Old 10th April 2012, 16:39   #61
Schoudhury's Avatar
Thanked: 470 Times
Default Re: From China, With Love - Fluidic Hyundai Verna HID Installation
Originally Posted by mtnrajdeep View Post
I received the bulbs ordered by me today. I had ordered H11 type on 13th Jan and H8 type on 14th Jan and both were delivered today. Now I need to get these installed!
Hi Rajdeep
Im also planning to put HID on the fogs of my Ritz,so wanted to check if you were able to get those fitted and how is the experience so far.
Cheers.
Schoudhury is offline   Reply With Quote
Old 10th April 2012, 20:06   #62
sagarpadaki's Avatar
Thanked: 1,256 Times
Originally Posted by triedeverything View Post
I finally got the kit, yesterday. Almost 2 months, but I'm impressed with the quality. Can anyone tell me how to connect this? I've got more connectors than places to plug it in.
What are the two wires marked A?
Where does the B connector fit?
Where does the C connector fit? I'm thinking C goes into the connection going to the present halogen bulb. As the existing bulb is 35 W, I don't think I'll need a relay, it should be a plug and play... but where to plug what... that is the big question
Attachment 909320
Hi ,did you get it installed? was it plug and play? How is your feedback with the product?
BTW,which car?
Old 15th April 2012, 17:10   #63
mtnrajdeep's Avatar
Thanked: 88 Times
Originally Posted by Schoudhury View Post
Hi Rajdeep
Cheers.
Hi
The experience is excellent . They are brighter than the low beam headlights so I use them sparingly. It was a direct fit without any mods. Only problem I face is some loose connection in the right foglight that doesnt switch on sometimes. This is usually sorted out by switching off and on again. After switching on, there is no problem.
Cheers.
mtnrajdeep is offline   Reply With Quote
Old 15th April 2012, 21:23   #64
DieselLover's Avatar
Thanked: 86 Times
Can anyone comment on how hid will perform in swift fog lamps. Is it a worthy upgrade.
DieselLover is offline   Reply With Quote
Old 20th April 2012, 15:21   #65
mtnrajdeep's Avatar
Thanked: 88 Times
I am using them in the Swift fog lamps. They work brilliantly. Only thing we need to take care of is to aim the fog lamps by adjusting the screw provided to ensure that we get a beam spread that suits our style of driving.
Old 20th April 2012, 15:37   #66
Thanked: 86 Times
Many thanks rajdeep. Does it cause glare to oncoming traffic? Where is the adjustment screws in fog lamps?
Planning to put 4300k hid and hope to get a good improvement over OEM fogs which is pathetic.
A pic of your car with fogs on will be really indicative.
Old 21st April 2012, 19:05   #67
It will cause some glare. But it is not that bad because the lamps are at lower level and the size of the fogs are less compared to head lamps.
There is definite improvement in the illumination. Infact you can drive around the city with just your fogs on if the street lamps are there. Else fogs plus low beam is more than sufficient.
You can go ahead and get them installed. You won't be disappointed .
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 28th May 2012, 16:31   #68
Schoudhury's Avatar
Thanked: 470 Times
Guys .
There is a post in classifieds, for the similar kind of HIDs
http://classifieds.team-bhp.com/buy-...006-9005.html/
Any pointers, will it be a good idea to get these .
My new "Fluidic" Hyundai Verna 1.6L Diesel jk007 Test-Drives & Initial Ownership Reports 84 5th February 2015 12:43
DIY : HID (3000k) Installation in the Maruti Swift ACMohan DIY - Do it yourself 8 17th December 2012 18:44
Hyundai Fluidic Verna 1.6 VTVT SX (Option) rajandroid Test-Drives & Initial Ownership Reports 29 27th October 2012 22:52
Old Verna vs Fluidic Verna : A Comparison amitwadhwa Test-Drives & Initial Ownership Reports 13 10th July 2012 21:30
Hyundai Verna Fluidic Vs. Chevrolet Optra Magnum vs Chevrolet Cruze soulweaver Sedans 55 3rd October 2011 10:48
