Old 11th April 2006, 10:56   #16
Godfather's Avatar
Thanked: 65 Times
Originally Posted by viper
If you want to fit 175/185 I would recommend alloy wheels as the original are too narrow. You can use 175 on stock safely but not recommend if you drive on bad roads due to ballooning whereby making the sidewall prone to cuts from stones etc.
Viper
very true..
My car is only for home use.. basicaly will be driven in city only.. but i will anyways upgrade to rims maybe next month.. still have not found a good design yet..
Godfather is offline   Reply With Quote
Old 11th April 2006, 11:19   #17
aZa
aZa's Avatar
Thanked: 17 Times
185 fits ?!?? ummm now my tyre dealer told me that it wont thats why i got 175/60/13 with 4+4mm spacers upfront. And yes 175 on stock rims does balloon up but not to an uncomfortable size
Old 11th April 2006, 11:20   #18
rareone's Avatar
Thanked: 11 Times
Originally Posted by aZa
Yes guys I wanna see the pic for the conical filter too.
Apart from that Rareone tell us more bout the before and after effects of the mods u've done namely
3. Sports Heavy Duty Springs for Rear Tyres
4. K&N Universal Replacement Filter
5. Automech Free Flow Exhaust
6. NGK Spark Plugs with Wiring Kit (Goin 2 put very soon)
and how much did it cost yu ?!?
3. Sports Heavy Duty Springs for Rear Tyres - 1500/-
4. K&N Universal Replacement Filter - 3700/-
5. Automech Free Flow Exhaust - 9000/-
6. NGK Spark Plugs with Wiring Kit (Goin 2 put very soon) - 2700/- without wiring kit
rareone is offline   Reply With Quote
Old 11th April 2006, 11:45   #19
jkdas's Avatar
Thanked: 1,436 Times
More bumpy ride?
Old 11th April 2006, 11:49   #20
Godfather's Avatar
Thanked: 65 Times
you put spacers for a 175/60/13 on a santro... why???? its not needed at all..
Old 11th April 2006, 11:50   #21
rareone's Avatar
Thanked: 11 Times
JKdas
Its not at all a Bumpy Ride. Coz the springs are stiff.
And i had 2 install it only coz of the upsize tyres used 2 touch the body of the car whn 3 people sitting behind.
This springs prevent the car 2 touch since thy r strong and a bit longer than the factory setup springs.
Old 11th April 2006, 13:13   #22
aZa
aZa's Avatar
Thanked: 17 Times
Yaar the tyre guy put it himself. I found out later when i was getting the Brake pads colored red. but i'm gonna take it out now and get them realigned.
@RareOne : The new stiff springs do they make any difference in high speed driving, cornering ??
Old 11th April 2006, 21:30   #23
rareone's Avatar
Thanked: 11 Times
According to me Spacers makes the handling difficult on high speed.
This is wat i came 2 knw from various people.
Old 11th April 2006, 22:42   #24
Samurai's Avatar
Thanked: 15,768 Times
Originally Posted by jkdas
Can you post some pix.
The Santro is still in Bangalore, may be once I pick it up.
Old 11th April 2006, 22:47   #25
Thanked: 13 Times
More bumpy ride?
Santro ride tends to be a bit bumpy in the rear to begin with !!
Jk-Das, what would your reason be for the springs causing a bumpy ride ? This is one thing i really dont like about santro !
Old 11th April 2006, 23:09   #26
Samurai's Avatar
Originally Posted by rareone
I have added few mods on my Santro from which i am totally Satisfied :
1. Tyres Michelin Upsize (i dont kwn which size exactly)
2. Aura Alloy Mags
3. Sports Heavy Duty Springs for Rear Tyres.
I think you didn't use the tire size calulator while upgrading. That explains why you needed item #3. In fact you may have major speedo errors.
Old 11th April 2006, 23:15   #27
aZa
aZa's Avatar
Thanked: 17 Times
Bout spacers ... i've driven my santro without spacers on stock rims + Potenza GIII. Well After the Alloys + Spacers + Potenzas, slow turns would feel a bit weird, but at higher speeds i felt the turn in's were firm are the car was more willing (prolly coz of the slightly wider base with the spacers) otherwise on expressways and all it feels better than before. but on slow lock to lock turns it sure does feel a bit weird as if i'm turning more than just the wheels
aZa is offline   (1) Thanks Reply With Quote
Old 12th April 2006, 11:41   #28
rareone's Avatar
Thanked: 11 Times
SO Aza
Finally Spacers are welcomed for Santro
or
A complete no no...
Old 12th April 2006, 11:54   #29
Godfather's Avatar
Thanked: 65 Times
SO Aza
or
A complete no no...
I would not recommend spacers for the Santro.. considering the body height i think it will be unstable during turns at 35 to 45kmph...
correct me if i am wrong..
Old 12th April 2006, 12:21   #30
aZa
aZa's Avatar
Thanked: 17 Times
Well its NOT that big an enhancement or the opposite. and since delhi has nice flyovers all around i've usually taken the off ramps from the flyovers at above 60kmph and there is no problem wat so ever. I think since wheel spacers increase the track it shud make it more stable. But i still wish i knew bout 185 tyres lol i wanted fatter rubber than 175 :( Guys i'll try to post some pix of these spacers
My Skoda Yeti - DIYs, OE Upgrades & Custom Mods. UPDATE: Park Assist video on Page 8 ajaypjayaraj DIY - Do it yourself 188 4th February 2018 17:01
Fiat Linea T-Jet : LED Mods / Upgrades ZBlue Modifications & Accessories 24 8th January 2017 02:36
Fiat Linea and Punto to get improvements and upgrades sidindica The Indian Car Scene 276 13th July 2010 23:03
Alloy Wheels and Tyre Upgrades for my Ford Fusion TDCi NIP Tyre & Alloy wheel Section 65 27th May 2010 17:04
Mods for Civic Vs Mods for Laura redsfx Modifications & Accessories 15 19th November 2007 21:01
