Old 19th April 2012, 18:28   #31
aditbelw's Avatar
Thanked: 40 Times
Default Re: Replacing a worn out Door Panel / Trim
Originally Posted by 500ContyCruiser View Post
Seats around 6k. Still some more work is pending for pads.
Checked with RNS, Yeshwantpur, Bangalore, they are quoting ~5500/- for single door!!
Great Job , indeed. Could you please give more information on the costs incurred for Doors pads, and where did you get them from? I'd like to get something done to my aging esteem type 1 too.
aditbelw is offline   Reply With Quote
Old 17th May 2012, 23:50   #32
500ContyCruiser's Avatar
Thanked: 402 Times
Sorry.. Had been off and just seeing your message.
Did not get the door pads repaired. Instead thinking of changing car and buying some diesel vehicle.
500ContyCruiser is offline   Reply With Quote
Old 18th November 2012, 11:59   #33
Thanked: 402 Times
Mods: Not sure if this thread can be closed or deleted. Please do the appropriate!
I have sold my car and will no longer be updating this thread.
Old 17th July 2014, 15:58   #34
S_U_N's Avatar
Thanked: 383 Times
I hope this thread is still alive. I posted my query in the Zen modifications thread, but then I realized this thread is more appropriate.
There are clips behind the door panel - hope I am using the correct term - which are missing.
http://www.team-bhp.com/forum/modifi...ml#post3480862 (The Zen Modifications Thread)
What is the best course of action?
I don't mind changing the door trim from the default gray to something more lively since the entire car has been restored and repainted as well.
Looking for some ideas and suggestions.
S_U_N is offline   Reply With Quote
Old 17th July 2014, 16:26   #35
saket77's Avatar
Thanked: 5,051 Times
I
They are available at Alibaba.com: http://www.alibaba.com/showroom/auto-trim-clips.html
However, getting those clips should not be issue at MASS or other auto accessories store I guess. They are called plastic trim clips. In fact, the clips may be salvaged from worn off door pads of any other car too.
Also, have a look at them, this may help: http://www.indiamart.com/asiarubber-plastics/
saket77 is offline   (1) Thanks Reply With Quote
Old 17th July 2014, 16:36   #36
S_U_N's Avatar
Thanked: 383 Times
I think the terms used are confusing. The plastic part in the picture I uploaded is not the problem. There is a metallic strip below that with variable height. Those strips are somehow glued to the panel back side. Getting those is the problem.
Old 17th July 2014, 16:40   #37
saket77's Avatar
Fabricate them with tin. Should be easy. Clean the surfaces and stick with Araldite. Will outlast the door pads themselves. As your car is with the tinkerer itself, it should be an easy adventure to indulge into.
Another idea: Slowly take off the grey rexine part from the door pads from the edges where the door pads need to be clipped. Put across screws and fix the pads in place. Cover the edges back with rexine and push it inside or stick them back.
saket77 is offline   Reply With Quote
Old 17th July 2014, 17:05   #38
S_U_N's Avatar
Thanked: 383 Times
Unfortunately the workshop team is not that innovative. I will prefer to take the car back once it is operational and get this done elsewhere.
XUV500 DIY: Replacing worn-out Key Fob cover Shai100 DIY - Do it yourself 12 8th May 2018 19:15
DIY: Replacing the worn-out rubber buttons of a Keyless Entry Remote raveesh_k DIY - Do it yourself 25 10th December 2017 08:08
What to do with spare tyre while replacing all other four worn tyres? androdev Tyre & Alloy wheel Section 22 6th July 2016 17:45
opening the door panel in optra beanstalk_230 In-Car Entertainment 8 20th September 2007 19:44
