Old 18th October 2011, 11:35   #1
Default Suggestions on Punto suspension
Hi All,
Hope I am posting in right section. Wanted to post it in classifieds, but rules there says 'no questions can be posted there'. I have a Punto MJD emotion pack and it came with one of the best suspension I have seen in any car. I went on a long trip with it from Hyderabad to Goa sometime last year. Some 200KM road stretch on both sides of AP-KA border was filled with pot holes and as I have to rush back to HYD, on return trip I didn't bother much to slow down. Punto atleast had hit 5-6 pot holes at 100 KMPH and when I hit the last pothole, my front right side alloy wheel and tire got damaged. I got alloy wheel and tire repaired and replaced tire with spare tire. After all this rough road handling, my suspension also lost its original feel of ride quality and handling. It made noises like 'tak', 'tak' whenever I go over hard concrete or on undulated surfaces. After that trip, I have serviced my car twice with Tata ***, but they couldn't do proper diagnosis for suspension. They once replaced top caps to remove that sound and another time replaced tie rods. I have asked for suspension overhall/replacement at my own cost both the times, but they said your suspension is fine and don't need any other service. I doubt service center's competency in dealing with suspension. Any one can suggest me a good suspension service/repair center in Hyderabad? There are many exclusive small suspension repair shops on Minister Road/ Lower Tank Bund road. How reliable are they? Can they handle Punto's Multi Link and McPherson suspensions or they can do only Coil Springs and Leaflets of Jeep and Ambassodor type?
Rach is offline   Reply With Quote
Old 18th October 2011, 11:43   #2
mayankk's Avatar
Thanked: 3,559 Times
Default Re: Suggestions on Punto suspension
can you get your steering column etc checked?
not for a punto, but i faced this repeatedly in my zen, till it was finally traced to the column after 5-6 visits to the service people/FNGs over 6 months.
Also, how did you get the alloy wheel repaired??????
mayankk is online now   Reply With Quote
Old 18th October 2011, 11:59   #3
My Alloy wheel had a dent on inside edge, where tire meets alloy wheel. As my tires were tubeless, it was not holding air due to this dent. I first went to a Wheel Alignment and Tire shop and they quoted Rs. 2500 for repair. Then, I went to A** and they said it cannot be repaired, but can only be replaced with a new Punto alloy wheel, which costs around Rs.8500/-. Then I inquired with couple of different wheel Alignment centers. One guy gave me the address of a aluminum forging shop on Minister Road, which also repairs alloy wheels. They are not exclusive wheel repair center, but a aluminum forging shop, which makes windows, grills, gates and other aluminum work. They heated the alloy wheel, removed the dent and bought wheel to perfect shape for just Rs 300/-. Obviously, most of the Wheel Alignment shops send their alloy wheels to this place for repair. Wheel shops fleece money from you just for transport and knowledge that aluminum forging center does this work.
Rach is offline   (1) Thanks Reply With Quote
Old 3rd July 2012, 12:16   #4
Hey Rach,
may i know how your alloy is doing now? and also can u give me the name and address of this repairing centre as even i need to get the dent on my alloy removed
tony05 is offline   Reply With Quote
Industrial Scissor found in brand-new Punto's suspension! GTO Technical Stuff 27 12th June 2014 22:59
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Punto Sports (MJD) or Punto T-Jet theEnd The Indian Car Scene 69 30th June 2010 23:26
Worth waiting for Fabia/Punto/Linea/Renault Sandero? EDIT - Bought Punto ~~VinZ~~ Hatchbacks 25 7th April 2010 16:06
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
