have bounced.
yzfrj is offline   Reply With Quote
Old 23rd September 2008, 10:09   #43
sudipt123's Avatar
Thanked: 20 Times
Here's an update for the Elusive pricol tachometer, they are now being sold by xenos and it's mentioned in the website.
http://www.team-bhp.com/forum/985793-post160.html
sudipt123 is offline   Reply With Quote
Help reqd with installing OE tachometer in AStar VXi Sankar Modifications & Accessories 24 12th October 2016 10:33
Is a tachometer required on a CAR ? skamb Technical Stuff 72 6th December 2014 21:57
tachometer ... problems cooldude585 Modifications & Accessories 9 9th January 2009 15:23
Tachometer Needle Vibrates at High Revs - Help amannarwal Technical Stuff 17 28th March 2008 11:02
Tachometer Pricing dragger Modifications & Accessories 10 11th February 2005 17:47
