Old 1st March 2013, 12:37   #46
Thanked: 62 Times
Default Re: My Laura with a Bilstein B14 suspension & many other Mods
Hey PZ, where in mumbai did you get the blisteins from and at what price. Also do you go to the A.S.S for service, or have you found some reliable mech. Please share info on that.
an_and is offline   Reply With Quote
Old 1st March 2013, 14:45   #47
prithwi-81's Avatar
Thanked: 987 Times
Bilsteins are from Pete's as he's mentioned. The new batches have significantly increased cost, nearly 1.5x of wht he paid (88k).
prithwi-81 is offline   Reply With Quote
Old 2nd March 2013, 17:13   #48
prithwi-81's Avatar
Thanked: 987 Times
FYI! New comparo photo.
Name:  Stock vs B14.jpg
prithwi-81 is offline   (1) Thanks Reply With Quote
Old 22nd November 2013, 08:33   #49
Hi prithiwi_81
Please be a little careful when you adjust the height as it vastly affects the suspension geometry . That will alter the handling .
Say For example in a McPherson Strut . You want to lower the car ( effectively CG) so that you get better handling and lower body roll in corners . If you shorten the strut length your ride height will go down but your roll stiffness may be decreased due to change in the control arm position. Please keep suspension geometry in mind before changing the ride height .
Also when you change the ride height , you probably turn the special screw on your strut which holds the spring . This apart form changing the spring length alters it's preload and stiffness ( if a progressive spring ) and will bring about changes in your ride quality .
satya430 is offline   (1) Thanks Reply With Quote
Polo GT TDI: Bilstein B6 or B14 + Eibach springs? raajks Modifications & Accessories 51 8th June 2018 07:50
Silver Skoda Laura TSI, 200 BHP & Bilstein Suspension. UPDATE: 70,000 kms up Santoshbhat Long-Term Ownership Reviews 252 13th January 2018 16:32
Many Many Happy returns Of the DAY SRK!! SohailPistawala Shifting gears 4 31st March 2008 18:17
Mods for Civic Vs Mods for Laura redsfx Modifications & Accessories 15 19th November 2007 21:01
