Old 20th October 2009, 10:51   #16
funkykar's Avatar
Thanked: 1,740 Times
Originally Posted by 1100D View Post
Mileage is a different issue.
I get that there is an initial slight hesitancy in pulling, but not sure as you mention you put the car in first gear and then push the throttle all the way down. It could be exactly that driving style wherein the butterfly is opening from idling position to wide-open-throttle (all of a sudden). The fuel circuits in both these conditions are completely different and might be thus causing the hesitance. Do you even feel hesitancy when you start with a light foot?
If you want to have the best start , rev before releasing the clutch, not release the clutch and then push the accelerator all the way down.
I too have this issue of hesitancy when the accelerator is pushed quickly. It doesnt happen when I accelerate slowly. Except for the tuning, could any thing else be bad?
@ Eastdust: How did you finally resolve the issue? Did you go for the M1000 carb? Please detail
funkykar is offline   Reply With Quote
Old 2nd November 2009, 12:51   #17
eatdust's Avatar
Thanked: 19 Times
i didnt replace it yet. gettin a good mechanic to work on it is a big problem here in trivandrum. hope u wont have any problem at blore
eatdust is offline   Reply With Quote
Old 2nd November 2009, 12:58   #18
funkykar's Avatar
More or less the same here buddy! No good mechanic here too. Moreover, S1 parts are not available here
Old 10th December 2009, 23:14   #19
Mehul1100's Avatar
Thanked: 13 Times
You can find good mechanic in Alleppey, there I used get my padmini jobs done before. Now I am near coimbatore so in coimbatore parts and service are not much of a problem.
Contact me at +919443330289, for mechanic in Alleppey and Coimbatore especially for fiats.
Mehul1100 is offline   Reply With Quote
Solex Carburettor for CJ3B desertfox 4x4 Technical 16 17th January 2013 11:17
Need help and advice for carburettor change in Premier Padmini rajnikhil Modifications & Accessories 12 11th January 2010 02:29
Injector and carburettor cleaner for my Swift ! siddhu_engg24 Modifications & Accessories 6 10th November 2008 10:14
Petrol leak from Carburettor - Mach 500 Ketan Technical Stuff 5 12th July 2007 13:19
How does one find a vaccum leak in a carburettor? techn0l0gist Technical Stuff 1 14th January 2007 00:54
