Old 12th January 2012, 08:50   #31
rakesh_r's Avatar
Thanked: 743 Times
Default Re: Swift VDi Remapped
Originally Posted by satya180 View Post
Add to that the Dynamisation kit, fitting, labour and the dealer warranty. I couldve fit it myself, but Mr. Lonkar (Tune Up Plus) was very helpful wrt everything. So i decided to get it fitted there itself.
great stuff satya,i am tempted to go for one too.But am a bit skeptical on CAIs.Are you sure it wont suck in dust(which is the case in Kn's)?
rakesh_r is online now   Reply With Quote
Old 12th January 2012, 17:01   #32
satya180's Avatar
Thanked: 211 Times
Rakesh, sucking im dust depends on where your driving.. I cleaned my filter after 20000 kms yesterday, and there was quite a bit of dirt.. The remap only feels much better now
Originally Posted by F150
What its the cost of brake upgrade bro ? Mine is a 2010 swift, would I need the brake upgrade as well ?
Brake upgrade i would recommend. Just got a quote from tune up plus.. They make slotted and cross drilled rotors for the swift.. Approx Rs.12000/- for the upgrade.. Im now confused between brake pads and getting a rotor upgrade.. Any suggestions?
Note from the Team-BHP Support Team : Please use "Multi Quote" option for quoting Multiple posts, instead of creating another back-to-back post.
satya180 is offline   Reply With Quote
Old 12th January 2012, 22:03   #33
Thanked: 817 Times
Actually I have started looking up options about the same. I was quite set on upgrading the rotors to grooved and cross drilled etc but then saw an article that mentioned that it wouldn't make much of a difference in daily driving - it was more of a race upgrade.
Another link mentioned that while upgrading to cross drilled would reduce the stopping distance from 100 kmph in a controlled smooth braking scenario, it wouldn't make much of a difference in a panic braking scenario.
This leaves me wondering what I must do.
Drive on,
Shibu.
shibujp is offline   (1) Thanks Reply With Quote
Old 13th January 2012, 10:18   #34
jkdas's Avatar
Thanked: 1,436 Times
Drive on,
Shibu.
shibu, it helps. I would recommend that you drive one and see. Peter might be able to help and/or visit Jerry's @ Thycad.
Costly though.
Old 13th January 2012, 12:36   #35
satya180's Avatar
Thanked: 211 Times
Even i actually want to drive one and see before taking the plunge.. Another option im considering is upgrading the master cylinder to the newer one, and getting uprated pads.. I have read and heard that a cross drilled and slotted rotor is usually noisier than usual, which im not ready to live with.
Old 14th January 2012, 02:10   #36
Technocrat's Avatar
Thanked: 2,589 Times
Wow Satya, the mods sound interesting, am tempted to drive the car now. I had driven it bone stock would be interesting to drive now
Old 14th January 2012, 08:49   #37
satya180's Avatar
Thanked: 211 Times
Anyday man.. Whenever you come back.. We can do our Hinjewadi drives again.. By the time you come, more stuff wouldve gone on, hopefully..
Old 14th January 2012, 11:01   #38
paras211's Avatar
Thanked: 57 Times
Can I have sarvesh's number can't see
To get thru the number listed on the site
paras211 is offline   Reply With Quote
Old 14th January 2012, 11:06   #39
F150's Avatar
Thanked: 685 Times
Call up the number listed on website, they will connect you to sarvesh. I spoke with him on Wednesday.
F150 is offline   Reply With Quote
Old 14th January 2012, 11:19   #40
paras211's Avatar
Thanked: 57 Times
I can't get through the number on the site.
Old 14th January 2012, 12:09   #41
benzinblut's Avatar
Thanked: 598 Times
Congratulations on the mods. You are enjoying every momemnt of it for sure. The above par experience with Cosworth makes the package even better.
Cosworth's website mentions an increase in FE of 10-12%. What's your observation?
What's the impact of the remap on the turbolag?
benzinblut is offline   Reply With Quote
Old 14th January 2012, 15:10   #42
satya180's Avatar
Thanked: 211 Times
FE has gone up. I dont drive that fast in the city and on my same commute route i can vouch for the increase in FE. Its has become even better because i dont use the AC now a days in the winters.
Lag is there.. but now it feels violent..
Old 14th January 2012, 15:44   #43
benzinblut's Avatar
Thanked: 598 Times
Are you calculating the FE? Can you mention the increase in a %?
So does that mean that the tubokick is more prominent now? Re-map should actually reduce the lag, or the turbo should kick in earlier no?
Old 14th January 2012, 16:15   #44
satya180's Avatar
Thanked: 211 Times
Sorry but i usually calculate FE over a long period of time, say 8000 kms, so can give u exact figures.. But i can safely say that a tankful usually lasts 10-15% more now, than it did before..
The turbo kicks in at the same rpm even now, and the turbo kick is more prominent.. Not sure if its supposed to be this way or not, but sure is fun!
Old 14th January 2012, 18:48   #45
amit_mechengg's Avatar
Thanked: 1,556 Times
cant help it in case of FGT turbo. for VGT remap can accommodate it
My ka Laal: Swift - Oye VDi, VDi Oye! - 12 months, 29.3k km UPDATE phamilyman Long-Term Ownership Reviews 89 7th May 2010 17:13
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
Why is Ritz VDi more expensive than the Swift VDi ? Tapan The Indian Car Scene 49 1st June 2009 18:19
Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI agm Hatchbacks 29 11th April 2008 22:56
Swift Vxi or Swift Vdi or New Ikon Flair nikunj_cal Hatchbacks 16 4th April 2007 02:40
