Old 1st April 2013, 16:22   #196
Originally Posted by Racedynamics View Post
We're in no position to comment. You should contact them directly.
Ok. I understand. So I will contact them. Can guide me as to what I should look for in a box. I mean I know I have to ask about performance increase and all, but is there any other key point through which I can judge there box or basically anything else one should enquire before buying a tunning box.
I ask this question to you as you people are the experts at this.
P.S. My main motive for putting a box is performance and the fact that I can turn it on and off. Otherwise I would have gone for a remap.
Thanks for the replies.
varunsonu is offline   Reply With Quote
Old 1st April 2013, 17:13   #197
Safari_Beast's Avatar
Thanked: 196 Times
Default Re: Racedynamics: DieselTronic Tuning Box
Hello Racedynamics
I was thinking of getting RD box for new swift ZDi , just needed inputs about for how many ksm testing has been done on new swift . Also there is no review on teambhp regarding the drive of new swift fitted with dieseltronic box . So it would be helpful , if you can put up a review of sort so that we can know what type of gains we can expect on new swift .
Safari_Beast is offline   Reply With Quote
Old 1st April 2013, 19:27   #198
Racedynamics's Avatar
Thanked: 437 Times
1. Try to locate a kit with water resistant automotive grade connectors
and enclosure. Some of them do with computer type 9-pin connectors that
are not good enough, whether gold plated or not. If the same manufacturer gives you either option, go with the automotive grade option. It is worth the added cost.
2. For petrol engines, ensure air-fuel ratio and ignition are set at optimum values. Unlike diesels where air-fuel ratio is not too critical, on petrols it is asking for trouble. Preferably look for a map that is calibrated for and tested on a car made in India and not a generic one.
Racedynamics is offline   (1) Thanks Reply With Quote
Old 11th April 2013, 11:12   #199
Hello RD, are the maps same for Vento and Rapid?
Mendocino is offline   Reply With Quote
Old 12th April 2013, 11:08   #200
Thanked: 437 Times
Yes, the maps for the Vento and Rapid are the same.
Old 23rd April 2013, 17:27   #201
jkdas's Avatar
Thanked: 1,424 Times
Yes, it is compatible with the 2.2 Safari. Please have a look at the first post of this thread for approximate performance gains. The extra power/torque is always kept within manufacturer tolerances.
No plug and play options available for petrol engines as of now.
Missed this thread.
Is it the single channel or dual for Safari?
Is there anyway I can test this at Trivandrum?
What would be the price for the box?
Old 24th April 2013, 12:11   #202
aks_karthik's Avatar
Thanked: 215 Times
Is Dual Channel Dieseltronic available for XUV5OO?
Please share the price and improvement maps if any for Both Power & torque against RPM.
Where can i try/buy it in Chennai?
aks_karthik is offline   Reply With Quote
Old 24th April 2013, 12:26   #203
Arch-Angel's Avatar
Thanked: 277 Times
Hi RD,
What is the cost of a dual channel box(if applicable) for the ford figo? If not, what is the cost of the single channel box?
Arch-Angel is offline   Reply With Quote
Old 24th April 2013, 13:40   #204
satya180's Avatar
Thanked: 208 Times
@RaceDynamics: How soon can we expect a dual channel box for the Vento?
satya180 is offline   Reply With Quote
Old 24th April 2013, 19:53   #205
Rajain's Avatar
Thanked: 918 Times
Hi
I have had a RD box in my Ertiga for the last 12500-13000 kms. I had installed one within a couple of hundred kms of purchase. No issues so far.
I did a trip through KA/MH/GJ and RJ - total of 3800 or so kms with no problems. the TL is available at http://www.team-bhp.com/forum/travel...uv-ertiga.html (3,800 kms across 4 States in 9 Days - A Family Sojourn in 'LUV' Ertiga)
I have almost always kept the RD at P1 mode while on the highway. In the city I take E but I like the P1 mode.
A question to RD - Can you confirm the RD box does not increase stress levels on the engine parts including but not limited to the turbo? In my driving I rarely exceed speeds of 120 kmph but keep a steady 90-110 kmph and have done Bangalore-Mumbai in a 14 hr drive.
Appreciate your inputs.
Rajain is offline   Reply With Quote
Old 3rd May 2013, 15:50   #206
Thanked: 437 Times
Vento/Rapid Dual channel units are in the final stages of testing and should be out very soon.
Originally Posted by Rajain View Post
Hi
There is no increase in stress levels of any engine component.
Old 3rd May 2013, 16:41   #207
Thanked: 215 Times
My Query Below
Old 6th May 2013, 15:29   #208
Thanked: 437 Times
Hello, the single channel is applicable for the XUV500.
Racedynamics is offline   Reply With Quote
Old 6th May 2013, 17:54   #209
MAS
MAS's Avatar
Thanked: 1,206 Times
Hi RD, my query:
I own a 2011 Endeavour 4 x 4 AT.
The Endeavour shifts into top gear at exactly 85 kmph true speed (as seen on the GPS). The last-but-one gear (before the top gear) engages at around 50 kmph and due to this huge 35 kmph gap (50 to 85 kmph), it slows down the progress after a quick dash to 50 kmph.
On the highway, this late top gear also leads to higher fuel consumption lowering the mileage of the SUV.
I want to know if the DieselTronic will help me improve driveability by shifting to top gear at a lower speed (say 75 kmph)
MAS is offline   Reply With Quote
Old 7th May 2013, 18:22   #210
Thanked: 215 Times
When can we expect Dual Channel Kit for XUV 5OO?
Any idea to release it in near future?
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Fiat Punto with RaceDynamics DieselTronic Dual Channel. EDIT: 110 hp, 265 Nm CrAzY dRiVeR Modifications & Accessories 94 13th January 2017 09:51
Racedynamics DieselTRONIC - 2010 Ford Figo 1.4 icyspikey Modifications & Accessories 25 6th July 2016 19:43
