Old 14th December 2011, 15:41   #91
Xryder's Avatar
Thanked: 75 Times
Default Re: The Baleno Makeover
I have quite a few pictures and videos of the ICEMAN, but I have not put them up since I wanted Rameshji to complete the narration.
P.S - Congratulations to you Rameshji on getting hitched !
Xryder is offline   (1) Thanks Reply With Quote
Old 14th December 2011, 16:40   #92
infotech58's Avatar
Thanked: 217 Times
this really turned out to be a lot better than anticipated. congratulations on neatly and professionally executed job.
please think about changing the alloys to something similar to BMW 10 spoke alloys and even think about painting them into black.
also post more pictures: interiors, and rear profile.
infotech58 is offline   (1) Thanks Reply With Quote
Old 14th December 2011, 19:10   #93
Thanked: 140 Times
Thankyou folks. For your kind remarks and blessings too.
To address the general questions and remarks (cant do it for each person as there are too many)...
-Yes the ORVMs are from the older Honda City.
-Going by the feedback from the owner, the car has been so far driven up to a speed of 120Kmph and the stability has increased a bit from what it used to be he says; so aerodynamics has not been an obvious issue with this design. I dare say it may have improved with the new subtle side skirts.
I will sequentially release the subsequent pictures focussing on each area.
Another 3/4 angle of the front from a lower angle to indicate the bonnet musculature and the aggressive frontal stance.
The rear is a lot more clear from this angle. This is how we (successfully as per our perception) 'tamed' the 'wild' looking fins.
Then the wheels - yes - the wheels are certainly going to be swapped as the design was made with wider more snazzy looking footwear in mind. So we went hunting for the right set of footwear at a suitable budget.
We narrowed it down to some options like these:
And eventually settled for these simple gorgeous deep rimmed and not-too-loud 15" 'Elegant' wheels.
Big enough to fill the wheel wells but small enough to allow for suitable 205 R55 tyres to negotiate our roads.
R.K.Ramesh is offline   (4) Thanks Reply With Quote
Old 14th December 2011, 20:41   #94
Rudra Sen's Avatar
Thanked: 4,092 Times
Ramesh, from your latest set of images, one question comes to my mind.
Is that bulged out bonnet obstructing part of the vision for the driver?
Old 14th December 2011, 20:47   #95
Jassy1313's Avatar
Thanked: 56 Times
hey Ramesh,
tires play a very important role (looks and handling)..
my suggestion is to go for 16'' rims and 205/55 R16.. Trust me your ride will rock the road..
Jassy1313 is offline   Reply With Quote
Old 14th December 2011, 20:53   #96
anekho's Avatar
Thanked: 659 Times
Ramesh, some honest feedback about your choice of rim - somehow I just don't feel the 4 spoke rims you've chosen will look too good on your ride.
IMO, try getting multispoke, aluminium, BBS-style alloys. Something like this:
I feel they'll really gel with the car's great looking body!
anekho is offline   (1) Thanks Reply With Quote
Old 14th December 2011, 20:58   #97
Rudra Sen's Avatar
Originally Posted by anekho View Post
Ramesh, some honest feedback about your choice of rim - somehow I just don't feel the 4 spoke rims you've chosen will look to good on your ride.
Agree with anekho here. Your choice of rim will make the car look naked. It needs equal amount of body on the wheel part.
But again, this is very subjective.
Old 14th December 2011, 21:49   #98
akas_chauhan's Avatar
Thanked: 22 Times
Originally Posted by R.K.Ramesh View Post
ICEMAN seems to be bringing me good luck. and it has made me busy over the weekend in a different sort of way - Am starting a new phase in my life - getting engaged today so will have to proceed with the updates from tomorrow.
Kind Regards
Ramessh
Congratulations Ramesh for a new begining. Wish you all the best for your future.
BTW how much was the cost for this modification?
akas_chauhan is offline   (1) Thanks Reply With Quote
Old 14th December 2011, 23:23   #99
Thanked: 140 Times
@ Rudra, the bulge is more exaggerated visually from this lower angle. However during normal driving I actually didn't realise it was there - it is only during close parking situations that it is noticed and even that can be addressed by looking past the side of the bulge.
@ Jassy, the rims that we finally chose came with a big 45% discount and we felt that it was worth it given that it also had a deep rim. It actually looked good on the car after installation. You may concur further down this thread.
Also the 205/55 R15 were just the right fit as we found a very meager clearance between the tyres and the wheel arch liners during full lock full suspension travel.
R.K.Ramesh is offline   Reply With Quote
Old 17th December 2011, 17:36   #100
Thanked: 140 Times
And now coming to the custom lights...
We used after market fog lamps and headlamps to insert custom made LED lights and acryllic lens to give the desired effect. The colours depicted here are not very accurate.
This is the indicator light :
These are the tail, brake, and indicator lights. The yellow and red LED lights here don't look very differentiated but in real life they are...
R.K.Ramesh is offline   (3) Thanks Reply With Quote
Old 18th December 2011, 01:36   #101
VOiLA's Avatar
Get the 2nd one from the top.
VOiLA is offline   Reply With Quote
Old 18th December 2011, 08:43   #102
raj_5004's Avatar
Thanked: 2,031 Times
The car is turning out to be a stunner. Will surely turn heads wherever it goes.
The only problem is that the amount of custom made parts is so much that a minor shunt would mean that days of hard work gone down the drain. For example, its not as easy as going to the workshop & buying these tail lights. While you are at it, make some spare ones for the owner as well!
Old 21st December 2011, 12:25   #103
cags's Avatar
Thanked: 12 Times
Looks like the thread is dead, Ramesh can you please post the final pictures
cags is offline   Reply With Quote
Old 21st December 2011, 21:24   #104
Thanked: 140 Times
Thread revived now @Cags - Was out of action here due to other pressing priorities on my personal front (impending marriage) and work (Indica kits and other Sierra and Jeep makeovers which I will feature soon).
@ Voila, Wheels already chosen and it wasnt the second from the top - and as it turned out the chosen ones were very good in a deep rim sort of way.
@raj_5004 we did a cost value trade off on those custom lights. The indicators are readily available with us - made extras. The Front headlights older Honda Civic's have to be imported from Thailand and the rear will take a week or so to make another set. Casings are readily available but interior components will have to be regenerated for which we have suitable means.
Either ways the rear lights are deep set so will need more than a minor shunt to get damaged. Front lights too are deep set and mountings linked to the bumper to push it in on impact to reduce chanced of small bump damage. The side indicators are installed on a hinge which allows it to take a medium intensity hit before it sustains damage. So all these lights have been installed with thoughtful precaution. Hoping that they will not have to come in for replacement soon if at all.
Now to zoom into the details
LED Reverse Lights changed later to something more powerful for added sparkle and a clearer rear view - not to mention the fade in/out effect at night
A closer view of the custom tail lights
Custom Indicator lights
The aggressive front lights from the older Honda City - Note the lower face DLR
R.K.Ramesh is offline   (12) Thanks Reply With Quote
Old 21st December 2011, 23:37   #105
Thanked: 274 Times
Ramesh , must say the bonnet looks seriously muscular in a positive way . The tail and indicator lamps look stunning . The paint job is superb too. You have made us wait enough. Now can't wait to to see the final set of pictures.
needforspeed88 is offline   Reply With Quote
Baleno makeover abhi1881 The Indian Car Scene 50 2nd August 2005 12:51
Toyota's Image Makeover Samurai The Indian Car Scene 16 24th February 2005 15:21
Isuzu Panther (Chevrolet Panther) gets a makeover v12 The International Automotive Scene 3 3rd November 2004 15:29
Elantra to get a makeover adityapd The Indian Car Scene 8 9th June 2004 16:50
