Old 21st July 2012, 08:42   #1
Thanked: 13 Times
Default Removable Fog Lamps - Possible?
I want to install extra fog lamps (Hella?) on my Qualis. I am thinking a bracket just above the bumper welded to the metal part of the body would hold the two. However I would like a mechanism by which I can remove the fog lamps during city driving and be able to put those back when we go on outstation drives.
Is it possible to do this while not screwing up the aesthetics? Because I am concerned the bracket will look like a sore thumb when the fog lamps are removed.
- Krishnan
ksakotai is offline   Reply With Quote
Old 21st July 2012, 09:45   #2
mayankjha1806's Avatar
Thanked: 821 Times
Default Re: Removable Fog Lamps - Possible?
Tough to say, but whatever lights i have seen they are all fixed onto the car and the most one can do it cover them when not in use. I have not seen any removable ones, but my guess is if such lights exist, the possibility of them getting loose on the place they are fixed are very high.
Over long use and at high speeds they can rattle, or worse can get dangerous and come out due to high speed air flowing through and get dangerous.
Would suggest you revisit the requirement of having detachable fog lamps and consider keeping them fixed for ever.
mayankjha1806 is offline   Reply With Quote
Old 21st July 2012, 10:55   #3
vikram_d's Avatar
Thanked: 940 Times
Why do you want to remove them? I had Hella fog lights on my Swift. In city driving I would just keep them covered and remove the cover while out on a highway night drive.
Also as you have mentioned the brackets will look horrible without the lights fitted on them.
Old 21st July 2012, 12:36   #4
Thanked: 13 Times
Originally Posted by mayankjha1806
....Would suggest you revisit the requirement of having detachable fog lamps and consider keeping them fixed for ever.
Originally Posted by vikram_d
Why do you want to remove them?..
..Also as you have mentioned the brackets will look horrible without the lights fitted on them.
Yes, I agree with both of you. But call me paranoid, I am always afraid that some auto or 2-wheeler may bang against my bumper and cause the lights to get damaged.
- Krishnan
Old 22nd July 2012, 22:08   #5
triedeverything's Avatar
Thanked: 165 Times
I was also thinking of installing removable fogs... especially since mine cost me almost 18K. Check - http://www.team-bhp.com/forum/test-d...ml#post2776538 (My new Scorpio MHawk: Initial report) for details.
Though I can remove the lights, it becomes a pain to remove, install and refocus each time. You may think that shouldn't take a lot of time, but believe me, it's impractical. The Qualis has a high bumper. If installed correctly, its not going to foul. Like I already mentioned, in the link above, even when I park with the front of the car touching the rear of the other car in the house (A swift), there is no risk of touching the lights. Of course, in a head on, the story is going to be a little different. But in regular day-to-day driving, you don't have to worry. If you are worried about someone knocking off your lights, high security nuts are the way to go. Peace of mind,in any gully!
triedeverything is offline   Reply With Quote
Old 23rd July 2012, 09:50   #6
genesis's Avatar
Thanked: 309 Times
You need something like this
Driving Lights [Unibar front bumper mount] - Toyota RAV4 Forums : RAV4World.com
Eagle Products Unibar Lighting Bracket
A 4x4 accessories manufacturer was fabricating them in India. Cant remember who though.
genesis is offline   Reply With Quote
Old 23rd July 2012, 16:45   #7
greenhorn's Avatar
Thanked: 1,516 Times
There was one in the classifieds. Have a look!
How do you dispose of CFL lamps & Fluorescent lamps? Klub Class Shifting gears 13 19th April 2017 16:57
Projector Lamps(Low Beam) as Fog Lamps for Ritz LDI alexpaul Modifications & Accessories 17 13th September 2012 20:23
Fog lamps without fog dushmish Road Safety 113 5th January 2012 12:51
Wanted :Fog lamps for new Lancer Lxd Maneesh Modifications & Accessories 0 6th May 2006 16:21
Zen MGA fog lamps fit WagonR ? prateekkaul Modifications & Accessories 2 9th January 2006 16:55
