Old 5th June 2014, 22:21   #376
Thanked: 93 Times
Default Re: Racedynamics: DieselTronic Tuning Box
Originally Posted by Voyager-1 View Post
they offered to fit the box in my car for a test drive. Since it takes only 15 minutes for installation, they are fine with removing the box if I am not satisfied with it.
Did you find time to take a TD ? If yes, please share your experience.
Chitta Pradhan is offline   Reply With Quote
Old 5th June 2014, 22:35   #377
Thanked: 162 Times
Not yet. For the Verna, the 800 to 1500 RPM is the 'dead zone' and the turbo wakes up only post 1500 RPM. I am still debating internally about buying the box vs living with the 'dead zone'. Also, taking a TD and not buying it would be very hard for the heart.
Voyager-1 is offline   Reply With Quote
Old 21st July 2014, 11:59   #378
rshanker's Avatar
Thanked: 283 Times
OK ~I've got a weird problem on my 75HP Punto. I've been running the Single channel RD Box for a couple of months without any issues. I had to hand in the car for the regular 60K service ~when I removed the box from the connector & started up, I got a "Check Engine" warning on the MID. Is there any additional 'thing' I should be doing?
rshanker is offline   Reply With Quote
Old 22nd July 2014, 11:09   #379
Racedynamics's Avatar
Thanked: 437 Times
Hello,
Did you remove just the box from the connector or the entire wiring harness altogether? Unplugging only the box and attempting to start the engine without removing the entire Dieseltronic wiring harness will throw up an error. Please contact us directly as soon as possible and we will guide you to professionals who can disconnect the box before you hand your car in for service.
RD
Racedynamics is offline   (1) Thanks Reply With Quote
Old 23rd July 2014, 08:46   #380
rshanker's Avatar
Thanked: 283 Times
Thanks~ That explains it! Do you have anyone in Coimbatore who can remove & re-attach the box?
Old 23rd July 2014, 10:36   #381
Thanked: 437 Times
Yes, as mentioned earlier do contact us directly using the support number printed on the box.
RD
Old 23rd July 2014, 10:50   #382
Thanked: 50 Times
Hello RD,
Is there a tuning box available for 2009 Chevrolet Magnum 2.0 TCDi. If available what power gains can I expect?
If possible ,may I know the cost also?
Anish
anish5225 is offline   Reply With Quote
Old 26th July 2014, 13:12   #383
Thanked: 437 Times
Originally Posted by anish5225 View Post
Hello RD,
Anish
Hi Anish,
The box is compatible with the Magnum. We now have a Dyno in house and we will have actual figures shortly.
RD
Old 3rd August 2014, 19:06   #384
Hi RD,
I have Maruti Suzuki SX4 ZXI (Petrol) Automatic 2009 Model.
Which RD box will support this?
In Hyderabad, where can I purchase and get it fixed? (DIY possible?)
Arun
arunaXT is offline   Reply With Quote
Old 14th August 2014, 17:00   #385
Thanked: 162 Times
I went ahead and bought the Single Channel box for my Fluidic Verna. I had covered a 1000 km road trip and enough city kms in the last 3 weeks to comment on the box.
In short, it does what it says and I feel my money is well spent.
I went directly to their head office in Bangalore. The box was fitted in 10 minutes and I took a 30 minute test drive. As claimed, the RPM needle rises faster in P1 and P2, so the engine spends less time in the 800-1500 turbo lag zone. You could up-shift sooner, since the engine pulls better at lower RPMs.
During my test drive, because of the city traffic, I intially could not feel the difference between stock and P1. But on my 30 km way back home, I started feeling the difference.
Feedback for P2 mode from my 1000 km highway trip:
To simply put, with P2, my car turned into a 6th gear automatic. I could accelerate in 6th gear from 60 kmph without feeling the turbo lag. And, I could reach my cruising speed faster without changing gears. My average speed on 4-laned highways improved considerably (from 60 to 70 kmph) without any additional driving stress. I was surprised to see that even with P2 and hard driving, there is improvement in the MID mileage. Earlier, with similar hard driving, it used to be around to 19.xx kmpl, but now it did not go below 22 kmpl.
Feedback for P1 mode within city:
I use only P1 within city. The number of down-shifts have reduced considerably and this reduces the stress. The car pulls well in 2nd gear when crossing speed breakers. The 3rd gear, which is the most used gear within city, now has a wider usable RPM range. The MID mileage is showing a 1.5 to 2 kmpl improvement (from 14.xx to 16.xx) for my routine routes.
Never drove in the E mode (except on day 1), and it feels as if your car is suddenly loaded with 5 people and luggage.
Old 14th August 2014, 21:16   #386
Thanked: 93 Times
Thank you so much for your valuable feedback. It seems that you are the only Fluidic owner using this box or even remap in this forum. Your experience is tempting enough to go for one.
I have few queries-
- Here I have a HASS. How easy/difficult will it be for them to install the box?
- Do they have boxes other than Single channel box for Verna?
- Do the remote wireless? Does the box remember the mode the car is switched off with?
- Have you measured the FE on TFM? If MID is showing around 2 kmpl improvement, actual FE increase should be round about that mark too. A huge bonus indeed.
Old 14th August 2014, 22:16   #387
Thanked: 162 Times
My responses inline.
You cannot install this box in a HASS as it would void the warranty. I suggest you speak to Racedynamics about where you can get this installed near your place.
No, for Verna there is only a single channel box.
Yes, the box retains the mode after switching off/on the engine.
No, I didn't measure the FE on TFM. All measurements are from MID and with A/C always on.
Old 14th August 2014, 22:41   #388
Thanked: 93 Times
My car is out of warranty now. So no worry for me wrt void of warranty. HASS people are very well known to me & will fully cooperate me for the installation. Just want to know if it can be easily installed or not with the diagrams or stuffs like that which may be coming with the pack.
Old 14th August 2014, 22:48   #389
Thanked: 162 Times
It is a DIY job, if you have the basic tools like Size 10 spanner (for the battery terminal) and some straps to keep the wires in place. HASS or any equally competent mechanic can install this.
Voyager-1 is offline   (1) Thanks Reply With Quote
Old 14th August 2014, 22:54   #390
Arjun Reddy's Avatar
Thanked: 1,117 Times
Chitta,RD Dieseltronics is plug and play. It Truely is a magic box. The performance you get is surreal. I am onto something with RD shortly for my Neo Elantra. Watch this space guys. Right Karthik?
Sent from my iPhone using Team-BHP
Arjun Reddy is offline   (1) Thanks Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Fiat Punto with RaceDynamics DieselTronic Dual Channel. EDIT: 110 hp, 265 Nm CrAzY dRiVeR Modifications & Accessories 94 13th January 2017 09:51
Racedynamics DieselTRONIC - 2010 Ford Figo 1.4 icyspikey Modifications & Accessories 25 6th July 2016 19:43
