Old 5th January 2012, 13:34   #16
Mr.Boss's Avatar
Thanked: 2,546 Times
Default Re: Maruti 800 with a Mid-Engine RWD? Is it possible?
Originally Posted by Mirage View Post
Sorry, I meant the tranny shift linkage.
If you are worried only for the tranny shift linkage, you can convert to cable shift mechanism, but again it calls for lot of R&D. IMO it is worth re-engineering to cable shift mechanism than modifying the existing linkages.
Mr.Boss is offline   Reply With Quote
Old 6th January 2012, 08:56   #17
muditgrover's Avatar
Thanked: 133 Times
This stuff is sure possible, but why use a M800 why not an esteem?
Doing that to the esteem plus some more mods can make it run very nice numbers in a drag.. all you need to take care is of the suspension setup and the structure of the car!
Good Luck!
muditgrover is offline   Reply With Quote
Which Indian Car has mid-engine RWD? GTO The Indian Car Scene 32 5th January 2011 14:59
converting a FWD to a RWD....POSSIBLE? twister Technical Stuff 21 27th April 2006 03:05
Is it possible to dump a 1.0 or 1.3 liter block in the Maruti 800? zero_lagg Modifications & Accessories 6 23rd August 2005 10:18
