Old 7th February 2012, 16:55   #16
rajeev k's Avatar
Thanked: 1,730 Times
Default Re: Replacing a worn out Door Panel / Trim
Is it a add on cover or a full custom work?
As you plan to keep this car for some more years, get the door pads also done matching with the new seats you have. Any upholstery guy would be able to do a good job at a budget cost.
rajeev k is offline   Reply With Quote
Old 7th February 2012, 17:07   #17
500ContyCruiser's Avatar
Thanked: 368 Times
Full custom work. Removed all previous covers (there were about 3 add-on layers before ).
Sure, will be looking for someone who does upholstery work.
500ContyCruiser is offline   Reply With Quote
Old 17th February 2012, 10:43   #18
esteem_lover's Avatar
Thanked: 445 Times
Fantastic job with the seat. Your door pads too look like new, did you get them new ? What were the costs for the seats and the pads ?
Old 19th February 2012, 09:31   #19
Thanked: 368 Times
Exclamation Re: Replacing a worn out Door Panel / Trim
Seats around 6k. Still some more work is pending for pads.
Checked with RNS, Yeshwantpur, Bangalore, they are quoting ~5500/- for single door!!
Old 20th February 2012, 15:18   #20
Thanked: 445 Times
That is just to scare you away. I am sure they cannot procure it even for 10k.
Old 20th February 2012, 23:38   #21
yogisays0909's Avatar
Thanked: 156 Times
Hey Bro, nice work there. I read in the previous posts that Pramod suggested to contact me for the door pads and the dash for type 3. I have replaced the dash and door panels of my type 1 esteem to type 3. I paid appx 8K for everything plus the power windows separate. I have put back the type 1 interiors back along with the manual windows. Sold off the type 3 sets for appx 6K.
yogisays0909 is offline   (1) Thanks Reply With Quote
Old 21st February 2012, 00:28   #22
Thanked: 368 Times
They are asking for 15 days to get the parts. I have not confirmed with them. I am trying to see if I can get in any place for better deal.
Someone suggested me to try Shivajinagar market, Bangalore.
Thanks yogisays0909. If you still have any contacts in Mumbai (Bangalore would be even more better) who sells/does Esteem part, can you provide me with their details? I am not in a hurry, but need to get this fixed asap.
There are few other things I want to get replaced. Hence I am looking for lesser price, at the same time not much compromising on quality.
Yeah, I cannot get very good quality products at steal-away price. If I can get, would consider myself lucky
Old 21st February 2012, 10:40   #23
motomaverick's Avatar
Thanked: 864 Times
You could try Karlson Leathers in Indiranagar, i got my manza door pads done in black leather and the job was pretty good. You can check with them if they can do up the door trims in your car. I had got the 4 door pads for 4k bucks last year.
Old 21st February 2012, 11:11   #24
jeeva's Avatar
Thanked: 527 Times
AFAIK, type II and III Esteems do not have the AC vents on the front door trim.
All you need, is to get hold of a good upholstery guy and get the pads refurbished, if those fragile clips and stuff inside are in good condition. If not, they will rattle away to hell, though you can screw them into place.
Plan a trip to the infamous Shivajinagar gujri, you may find some good ones there.
jeeva is offline   (1) Thanks Reply With Quote
Old 21st February 2012, 16:25   #25
Thanked: 156 Times
Dude. You can find each n every part in mumbai cst road. Just for example i had lost one of the dash speakercover, found it at cst road!!!!!
yogisays0909 is offline   Reply With Quote
Old 22nd February 2012, 15:23   #26
Thanked: 368 Times
Talked to Karlson couple of weeks back, they promised to get back to me with details. Never heard back. When talking to them, felt that they are not interested.
Sure, will try Shivajinagar.
Thanks yogisays0909. Will plan during one of my trips to Mumbai.
Old 23rd February 2012, 11:17   #27
Thanked: 156 Times
By the way i have seen here in couple of old esteems and M800s, custom made door trims are being made by the seat wala's. its made of thin metal sheet and covered with good quality cover and then laminated to avoid wearout. looks too good, probably after the rains even i am planning to go for it. They are charging appx 3K for this.
Old 17th April 2012, 21:26   #28
greenhorn's Avatar
Thanked: 1,309 Times
I had my door trim replaced at a car upholstery shop. cost me 600/door.
I was initially planning to get some MB Tex ish material, but was talked out it by the guy because he said it would not stick as well. The material he recommended was the old school stuff - all velvety. Didnt want it on my car. Finally found something at the godown of the upholstery material shop that was more like the OEM fabric, and had three layers (a base, then some foam, and then the cloth)
it was cut to shape, then rubber adhesive applied to where my old pads used to be , then stuck, and the edges tucked in using the round edge of a hacksaw while applying some extra glue to the edges to make sure they stick
The process for those of you who are curious and wouldn't mind DIYing ( I probably would the next time if i had to !)
Replacing a worn out Door Panel / Trim-img_20120417_131156.jpg
Replacing a worn out Door Panel / Trim-img_20120417_131205.jpg
Replacing a worn out Door Panel / Trim-img_20120417_131212.jpg
Replacing a worn out Door Panel / Trim-img_20120417_131540.jpg
Replacing a worn out Door Panel / Trim-img_20120417_131230.jpg
Old 17th April 2012, 21:31   #29
dhanushs's Avatar
Thanked: 4,054 Times
^^ greenhorn, 600/door sounds a bit steep!.
It should probably cost just half of it. Did you shop around?
Old 17th April 2012, 21:40   #30
greenhorn's Avatar
yes, and I got pretty much the same rate. I had first asked a rather large ICE shop and they quoted 2500 for the whole thing and wanted me to leave the car there for 3 days (!)
Then I went to another part of town where there all all these large rexine/upholstery material dealers, and one of them pointed me to this small shop which offered a quote of 600 per door and said they would do it in 3 hours. I got them to do some floor matting and cut some rubber carpets as floormats (the same stuff jkdas uses in his truck) - very soft on the feet, and do a great job of damping too.
Anyway, the rest of the quotes they gave me seemed reasonable, time was an important factor, and I was running out of places to look, so i got it done there
DIY: Replacing the worn-out rubber buttons of a Keyless Entry Remote raveesh_k DIY - Do it yourself 25 10th December 2017 08:08
XUV500 DIY: Replacing worn-out Key Fob cover Shai100 DIY - Do it yourself 11 11th November 2016 14:57
What to do with spare tyre while replacing all other four worn tyres? androdev Tyre & Alloy wheel Section 22 6th July 2016 17:45
opening the door panel in optra beanstalk_230 In-Car Entertainment 8 20th September 2007 19:44
