Old 14th October 2011, 18:37   #1
Thanked: 70 Times
Default Momo Steering wheel for the Nano??
I am thinking of buying a Nano for my personal city use. I have a MOMO wooden steering whell currently fitted to my 2005 Alto. I want to know if I can take it off the Alto & fit it in the Nano? To do this, I need to get the centre hub to match the Nano rod & splines? Can anyone please advise?
C.S.ANANTH is offline   Reply With Quote
Old 14th October 2011, 19:28   #2
Thanked: 3,508 Times
Default Re: Momo Steering wheel for Nano
You need a steering wheel adapter hub with splines that match with nano's steering rod. Finding a hub with matching spline could be tough task.
Else you can buy another steering wheel and use its base to build a hub adapter. Also note that indicator autocancel will not work unless you find/build a matching hub.
Old 15th October 2011, 07:16   #3
Thanked: 70 Times
Thanks Sankar.The original hub & steering wheel of the Nano is an integrated single moulded piece. I need to separate this hub from the wheel. How can this be done? The surface of the hub cut off from the wheel has to be smooth.Only then the MOMO can be screwed flush on the hub.Please advice.
Old 15th October 2011, 08:04   #4
OE steering is almost always a single integrated unit. What I meant was to buy another one and cut it up to create the base for a hub. I know a friend who did such a thing for his m800 in spite of being the hub readily available for it.
Old 15th October 2011, 16:59   #5
Thanked: 70 Times
Thanks for your inputs.Being a Vintage & classic car rstorer,I am aware that steering wheel is an integrated unit.My apprehension was if one could slice it in such a way the surface is even. I am yet to decide on the Nano. Will decide soon.
Old 15th October 2011, 17:11   #6
Separate the metal base from the plastic, should be easy after that.
Old 15th October 2011, 17:34   #7
Thanked: 70 Times
THanks.will do that when I buy the Nano.
DIY: Installing a Momo Steering Wheel ariesonu DIY - Do it yourself 17 19th October 2015 23:48
A Nano trip on a Nano budget...in a Tata Nano novice_alto Travelogues 11 28th September 2014 15:19
Momo Steering - Palio Stile 1.6 Sport eclectix 1st Modifications & Accessories 31 3rd June 2012 17:08
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
