Old 9th December 2012, 06:23   #16
Thanked: 370 Times
Default Re: Figo Suspension - to mod or not to mod
Basically answer the following questions and the decision whether you need new shocks or OEM shocks will be clear.
Do you intend to keep the vehicle the same height or is it going to change (higher or lower)
Are you putting in a beefed up suspension to better handle the road conditions
Do you want better highway handling (lowered suspension for better cornering)
As you can see the above questions are aimed at seeing if changing to after market or OEM is fine
pganapathy is offline   Reply With Quote
Old 9th December 2012, 11:25   #17
Catalyst_delhi's Avatar
Thanked: 149 Times
I am surprised that a Figo's Suspension broke down this early. I really like the suspension setup. I would do anything to keep the Figo's suspension stock as possible.
Catalyst_delhi is offline   Reply With Quote
Old 9th December 2012, 12:31   #18
kpzen's Avatar
Thanked: 1,655 Times
You have to be kidding. The Figo has such amazing balance between ride & handling in stock form. Why on earth would you want to upgrade? Performance dampers are very expensive, difficult to source and have zero after-sales support. Upgrades should be implemented where they are required and, IMHO, the Figo's suspension simply doesn't need any after-market treatment.
Leave the performance dampers for owners of the i20, Micra et al
Absolutely SPOT on !
I have a sharp handling Getz with monroe suspension and a stock Figo.
Figo's setup is way better than the Getz. Feels so relaxed even while cornering at triple digit speeds.
Figo has one of the best stock suspension setup, upgrading is not advisable.
kpzen is offline   (1) Thanks Reply With Quote
Old 13th May 2013, 19:00   #19
himanshu_j's Avatar
Thanked: 125 Times
Originally Posted by pranavt View Post
Do NOT install lowering springs on stock dampers, even if they are brand new.
Why do you advise against it so strongly?
Agreed the stock dampers will wear out faster but replacing a stock damper is way cheaper than buying sport dampers.
himanshu_j is offline   Reply With Quote
Angels & Demons - The first mod to the Figo Mad Max Modifications & Accessories 27 17th October 2014 08:55
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Suspension mod? thalavoy Modifications & Accessories 14 24th November 2004 19:17
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
