Old 28th December 2011, 09:23   #1
shivshanker's Avatar
Thanked: 87 Times
Default Is the Esteem's clutch compatible with the Baleno?
Modification Guru's,
Since my Baleno is almost 7 years old now have decided to shift from MASS. I have narrowed down to a good and reputed garage near my place.
The mechanic is claiming that the Esteem Clutch and pressure plates are a 100% match for the Baleno.
He claims he has fixed it to over 4-5 Baleno's where I live, any ideas is this will work.
I was hoping for a few reference/contact numbers of the other owners from my mechanic, however in the mean time wanted to bounce it off on the forum.!
shivshanker is offline   Reply With Quote
Old 28th December 2011, 10:49   #2
SRK
SRK's Avatar
Thanked: 352 Times
Default Re: Esteem and Baleno Clutch
Not sure completely but should work. Maruti has been sharing its parts with most of their models.
Where you getting your work done from?
There is one mechanic at Bandra, who is a Maruti specialist as he had been working there.
See this http://www.team-bhp.com/forum/mumbai...st-mumbai.html (Mechanical Works & Repairs - Nakita Motors (Bandra West, Mumbai))
May be could be helpful for you. You can call him up and ask if it can be done or no.
SRK is offline   Reply With Quote
Old 28th December 2011, 12:25   #3
gigy's Avatar
Thanked: 41 Times
esteem's and baleno's clutch can be interchanged but its not recommended due to the power/ torque difference,
There is no need to go for this downgrade since there is no price difference between the two. Get the 4 spring one(its actually 8, there are two inside each)(baleno), not the six spring one(esteem). I recommended ceekay to valeo since i found valeo wearing off faster.
gigy is online now   (3) Thanks Reply With Quote
Old 28th December 2011, 12:43   #4
suhaas307's Avatar
Thanked: 6,601 Times
Why go in for a mechanical component that is not correct and suited for your car? Always get parts that are meant for the particular car. I'm not sure what the price difference is, but I'm sure it's not much. So it shouldn't be a problem.
The 1.3 in the Esteem makes about 85 horses, while the G16B in the Baleno makes a little more. Around 90 or so? The Torque isn't too different either. But that shouldn't mean that you could go in for a component that isn't entirely suited and made for you car.
It isn't worth the risk, even if your car has notched up the miles.
suhaas307 is offline   Reply With Quote
Old 28th December 2011, 13:51   #5
kutlee's Avatar
Thanked: 194 Times
What's the saving you are aiming at (for another 7 years?) by the clutch?
kutlee is offline   Reply With Quote
Old 28th December 2011, 14:19   #6
Thanked: 87 Times
@gigy,
Obviously, the 4 spring Ceekay clutch plate should be procured from a non MASS setup.
Any pointers as to where should one pickup these from.?
@kutlee, the MASS numbers are atleast 4K apart, however with ceekay plates that difference might be reduced, hence will stick to Baleno 4 springs setup as suggested by gigy.
I see the point you were trying to make, got me thinking as well. Not sure what I was trying to save 4K for.?
Cheers!
Last edited by Eddy : 28th December 2011 at 15:14. Reason: Please use the edit / multiquote option instead of posting back to back posts within 30 mins. Thanks.
Old 28th December 2011, 17:37   #7
kutlee's Avatar
Thanked: 194 Times
for baleno there are always options. Try aftermarket stuff such as exedy.
Old 29th December 2011, 11:05   #8
gigy's Avatar
Thanked: 41 Times
Default Re: Is the Esteem's clutch compatible with the Baleno?
I have seen MASS guys picking up ceekay clutches from prakash automobile, santacruz. It was about 2400 for clutch set only. don't remember bearing cost may be 400-600. another thing commonly swapped is the clutch cable with esteem, its slightly shorter in length and after installation makes clutch very hard, getting original cable for baleno may be problem, so retain the cable if its good and don't lubricate it with oil.
gigy is online now   Reply With Quote
Old 29th December 2011, 13:56   #9
shuvc's Avatar
Thanked: 283 Times
Clutch has been changed twice on my car at MASS. At 22k kms and at 75k odd. On both occasions I was charged around 4k. I was told they used the esteem clutch.
Presuming the first one was also an esteem clutch, I have had no issues with it for 55k+ kms.
Old 30th December 2011, 13:57   #10
Thanked: 152 Times
Infractions: 0/1 (5)
Suzuki OEM Made In Japan , MASS Specificed Clutch bearing costs 1700/- INR for Zen , Esteem , Baleno .It is the same.
Trust_In_Thrust is offline   Reply With Quote
Old 30th December 2011, 15:08   #11
Thanked: 87 Times
@Thrust_in_thrust, would you know the recommended change interval for the Bearings.?, I know for sure the pressure plate needs to be changed along with the main clutch plates, However not sure about the bearings.
Old 30th December 2011, 23:47   #12
Thanked: 152 Times
It is easy when you open up the clutch remove the bearing and bring it close to your years and if you hear noise while it is rotated(by hand) go ahead and change it .
When you change it is better to change
1.) clutch
2.) Flywheel
3.) pressure plate
4.) clutch bearing
5.) Clutch Cable in case it is not hydraulic
6.) Gear shifter rubber bushings , incase of cable activated gearshifter the housing of shifter along with cables.
7.) Clutch pedal springs should be checked too
This sounds too much but every part here makes sure you enjoy shifts like when your car was new.
The SGP make is NTN if i remember correctly while it was installed in mine.
You can buy from outside also which cost 400-500 Inr but there is huge difference in finish of the SGP and what is sold outside.
Trust_In_Thrust is offline   (1) Thanks Reply With Quote
Compatible amplifier with pioneer 6950ib abhi212 In-Car Entertainment 18 17th November 2011 15:24
Compatible CD-Changer with Alpine 9830 moralfibre In-Car Entertainment 30 27th December 2008 20:11
Alpine 9853 and other iPod compatible HUs d.kiran In-Car Entertainment 12 9th October 2007 09:11
Compatible CD changer for Ford Ikon WasavaTyres In-Car Entertainment 1 19th September 2006 11:03
MP3 flash card compatible head units? Why not? navin In-Car Entertainment 32 19th October 2005 00:36
