Old 7th February 2012, 18:50   #16
Thanked: 3,508 Times
Default Re: Lowered the steering wheel tilt of my Maruti A-Star!
Originally Posted by vinair View Post
Though its a great DIY exercise, is it a good practice to mend the factory settings? What if the steering fails to collapse in the event of an head on collision? Other than cosmetic modifications, doing any other component modification by yourself is inviting trouble on a long run (unless you are an expert and have the right tools and understand the mechanical tolerances). This is my view
Collapsing is done by the collapsible steering column. Doesnt matter if the steering column is moved at the base by a few MMs down. There are factory tilt steerings that can be moved up or down and the movement is controllable by a lever which will lock it at a position. In my car there is no lever, but the steering column is tiltable, there is a pivoting mechanism which allows for this movement if it had a lever. Btw, export versions of my car have tilt-adjustable steering.
This is not a cosmetic modification but a functional one, this is as important as having adjustable seats. I don't foresee any trouble wrt the steering system other than its normal wear and tear. There is universal joint an it allows for smooth rotations and the angle is not that acute to cause binding.
My OHC VTEC - Lowered, Stiffened, FFE'd and Now with ITBs!! pranavt Modifications & Accessories 227 13th August 2012 16:46
Steering Wheel Hub Adaptor for A-Star Sankar Modifications & Accessories 23 25th October 2011 18:19
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
What Indian cars come with tilt steering ? sakharamcool The Indian Car Scene 32 27th March 2009 11:36
What are the Pros & Cons of A Tilt Steering? bharath.kan The Indian Car Scene 21 29th February 2008 21:53
