Old 5th April 2006, 14:01   #1
caroholic1's Avatar
Thanked: 29 Times
Default Sunroof for Baleno
Hey guys i need your help. My friend has a 2005 sep Baleno VXI & wants to get a sun roof. We are considering the Webasto Sunroofs. What do you suggest? He should go for the outer sliding sunroof or any other? How much will it cost & somewhere in mind he has a doubt that after market sunroofs are not that good. Is this true?
caroholic1 is offline   Reply With Quote
Old 5th April 2006, 14:10   #2
Rudra Sen's Avatar
Thanked: 4,288 Times
This is very much true. Check with autopsyche. If I remember right, he told me the same about after market sunroof. Water leakage is a common issue there.
Old 5th April 2006, 14:19   #3
v.tec's Avatar
Thanked: 16 Times
a friend just got a sunroof put on his corolla from autopsyche..the fitting and all is really good..you cant really say that its an aftersale accessory...but the only thing is that it wasnt fully electronic..we had to pull the shade back n forth
v.tec is offline   Reply With Quote
Old 5th April 2006, 14:41   #4
speedsatya's Avatar
Thanked: 712 Times
http://www.webastoindia.com/
this should help you clear all your doubts
speedsatya is offline   Reply With Quote
Old 5th April 2006, 14:46   #5
Thanked: 90 Times
Webasto are the Best, BUT cutting the roof and the fitting are the grey areas, because of which all the problems happen.
the fitter Has to be Perfect and Trained
scooby05 is offline   Reply With Quote
Old 5th April 2006, 15:43   #6
S@~+#0$#'s Avatar
Thanked: 37 Times
Webasto is a good choice amongst what is available here. Also, webasto comes OE in the Opel Astra Club and I have had no problems for the last 5 yrs in our Opel.
Very Important: Make sure it is fitted by a professional.
S@~+#0$# is offline   Reply With Quote
Old 5th April 2006, 15:52   #7
aZa
aZa's Avatar
Thanked: 17 Times
Webasto is OE on Hyundai and Maruti !! If its OE then its good i'm sure .. plus webasto is in NOIDA only
Old 5th April 2006, 19:21   #8
As several people have pointed out, apart from the build quality of the sun-roof, its the precision and quality of the fitting that makes the difference... Won't do any good having a 50K sunroof with the side leaking.
Ensure you talk to couple of customers from wherever you are getting your sunroof installed. Webasto would be a good choice as worldwide, they are OE on many luxury models as well.
-Regards,
Sumit
sumitsingh is offline   Reply With Quote
Old 5th April 2006, 21:24   #9
karthik247's Avatar
Thanked: 16 Times
I've got the Webasto sunroof fitted on my car before I took delivery of it. Its been over an year now and, touchwood, havent had any probs so far
karthik247 is offline   Reply With Quote
Old 5th April 2006, 21:40   #10
autopsyche's Avatar
Thanked: 15 Times
Webasto are the only decent ones around, atleast they cover leakages and all under the two year warranty so its a pretty fair deal.
The outer sliding one Skyslider 300 Classic large is the most economical option (which we just fitted in impact's corolla). and yes the shade has to be manually used not just in this one but also in the top of the line sunroofs, its only the glass thats automatic, the rolling/sliding shades are always manual.
Arush
autopsyche is offline   Reply With Quote
Old 5th April 2006, 21:46   #11
Sahil's Avatar
Thanked: 2,712 Times
Talkin from personal experience ...I have an showroom fitted sun-roof in my accord and i have had several problems.......I wouldnt trust any other company but Webasto,fitted by trained professional...will be a lil more expensive but its worth it. Since your in Delhi Arush can do it for you, if it leaks in the monsoons you go catch his throat haha
Old 5th April 2006, 21:46   #12
caroholic1's Avatar
Thanked: 29 Times
Hey Arush how much does it costs? & i'm suggesting him to go for 2 outer sliding sunroofs. They look damn kool
Old 5th April 2006, 23:54   #13
S. No. Sunroofs Customer Price including Labour charges
1 Pop Up 9200
2 Pop Up (Without Sunshade) 8500
3 Sky slider medium Mannual 21500
4 Sky slider M EL 27500
5 Sky slider M SCU 29000
6 Hollandia 300 CL Large 39000
7 Hollandia 300L Rollo DLX 41000
8 Hollandia 700 89000
9 FreeDome 146000
10 Hollandia 400 Black (Deluxe) 74500
Chevy is offline   Reply With Quote
Old 6th April 2006, 01:20   #14
autopsyche's Avatar
Thanked: 15 Times
Thanks chevy those are the correct prices, caroholic you can put two in a baleno as well. There is a discontinued model from the webasto range which was the Hollandia 500 which had dual sunroofs, infact we did put it on a baleno and it did look very cool!
Old 6th April 2006, 10:12   #15
caroholic1's Avatar
Thanked: 29 Times
Hey guys saw this pic on webasto site. Looks realy cool.
After-market Sunroof! sparco Modifications & Accessories 37 22nd December 2011 22:08
Sunroof in a zen jesal Modifications & Accessories 7 10th September 2009 16:30
Maruti Genuine Accessory - Swift Sunroof & More Technocrat Modifications & Accessories 44 8th December 2008 15:06
Sunroof for Swift jusgetgoing Modifications & Accessories 8 8th March 2007 07:17
Sunroof for my opel corsa sail please! stevie Modifications & Accessories 16 30th June 2006 17:23
