Old 1st November 2011, 23:41   #1
HAFI's Avatar
Default Skoda Octavia VRS - H&R Springs Modification Query
I own a Skoda Octavia VRS.I have installed Bilstein B6 Shocks and H&r springs.Its been a year and a half since the modification.I haven't had any issues till date.
Now i am not satisfied with the lowering level the spring offers and there is no issue of road bumps as i run only strictly inside the city and all bumps are of minimal height so nothing to worry on that.
The adjustable suspension cost a bomb.So is cutting one of the dead coils of the spring to lower the height by 1/2 " a safe practical idea??
From my research the tension comes only in the active area of the spring and the dead coils are used for the spring to rest on the suspension.Wont it be a cost effective way to lower our ride.?
Guys i need your inputs.Please do help me out here....
HAFI is offline   Reply With Quote
Old 2nd November 2011, 06:02   #2
1self's Avatar
Thanked: 270 Times
Default Re: Skoda Octavia VRS - H&R Springs Modification Query
I have done it on my Sonata to lower ride height. While it is possible to do it, careful measurements have to be taken & springs have to be uniformly heated in a kiln at 1000 Celsius before cutting. After cutting, it is put in an oil bath to prevent heat stresses. After that it is cooled down in a sand bath. So it is quite an involved procedure.
Also, if the springs are flattened at either the upper or lower ends to sit snugly in the perches, then you can't mod it at all. Some springs also have variable stiffness in bounce. Then again you cannot mod it.
I repeat this is NOT a simple job of using an oxy-acetelene cutter to simply cut the excess bits.
So, do know the pitfalls of what you are getting into.
1self is offline   (3) Thanks Reply With Quote
Old 2nd November 2011, 07:16   #3
fre2bpowerless's Avatar
Thanked: 81 Times
Originally Posted by HAFI View Post
The Octy RS is one awesome car, the Bilstein/H&R set-up must have given her sweet handling as well.
I'd suggest you save up and go for a new set of springs rather than ruin your H&R. 1self has listed the process above, its doesn't sound practical & you risk losing your springs.
1/4 inch of a coil is almost an inch of ride height, the cut has to be correct till the last mm to ensure your car is even on all corners. If not, your risking your safety in an extreme scenario such as emergency braking/swerving.
fre2bpowerless is offline   Reply With Quote
The Skoda Kodiaq. EDIT: Now launched at Rs 34.49 lakhs ajmat The Indian Car Scene 412 15th December 2017 17:56
SKODA VRS lowering springs any problems Frank Zappa Technical Stuff 1 25th June 2010 16:32
H&R Springs On Stock Shocks For A Skoda RS HAFI Modifications & Accessories 15 7th May 2010 05:54
Skoda Octavia II vRS skodaboy The International Automotive Scene 19 7th May 2006 20:17
Hot Skoda Octavia vRS nikibusa The International Automotive Scene 11 21st September 2005 12:58
