Old 19th September 2006, 14:21   #121
true spadival....... but you can't deny that they look 100% better...... cheers
bikirao is offline   Reply With Quote
Old 27th September 2006, 19:51   #122
memo45_m's Avatar
Thanked: 61 Times
Originally Posted by SRK
memo doest that effect the lighting??
I think there are these spray paints for lights available..how about that???
No itdoes not it looks as if stock when the lights go on nothing to worry for
memo45_m is offline   Reply With Quote
Old 29th October 2006, 06:28   #123
Ram
Ram's Avatar
Thanked: 149 Times
Default Clear tail-light units for Baleno
Here are two sets of aftermarket tail-light units for the Baleno.
The first one on the left is what we understand by clear lens.
The one on the right needs small colored glass envelopes around the bulbs
so that the tail-light, brake-light and turn-signal circuits produce light of the legally permitted color!
URL http://www.carfull.com.tw/performanc...amp/baleno.htm
Ram
Ram is offline   Reply With Quote
Old 29th October 2006, 11:27   #124
neo_trace's Avatar
Thanked: 38 Times
see this what i have found
i think this look so good
neo_trace is offline   Reply With Quote
Old 29th October 2006, 13:57   #125
danlalan's Avatar
Thanked: 135 Times
and after a little rework from RAM and neo's pics ....this is wht those lamps would look like....
danlalan is offline   Reply With Quote
Old 29th October 2006, 14:01   #126
adityapd's Avatar
well...the easiest quickfix to solve this issue once and for all is to pick up an altura
what say guys ?
~A
adityapd is offline   Reply With Quote
Old 29th October 2006, 14:06   #127
ported_head's Avatar
I think you guys should try and use the Altura's tail lights. You'd need to do a chop job around the sides and then fabricate new mounts for the lights probably, but I think the wrap around lights will soothen out the butch rear end quite a bit.
ported_head is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Looks comparison: Baleno and SX4 Ram The Indian Car Scene 151 27th December 2009 19:48
Which rear design looks best?? Shan2nu Shifting gears 11 25th January 2005 13:40
Improving Rider Comfort Dovin The Indian Car Scene 13 29th September 2004 19:29
