Old 21st June 2012, 23:11   #16
audioholic's Avatar
Thanked: 6,150 Times
Default Re: Remote Engine start system
Is it possible to wire such a system given the immobiliser present in modern cars? As far as my knowledge goes, unless the key with the transponder is present in the key fob, one cant start the car.
Or if this system is capable of bypassing the immobiliser setup? Both ways, personally I will prefer to stay away from such products. A running engine is the best help you can offer to a aspiring vehicle thief
audioholic is online now   Reply With Quote
Old 22nd June 2012, 18:13   #17
Thanked: 86 Times
Good Find Dr.Vikas. I used to have this in my Ford Expedition and was very useful in the Middle east to get the engine started and the climate control ac would make sure that you are at ease while entering into the car with outside temperature near to 50deg.Mine was an automatic and the vehicle will have the gear on PARK mode with the hand breaks on. So no confusion on the remote starting bit. With manual gear , one will have to have the gear in neutral and the handbrake on
jmvivek is offline   (1) Thanks Reply With Quote
Old 22nd June 2012, 18:26   #18
abdriver2000's Avatar
Thanked: 24 Times
It would be better if we could find something which comes with a programmable timer. For people who keep their cars parked for several weeks, it would be nice if the car could start and warm itself for 15 mins daily or weekly and then switch off.
abdriver2000 is offline   Reply With Quote
Old 22nd June 2012, 20:59   #19
Dr.Vikas's Avatar
Thanked: 47 Times
Glad to see the inputs with different views here.
Even I think, such a product of course if needed, should be present in the vehicles as a 'company-fit' only & not at all as an aftermarket fittings. A possible warranty issue could be another reason for that. The only thing I was looking for, is the significant 'usefulness' of it and practical 'demand' also! Bye,
Dr.Vikas is offline   Reply With Quote
Old 11th June 2017, 09:49   #20
Guys, Remote start means.. you have to lock your car in Nuetral. ~80% of Indian saftey and terrain, this is out of the question.
What if all the safety check points are cross checked by the system, like gear should be neutral and handbrake on.
Does the indian regulations allow remote car start ?
aryan.goyal is offline   Reply With Quote
What to do if remote key fob fails and vehicle is equipped with Start-Stop button? arjab Technical Stuff 33 3rd February 2018 22:39
Bike Security system with remote start. nikkibike Motorbikes 19 26th August 2014 03:38
DIY: Adding a Remote level control/ Bass remote to your Amplifier HimuraKenshin In-Car Entertainment 8 11th April 2012 16:59
Engine will not start...security system issue? theexister Technical Stuff 4 18th November 2008 15:22
Remote Car Start Subbu Modifications & Accessories 22 20th September 2007 10:13
