| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi all, So finally installed new iridium plug in my 1995,carburetor esteem fitted with K & N replacement filter & LPG kit. The performance is just mind blowing......i cant imagine my car having such an acceleration.....it just crosses 0to80 within no time......much much better then what I had.......mileage not at all affected.....but yet to see how much gain in it.............. Few point which I want to share......after installing K&N filter......I had done my carburetor setting........Opened air screw more & allowed more air........& my gas supply made rich too .....not so much rich to affect my mileage......this effort took almost 4 days of contant trial & error .........then finally at one point of time I found car just gliding on road with much more power at entire rpm range............then i waited to see whether this setting is good for incresed mileage or not.........& this setting made me happy as it increased my mileage to nearly 1Km per Kg of gas. Also I adjusted the Iridium plug gap.......i made it narrow by 2to3mm....... & result is wonderful..... I tested my car on petrol too.........pick up is so much improved.car feels so much lighter.....responsive.......... I havent changed ingnition coil....plug wire...but response is excellent...... I wish that all users running on LPG gas must take advantage of this spark plug.......they are indeed good for engine running with LPG......... WIll post soon after checking my mileage........... __________________________________________________ ______________ Optimizing the resourcesEconomically is My Passion,This habbit extended to everything I possess. |
| | #7 (permalink) |
| BHPian | hey finetuning, Is that a stock K&N replacement filter that you have gone for ? how much does that cost you and from where did u get it in Mumbai ? what mileage do u get in petrol mode ? I too have a carbed 95 esteem petrol ( no LPG) though and was contemplating going for this filter since the past few days and hence your feedback would surely help. ~A
__________________ any rpm, any gear, just push the pedal to the metal and the baleno will deliver T-O-R-Q-U-E to you !!! |
| | #8 (permalink) |
| Dear Adityapd, Its replacement filter.Price 4700 from Four Season Automobile at tardeo,contact no.24940444...........my mileage with petrol not yet checked as most of time I drive with lpg.But sure its 10+. With carburetor u need to adjust setting to fully utilise this filter.Just open air screw more then adjust fuel setting accordingly.U have to adjust this till u get perfect balance of power & mileage.I so much prefer carburetor for this unlike mpfi. This filter really help engine work more efficiently.U dont have to regret.But one thing very sure,ur engine must be in optimum condition to pass on benefit to u.Most of time after using such products ppl complain of not getting desired result & culprit is health of engine & other system. So new spark plug,tuning,good clutch,good oil will only help running car better.......if all these not working in optimum condition then how Best filter can perform? Enjoy.... |
| | #9 (permalink) | |
| BHPian | Quote:
~A
__________________ any rpm, any gear, just push the pedal to the metal and the baleno will deliver T-O-R-Q-U-E to you !!! | |
| | #11 (permalink) | ||||
| Distinguished - BHPian ![]() | Quote:
http://www.edelbrock.com/automotive/sparkplugs.html
__________________ Learning is a continuos job that keeps me busy. | ||||
| | #14 (permalink) |
| Hi Pshyco, Indeed K & N gave more performance boost with correct carburetor setting.But what I meant to say that after installing iridium plug & narrowing down gap....really my car is much more responsive.....Acceleration is improved & can be felt. Regarding setting of air srew.....it is definitly advisable to open it with K & N filter then open incoming gas setting at Vaporiser end. Regarding spark plug.....i asked Four Season ppl to check plug number to be used with my esteem.Its running so well & heat range is ok. I think no need to check ignition system with slight reduction in spark plug gap. Enjoy.......... |
| | #15 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| LPG Conversion - Experience/Queries | tvsakpal | Technical Stuff | 151 | 27th July 2008 11:52 |
| Iridium or Twin Electrode Plug ?????? | eagle_f1 | Motorbikes | 2 | 11th November 2006 22:44 |
| Lpg Or Cng Better For Esteem Mpfi | santo | Modifications & Accessories | 28 | 20th July 2006 20:50 |
| car buying experience - Esteem | pk3977 | Technical Stuff | 7 | 15th April 2006 17:24 |
| Is It necessary to add new plug wire,ignition coil if adding new NGK Iridium Plug | finetuning | Modifications & Accessories | 16 | 17th March 2006 06:53 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
