Closed Thread
Old 20th February 2012, 21:49   #1
gopz's Avatar
Default Is it possible to retrofit Passenger Airbag in a Toyota Innova?
As title please, I'd like to know if its possible to fit a passenger airbag in a GX model (which comes only with driver side airbag)?
gopz is offline
Old 21st February 2012, 10:36   #2
cooldude1988765's Avatar
Thanked: 108 Times
Default Re: Is it possible to retrofit Passenger Airbag in a Toyota Innova?
As far as i know, it is not possible to retrofit airbags, abs, tcs ebd etc. It has to be provided by the manufacturer.
cooldude1988765 is offline   (1) Thanks
Old 21st February 2012, 10:58   #3
revintup's Avatar
Thanked: 373 Times
Dont think so. Even if it is, am sure it will cost more than the top end innova.
If by some remote chance, it is possible,and cheaply so, pay only after making sure its working properly
revintup is offline   (2) Thanks
Old 21st February 2012, 11:20   #4
sushrutha's Avatar
Thanked: 325 Times
Airbags & ABS ... No Retrofitting/After market fitting pls.
Better to have them equipped as OEM.
You can retrofit them(ofcourse with major modifications), but they may not work the same they are intent to.
sushrutha is offline   (1) Thanks
Old 21st February 2012, 12:43   #5
vinair's Avatar
Thanked: 976 Times
Even if you can retrofit one, I guess you would end up testing the device with your life!
vinair is offline   (1) Thanks
Old 21st February 2012, 15:43   #6
gopz's Avatar
Thanks all. So is it better to invest 2L more for the top end Innova, assuming that airbags are absolutely necessary and effectively saves life?
gopz is offline
Old 21st February 2012, 15:52   #7
libranof1987's Avatar
Thanked: 4,226 Times
Yes.
For Airbags, you'd need to change/install a lot of things - a dash to incorporate the passenger Airbag, crash sensors, wiring, probably a change in ECU etc.
That would be playing around too much with stock condition.
It's best you go for the top-end variant.
libranof1987 is offline   (1) Thanks
Old 21st February 2012, 16:06   #8
gopz's Avatar
Someone said Airbags do more harm than good, is that so?
Can anyone confirm if Airbags can harm?
Thanks in advance
gopz is offline
Old 21st February 2012, 16:12   #9
Yea, only financial harm. But then they makes up for it in countless way by saving lives.
Have heard that someone who's had a close call with Airbags does have a few bruises on the face though - understandable given the force with which they cushion your face in case of an impact.
libranof1987 is offline   (2) Thanks
Old 21st February 2012, 16:40   #10
smartcat's Avatar
Thanked: 14,927 Times
It's probably safer to let the passenger hold a big pillow than let somebody retrofit an airbag to the car!
Thanks in advance
If the passenger is not wearing seatbelts, airbag deployment can apparently cause more harm than good.
Small children could even be killed if the airbag deploys. So that's why kids should be at the back. In some cars (like i20), you can switch off the passenger airbag though.
smartcat is online now   (2) Thanks
Old 21st February 2012, 16:57   #11
mayankjha1806's Avatar
Thanked: 821 Times
Yes, The intensity with which Airbags inflate, is very rapid and its almost like an explosion inside the airbag to make it inflate in 60-80 milliseconds after the first impact, also the passenger side airbags are larger (because the dashboard is further away) and hence needs more gas to inflate, and hence has stronger more vigorous explosion like mechanism.
This intensity of inflation (almost like explosive) can get someone injured especially kids, hence the rule to always put kids at the back.
mayankjha1806 is offline   (1) Thanks
Old 21st February 2012, 17:03   #12
bblost's Avatar
Thanked: 6,980 Times
And in an age/weight appropriate child seat.
bblost is offline   (2) Thanks
Old 21st February 2012, 18:12   #13
noopster's Avatar
Thanked: 9,599 Times
Taking this to the next logical level, what about a vehicle like the Force One where even the highest trim variant lacks airbags and ABS? Is retrofitting an option here or is it, as smartcat suggests, a case of the solution being worse than the problem?
noopster is offline   (1) Thanks
Old 21st February 2012, 23:46   #14
scopriobharath's Avatar
Thanked: 1,259 Times
Well, Technically We can fit them as its nothing but an impact sensor that operates the Airbag.
In an Innova i would say maybe but It is not recommended though as it may not perform to its best capability when needed. I am sure the service centers would have put together a head-on collision Innova V, where they would have to replace the dash / sensors /Airbag etc. The same parts need to be added for E / G etc.
In a Force One - just steer clear and even if someone offers to fit - it would just burn your pocket.
scopriobharath is offline   (1) Thanks
Old 22nd February 2012, 10:43   #15
rjstyles69's Avatar
Thanked: 795 Times
Easier said than done, the ECU should support all this. An impact/crash sensor alone wont do the trick here, from what I have read most airbag systems would have a safety/arming sensors which are located at the passenger side,usually in the dash board or seat or airbag control module.
This safety sensor should ensure that the airbag shouldn't deploy unless a certain amount of deceleration/impact is experienced. I am sure the wiring alone will be a big thing to achieve with the kind of infrastructure and expertize we have in india.
rjstyles69 is offline   (2) Thanks
Closed Thread
Replacing our 2 lakh km Innova - Toyota Innova Crysta vs Ford Endeavour icyspikey SUVs, MUVs & 4x4s 31 16th May 2017 18:48
Airbag Warning Light In Innova Lit Up: Update - Issue Resolved genesis Road Safety 19 27th October 2014 10:54
Passenger-side Airbag switch? drsnt Road Safety 30 6th April 2012 08:51
Liquid dripping into front passenger area of Innova oldmobile Technical Stuff 0 26th December 2009 17:01
m800 AC retrofit and some questions eternalck Technical Stuff 86 29th June 2009 21:46
