Old 13th February 2009, 11:51   #181
UniqueMods's Avatar
Thanked: 50 Times
Originally Posted by aditya.86 View Post
@yatin
From the pics of your filter looks like the engine will be sucking in a lot of hot air. I was facing problems before with similar install and after i changed the piping and position that is away from above the engine there has been considerable difference in the running.
Adi
Can you post a pic of your filter position?
I too have the same setup, as i couldn't find any other place to fit it.
The filter is too large to fit behind the headlight and would hit the block or the power steering oil box.
UM
UniqueMods is offline   Reply With Quote
Old 13th February 2009, 12:21   #182
yatinchoubal's Avatar
@yatin
Adi
Well, I doubt on having any problem to the engine as yet. Infact after installing the filter, the temperature has decreased, and is very evident on the heat temperature range (on speedo).
I also noticed a rise in my mileage, after installing.
Well but would definetly be interested to know how you have installed. Post a snap of your install.
Also could you mention what problem were you facing ?
yatinchoubal is offline   Reply With Quote
Old 20th February 2009, 17:50   #183
Shakensoul's Avatar
Thanked: 222 Times
Originally Posted by aZa View Post
Santro like many other new cars comes with Dual Ignition Coil Systems (DIS) Due to this the normal 4 Cylinder setting on a aftermarket tacho shows only half the RPM reading.
The solution
1. A tachometer with 2 Cylinder setting, Very easy to connect and takes the rpm from 1 coil only.
2. Autometer/sunpro RPM Adapter, Using this the 4 cylinder setting will show the correct RPM
Harsh and i, both have SUNPRO tacho fitted onto our Xing's and it rocks
For more info check out Sunpro®
cheers
Hey tacho gurus, please enlighten me.
I wanted to fit a tacho in a WagonR which I believe has a DIS system, so I am getting a Sunpro CP7905 which can be set to two cylinders. Can the wiring be done DIY way ? This is the picture of a wagonR engine bay with the ignition coil. Where should the connection be made ?
Shakensoul is offline   Reply With Quote
Old 25th February 2009, 00:55   #184
aditya.86's Avatar
Thanked: 17 Times
There will not be any temperature decrease on the guage after installation of the filter. Once the engine reaches its optimum runnning temp the needle stays there.
There are a couple of dots on the temperature guage in between which the needle stays once the engine warms up.
Here is the way its installed in my car. Earlier it was installed the way as shown in your pic. Sometimes after long running i used to literally feel the engine running out of breadth and the air filter choking. After a halt it ll be back to normal.
After the change have not encountered such problems.
aditya.86 is offline   Reply With Quote
Old 25th February 2009, 00:57   #185
aditya.86's Avatar
Thanked: 17 Times
Mine is a non PS model and i think the position of my filter is the same place where the PS oil reservoir would have been. Not sure.
Old 25th February 2009, 10:55   #186
UniqueMods's Avatar
Thanked: 50 Times
I am yet to feel any difference in the performance when the car heats up on long runs. haven't faced this problem.
Yup, there is a oil can in place where your filter is fitted, that too with metal pipes, so cannot be moved easily.
plus i am not in favor of any mods which i cannot remove before the car goes for service as it is under warranty.
the reason i got this installation done in this way, is coz there is no other place to fit the filter.
two changes i made is that the horn and the plastic plate that come in front of the filter is removed, to allow maximum fresh air flow in to the filter form the front grill.
also a flexible shroud that covers the bottom (between the filter and exhaust headers) and right side (between filter and radiator fan), to block hot air from both.
UM
Old 25th February 2009, 11:57   #187
jassi's Avatar
Thanked: 11 Times
Smile
heres how mine is fitted and its a cold air intake (K&N rc5052) which takes air from the front grill. I have no issues.
jassi is offline   Reply With Quote
Old 25th February 2009, 12:05   #188
aditya.86's Avatar
Thanked: 17 Times
@jassi
Are you running an FFE? How good is it after the cold air intake kit?
Old 25th February 2009, 12:11   #189
jassi's Avatar
Thanked: 11 Times
Smile
@jassi
yes I am running an FFE also and it was done by Raj Hingorani and Shabbir in bangy
Combined the CAI and FFE are the best you can do on a santro. Anything more is just a waste of time as hyundai cars are engineered very close to the limits unlike the hondas
now that i think of it, I do have one issue - the CAI pipe going towards grill has a wire going over it and that is rubbing against it. Anyone knows how that can be fixed. The damage can be seen in pic above, where the black color is fading at the point of contact
Old 25th February 2009, 12:20   #190
Dude, check out the difference between PS and NON PS..
theres no space for a set up like yours. Also somehow, my AC pipe, seems to be at a height that yours..
Old 25th February 2009, 16:39   #191
aditya.86's Avatar
Thanked: 17 Times
Yes i noticed that the AC pipe on yours is at a comparatively higher level. Also due to the PS oil reservoir you cannot place the filter there.
For me i do not have any issues like that.
Old 25th February 2009, 16:41   #192
aditya.86's Avatar
Thanked: 17 Times
How is the performance of the car with the raj headers? I have heard that he is supposed to be really good. I am running an FFE fabricated by Leela Auto House, Coimbatore.
Old 25th February 2009, 17:04   #193
jassi's Avatar
Thanked: 11 Times
Smile
it is pretty torqy with the often wheel spin going from 1st to 2nd. Acceleration have significantly improved and so have 0-100 times. Also my top speed went up to 155 (i think 160kmph) on GQ highway and i got to that speed much faster than my earlier trips.
Edit - Or maybe i am traveling a lot in the direction of wind these days :-)
Old 25th February 2009, 17:18   #194
aditya.86's Avatar
Thanked: 17 Times
Good to hear that. I have also observed the same just like you did and the car's hitting 170 on the speedo without any constraints.
Would a fuel pressure regulator be of any help to this car?
Old 25th February 2009, 17:24   #195
jassi's Avatar
Thanked: 11 Times
Smile
even with the 185 section tires, i would not be comfy hitting 170 on a santro but i did have plenty of throttle left at 160, i think i chickened out
as for fuel pressure regulator, i don't think i plan to squeeze any more performance out of this baby !! Let me know if it works out for you.
My Skoda Yeti - DIYs, OE Upgrades & Custom Mods. UPDATE: Park Assist video on Page 8 ajaypjayaraj DIY - Do it yourself 188 4th February 2018 17:01
Fiat Linea T-Jet : LED Mods / Upgrades ZBlue Modifications & Accessories 24 8th January 2017 02:36
Fiat Linea and Punto to get improvements and upgrades sidindica The Indian Car Scene 276 13th July 2010 23:03
Alloy Wheels and Tyre Upgrades for my Ford Fusion TDCi NIP Tyre & Alloy wheel Section 65 27th May 2010 17:04
Mods for Civic Vs Mods for Laura redsfx Modifications & Accessories 15 19th November 2007 21:01
