Old 12th May 2006, 09:11   #31
Ford Rocam's Avatar
Thanked: 16 Times
i have done direct porting to it
i have also got the heads recently polished
Can you elaborate more on that "direct porting" have heard for the first time & Polishing where you have got it done
i also use petrol with high performance additives
which fuel do you use & what additives ?
i use honda accord oil in my car
the showroom guy said its different from city oil
What Viscocity?
i get so much power coz my k&n has a directr connection to the engine i.e i have put a original k&n pipe along with the filter
Can you post the pic for same?& pic of your engine Bay. is your ECM Stock or are you using Apexi VAFC
Ford Rocam is offline   Reply With Quote
Old 12th May 2006, 10:57   #32
Thanked: 11 Times
Originally Posted by honda_dude
i didna say i havent tampered with the electricals
Hey could you also specify what all you've done with the electricals?
Boom Shiva is offline   Reply With Quote
Old 12th May 2006, 14:17   #33
Fuelled's Avatar
@shantanu-
Boy i had no idea how speed was calculated. Thanx
But i'm stil a little sceptical.
I mean everywhere else i've read that if you have a new tire that is either bigger or smaller in circumference than ur OD, then ur speedo reading goes for a toss.
Fuelled is offline   Reply With Quote
Old 12th May 2006, 14:34   #34
Shan2nu's Avatar
Thanked: 89 Times
Yup thats true, using a smaller or bigger tyre will increase speedo error wrt vehicle speed and not tacho readings.
For EG: If i fit the Vtec with 145/60 R13 tyres. It's circumference would be 145 * 0.6 / 25.4 + 6.5 * 2 * 3.14 = 62.33 inches.
So at 7100rpm in 2nd the car would be doing 87.06 kmph (-2%). But, your speedo would still be reading the factory caliberated speed at this point (which is 98kmph in my car).
So, your speedo error would have increased by 11.3 %. Meaning that your car is showing 98 when you're actually doing 87.
When upsizing, always go for a tyre size that will increase circumference by a little (withing 3% though) This will reduce your speedo error by a certain %.
Shan2nu
PS : Mods, i think you can move all the speedo error posts onto a new thread titled "Speedo error, are you aware of it?"
Shan2nu
Old 12th May 2006, 14:39   #35
diven_b's Avatar
hey shan2nu
say if i am using 195/65/15 rite now........and i upgrade to 215/45/17....what (%) will the error be like.?
diven_b is offline   Reply With Quote
Old 12th May 2006, 14:47   #36
Shan2nu's Avatar
Thanked: 89 Times
195/65 R15 has a circumference of 78.43 inches.
215/45 R17 would come to 77.30.
So your speedo would be over reading by 1.5% (Which is ok i guess).
You could also go in for 215/50 R17, which will reduce speedo error by 1.9%.
45 profile is a bit too low for Indian conditions.
Shan2nu
Old 12th May 2006, 14:50   #37
diven_b's Avatar
thanks..that solved a few doubts
Old 12th May 2006, 23:51   #38
Fuelled's Avatar
Hey thanx shantanu for clearing the confusion. I didnt kno it was like that
And Diven B use this link to calculate ur tire error(its already been posted before by rtech, but jst for a shortcut)
http://www.miata.net/garage/tirecalc.html
and the thread link
http://www.team-bhp.com/forum/tyre-a...alculator.html (Tire size and Speedo error calculator)
Old 13th May 2006, 16:06   #39
honda_dude's Avatar
Thanked: 33 Times
Default hey evr
thanks evry one for taking so much interest in my post
actually i have 205 /40 r17 on my car
and i dont know if there is any error in my speedo but the tacho actually shows around 120-123 when i rev it in the second gear
also sajid has done sumthing to my rpm setting due to which the engine feels over revved all the time
and so when i do around 100-120 my rpm reaches upto 7500. is this the reason my car's showing such a high speed or is there some error with the speedo
honda_dude is offline   Reply With Quote
Old 13th May 2006, 16:24   #40
honda_dude's Avatar
Thanked: 33 Times
i was wondering to change some parts to increase my performance
could u'll suggest me some good picks
1) msd ignition
2)pressure regulator
3) turbo ignition
4) turbo charger
also can sumone tell me is turbo charger and intercooler the same
as my budget is low i was planning to go for msd and pressure regulator
are these parts gonna help?
Old 13th May 2006, 17:07   #41
viper's Avatar
Thanked: 9 Times
Hey,
A fuel pressure regulator and MSD ignition will help. The combined cost should be in the vicinity of approx 30-40k depending on the MSD parts you fit.
A turbo setup will be out of your budget.(1lac upwards)
Viper
viper is offline   Reply With Quote
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 137 24th January 2015 12:15
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
Looking for OHC in mint condition 16v100bhp Shifting gears 3 28th May 2007 19:37
Looking for a OHC mithun.pentuker Sedans 13 21st March 2007 22:20
Looking to buy used OHC luvjascha Shifting gears 0 28th September 2006 04:59
