Closed Thread
Old 11th November 2009, 21:12   #46
sgiitk's Avatar
Thanked: 3,882 Times
Most majors are good.
I will go totally by the API ratings. Only API-SJ, SL and SM are current. Others are history. This is for petrol. If you are driving a run of the mill car then Synthetic, Semi-synth, Mineral differences are not worth bothering. Make sure you meet the manufacturers recommendations. Then vote with your pocketbook - get the cheapest.
sgiitk is offline
Old 13th November 2009, 11:19   #47
Thanked: 21 Times
Hi Sumeet,
The MRP of Shell Helix Super 15W40, is 915Rs for 4 ltrs. I was also searching the Shell station of 15W40, but none of them has stock, so purchase Castrol Magnatec 4 ltr at 1160 Rs (bit costly but i didnt have time to search other shops so purchased).
For information of others,
Also changed: Oil filter: Purolater/Mhale: 70Rs
Air filter: Purolater/Mhale: 120Rs
Hope this helps.
shabahmad is offline
Old 5th January 2010, 16:11   #48
maglev's Avatar
Thanked: 90 Times
Guys I need some advice,
During the 1st service of my SX4 (July 2009) I got Mobil-1 (0w-40) fully synthetic engine oil , Now the issue is that my 2nd service is due within this week,
so I wanted to know whether I should stick to the fully synthetic or switch to normal oil.
1. What would be advisable in the long run ?
(Taking into account various parameters such as performance, engine life and economy.)
2. Should I change to normal oil now and switch to fully synthetic during my 3rd service ?
P.S.: The car has 3900 kms till date and I plan to retain her for at least 7-8 years.
maglev is offline
Old 20th June 2010, 11:20   #49
Thanked: 99 Times
Anyone having experience with BOSCH engine oils?
(Alok) is offline
Old 20th June 2010, 19:02   #50
Thanked: 37 Times
my ikon completed 1Lac Kms and i am planing to give it a vitamin treatment with OWS (engine Flush, engine oil addictive and Fuel line treatment) by myself. Ford dealers use 10w 30 engine oils from Mobil, shell or castrol. i am searching for the same in local oil dealers but not able to get (either 10w 30 or 5w 30) can i use 10w 40 ( castrol magnetic is available ) instead?. is it not littile more thicker compared to 10w 30. even though both of these oil have same viscosity at hot condition , will my engine not suffer in cold starts?
toms_2191 is offline
Old 20th June 2010, 23:00   #51
sgiitk's Avatar
Please look at the Synthetic Oils thread - you will find all your answers there.
MODS: Please merge the threads
Note from Mod : Old thread on a topic often discussed on the forum. Hence closing.
sgiitk is offline
Closed Thread
Is RWD more suited for India? vcash Technical Stuff 17 19th November 2010 12:23
Which second hand car to buy which would be most suited to put in CNG? sahakar Hatchbacks 1 4th May 2008 02:16
Most suited rear disc brake setup for Pulsar? nikkibike Motorbikes 11 14th June 2007 11:15
