Closed Thread
Old 4th May 2006, 13:18   #1
gbpscars's Avatar
Default Most suited engine oil.......?
Now another debating thread, (sorry admins, if I have posted in the wrong Q, this was the most appropriate)
Which engine oil is good for use?
My choices can be
Mobil 1
Castrol GTX
Pennzoil (not sure about the specs)
I had been using Mobil even for my 2-wheeler Suzuki Shogun.
So I would like some expert advice for a good engine oil (budget ranging from medium to high) for my OHC VTEC.
Also pls recommend which petrol is good for performance?... BPCL Speed or Speed 97?
gbpscars is offline
Old 4th May 2006, 13:38   #2
You can try synthetic engine oils from Shell like Helix Ultra and OWS. Mobill 1 is good too.
For performance obviously speed 97 but for a OHC Vtec I think you could stick to speed.
5u3zEr0 is offline
Old 5th May 2006, 19:10   #3
mobil 1 sucks dont use it plz
Kinetik is offline
Old 5th May 2006, 19:24   #4
F50
F50's Avatar
Thanked: 92 Times
Few days back I flushed my engine oil and now its running on Castrol GTX Magnatec .... Its pretty good. Earlier I was going to put Mobil 1 but makes no sense putting it in Santro.
You got a Vtec, I say go for Mobil 1. May be other Vtec/Mobil 1 owners/users might give you better picture.
F50 is offline
Old 5th May 2006, 20:46   #5
The Wolf's Avatar
Thanked: 58 Times
I run my ohc vtec on Castrol GTX magnatec...its very good I can say...donno if comparing it with fully synthetic like mobil1 would make sense but for the money you are paying magnatec should keep you damn satisfied. For engines older than 100000kms, mobil1 should be preferred for other reasons.
ps: Use Bardahl engine oil additive(some 350bucks) with magnatec and you have magical results.
The Wolf is offline
Old 5th May 2006, 22:09   #6
jkdas's Avatar
Thanked: 1,423 Times
Ok, so if I am to get it what should I ask teh shop guy for? Magnatec for Santro? And how much should I buy and how much would it cost?
jkdas is offline
Old 5th May 2006, 22:16   #7
kpzen's Avatar
Thanked: 1,613 Times
Indian Oil Servo is also good.....
any reasons..!!!
kpzen is offline
Old 5th May 2006, 22:24   #8
kb100's Avatar
Yup... Why??? ....
kb100 is offline
Old 5th May 2006, 22:34   #9
F50
F50's Avatar
Thanked: 92 Times
No just say Castrol GTX Magnatec .. you will need 4 lt can (700-800 grey in color) and it is advisable that you also change the Oil pump which will cost 120 bucks.
Voila much smoother Santro.
F50 is offline
Old 5th May 2006, 23:02   #10
DRC
DRC's Avatar
Thanked: 42 Times
did U mean, oil filter?
DRC is offline
Old 5th May 2006, 23:20   #11
jkdas's Avatar
should be. I missed it.
jkdas is offline
Old 5th May 2006, 23:24   #12
F50
F50's Avatar
Thanked: 92 Times
Yea oil filter ... my mistake
F50 is offline
Old 6th May 2006, 02:56   #13
Which is this additive? I am using IFtex -G is that good.
How are you supposed to put these things..at every tank full?
Asking for the Baleno and the Swift.
imjimmy is offline
Old 6th May 2006, 03:54   #14
Max
Thanked: 85 Times
I fill up Indian Oil extra premium 91 octain fuel in my honda city. It gives better mileage then Reliance normal fuel. Go for Indian Oil Extra premium fuel, its good
Max is offline
Old 7th May 2006, 10:11   #15
Originally Posted by kb100
Yup... Why??? ....
1) there was a chemical analysis done on all engine oils .. mobil1 turned out be on par with semi-synth oils,,,
2) mercedes all over the world especially the wdb211 were facing this problem of cam wear as early as 30,000 kms the reason mobil 1.. u could infact ask for instance autohangar or taipan ...which oil they were earlier using and which oil they are using now.. ..
but the best test lies with u .. use mobil 1 .. run the car for around 10,000 kms and then switch to OWS, shell helix ultra or petrocanada and see the diff for urself..
Kinetik is offline
Closed Thread
Is RWD more suited for India? vcash Technical Stuff 17 19th November 2010 12:23
Which second hand car to buy which would be most suited to put in CNG? sahakar Hatchbacks 1 4th May 2008 02:16
Most suited rear disc brake setup for Pulsar? nikkibike Motorbikes 11 14th June 2007 11:15
