Old 5th September 2012, 15:31   #16
human_wheels's Avatar
Thanked: 56 Times
Default Re: RaceChipped - Maruti Swift Diesel
@shibujp Did you try out the other settings of the box.
I have been using this box for about 30k kms in my dzire with the stock settings.
There was no change in the FE. In fact I am getting about a km more.
So far I am loving it.
human_wheels is offline   (1) Thanks Reply With Quote
Old 9th October 2012, 01:15   #17
Thanked: 817 Times
Default Racechip Experience - Stage 2
Okay - so i've been running the Swift with Stage 2 of the RaceChip box. My experience has been mixed.
I liked Stage 1 better. Stage 2 seems to have given the car the ability to cruise at 100kmph which is 10 kmph higher than Stage 1. However this comes at the cost of a bit of low end torque which means that I have to take it easy in slower city traffic. Also the power delivery has become a little more linear post 2000 rpm. And braking which had been spot on in Stage 1 has become a bit of a problem now.
My experience has been that the ECU takes around 750 - 1000 kms to get fully adjusted to a new stage setting. In the interim power delivery becomes really patchy with a spot of shuddering at lower rpms. But taking it easy and waiting for the ECU to find it's feet pays dividends.
The mileage also seems to have dropped compared to Stage 1.
Drive on,
Shibu.
shibujp is online now   (3) Thanks Reply With Quote
Old 21st December 2012, 22:23   #18
Thanked: 817 Times
Switched back to Setting 1 and things are better now. However I think an impending timing chain replacement might be preventing me from getting the benefit I initially had.
Setting 2 also had some grease accumulating at the end of the fuel pump. This is the pump I am referring to - http://www.dieselevante.it/fuelpumps...0445010050.gif. According to what I read it seems to have some kind of relief mechanism if the common rail pressure goes up. All assumptions at this point. This accumulation has decreased once I shifted over to Stage 1. The mileage has also improved near to it's usual average.
Drive on,
Shibu.
shibujp is online now   Reply With Quote
Old 21st December 2012, 22:36   #19
Thanked: 604 Times
Just curious if you ever considered a remap as an option? Racechip is probably the cheapest option in the world and IMHO all Swifts should have a stock Racechip as that 75 HP engine tuned by Maruti to squeeze maximum mileage takes all the fun out of this brilliant engine.
At what RPM do you feel a change compared to stock settings?
Pedaltothefloor is offline   Reply With Quote
Old 23rd December 2012, 11:58   #20
Thanked: 817 Times
Yes, i did consider the Cosworth remap, however we simply could not work out an arrangement that worked as Cosworth folks would have to come to Cochin/Trivandrum for the remap.
The rpm range remains more or less the same. The low end and mid range pull improves.
Drive on,
Shibu.
shibujp is online now   (1) Thanks Reply With Quote
Old 23rd December 2012, 17:37   #21
Thanked: 1,172 Times
Drive on,
Shibu.
I am also trying out race dynamics ECU on Tucson.
how did you locate and spot the fuel pump on your car? Can you post some real pics?
BTW, I was using P1 and some P2 on the RD box for a month or more. Just out of curiosity, i have switched to E, which is economy mode for last 2 weeks or so and I notice the engine has become silent. So in the P1/P2, I think the diesel clatter increases as you said, I will continue to observe for another month or so...
If you switch to the economy setting (not sure what it is called on RaceChip box), do you also feel engine clatter is reduced?
anandpadhye is offline   Reply With Quote
Old 26th December 2012, 21:01   #22
Thanked: 817 Times
Here is the pic of the pump. It is on the right side of the engine as you face it.
I am currently on the lowest setting which I believe is the economy mode for RaceChip. Yep the engine is more silent in this mode
Old 9th August 2013, 23:58   #23
latentpotential's Avatar
Thanked: 380 Times
Initial Impressions
The chip has three settings and I am currently at the lowest.
Drive on,
Shibu.
Setting 2 also had some grease accumulating at the end of the fuel pump. ...
Shibu.
Can you please share how you change the settings on a racechip? I am planning for the Ertiga. Also, can we give them usage information while ordering itself so that they can apply appropriate settings before shipping?
latentpotential is offline   Reply With Quote
Old 18th August 2013, 16:22   #24
Thanked: 817 Times
Changing the setting is relatively easy though you will have to unscrew the front of the box to do so. Inside you will fine two adjustable screws numbered in hexadecimal from 1 to F. With you racechip module you get the documentation that tells you the combination for each of the 3 setting. Simply adjust to the specified combination using a small flat end screwdriver and you are done. Not as intuitive as flipping a switch though but I found it fine especially as I never found the need to keep on switching through the settings.
Here is a link to the adjustment mechanism - http://i55.tinypic.com/2nqr6ug.jpg
Drive on,
Shibu.
Old 5th December 2013, 14:14   #25
benzinblut's Avatar
Thanked: 598 Times
Can you inform what was the original setting when the racehip was delivered to you? You will find this on the invoice as well.
benzinblut is offline   Reply With Quote
Old 5th December 2013, 15:57   #26
devrajman's Avatar
Thanked: 116 Times
The best way to know the exact changes going on in rail pressure, radiator temp, etc is to connect ELM327 to the OBD port and check out behavior changes in real time.
You can also capture both data and analyze it later.
devrajman is offline   Reply With Quote
Old 12th December 2013, 22:11   #27
Thanked: 817 Times
The stock setting on the racechip was BC.
Drive on,
Shibu.
Old 21st October 2014, 21:40   #28
adit mishra's Avatar
Does the race chip lead to high rail pressures and high temperatures? Basically, a race chip tricks the ECU. So I feel you must use a 2 core heat exchanger with engine oil cooler for the swift diesel. The car may overheat under stressful situations Someone using this race chip may share the temperature gauge pictures after lots of driving.
adit mishra is offline   Reply With Quote
Old 23rd October 2014, 12:41   #29
using racechip in punto mjd and no diff in temp even afer a 7 hr drive. i use an obd scanner and the temp.once heated will remain between 81 to 83
pvgeorge is offline   Reply With Quote
Old 22nd March 2015, 20:17   #30
saurabhdadhichi's Avatar
Thanked: 74 Times
Shibu a query, i have recently procured a second hand RACECHIP which was used on Ritz Diesel and i have new SWIFT from 2012. When i installed the CHIP the setting was BC & i get a ENGINE CHECK Light ON. Once i remove the RACECHIP, the ENGINE CHECK LIGHT OFF goes away after some driving. Did you encounter any such problem? Can you also indicate what settings are recommended for your RACECHIP for Stage 1 & Stage 2?
saurabhdadhichi is offline   Reply With Quote
Diff between Speed diesel, Xtra premium diesel and regular diesel msk_kapoor Technical Stuff 90 26th July 2012 21:53
Altis Diesel vs Micra Diesel ! Is Altis Diesel still underpowered ??? Hero Puch The Indian Car Scene 13 8th April 2011 16:20
Help Choose: City vs Fiesta Diesel vs Verna Diesel vs Swift Diesel aseem Hatchbacks 21 11th October 2009 17:44
Urgent! Ford Fiesta Diesel, Logan Diesel vs Hyndai Verna Diesel Zahir Sedans 3 26th May 2008 10:37
