Old 7th July 2009, 09:36   #31
mithun's Avatar
Thanked: 49 Times
A little off-topic...
Is it possible to move the gear-lock fitted that's fitted in the old car to a new car when the old one is sold ?
Old 7th July 2009, 10:52   #32
Thanked: 33 Times
2 problems:
1. It cannot be guaranteed that old car's gear lock will fit the new one. They are different for different cars.
2. It will leave couple of holes in the body of old car.
amohit is offline   Reply With Quote
Old 7th July 2009, 12:29   #33
prince_pervez's Avatar
Thanked: 31 Times
The base plate is the key here. This plate is bolted on the chasis and the lock is mounted on the base plate.
The base plate is placed very near to the gear lever. So it becomes necessary that the curvature of the mount (on which the gear lever & cup holder plastic mould is mounted) are in sync.
If it is in sync with your new car than it is usable.
But, like someone pointed. It leaves holes in your old car chasis!
prince_pervez is offline   Reply With Quote
Old 7th July 2009, 22:59   #34
Thanked: 31 Times
Heres a snap of the base plate bolted to the chasis curve of my zen.
If anyone is interested I can start a new thread on this install. I have a complete set of pictures.
Old 8th July 2009, 02:17   #35
Ravveendrra's Avatar
Thanked: 405 Times
Security is above all, a state of mind. If the car looks unattractive either due to locks or bad condition thieves will stay away.
How to beat the car thieves:
1. Drive an old beat up car. No matter what is under the hood - no thief will come near it.
2. Do not clean your car ever. The dust and grime will deter the most determined thief.
3. Put a fancy looking black box with military markings on the dash with flashing lights, beeper etc. Switch off the lights and beeper when you get in - remember to switch on the lights and beeper when you get out.
4. Drive a car with low re-sale value.
5. To deter 'friends' from 'borrowing' your car - interchange the spark plug leads.
6. Use a chain and padlock to tie your car to a lampost, pillar or ring set in wall/ground.
7. Become a politician so you can have black cat commandos surround and protect your car 24/7.
8. Buy yourself a huge big dog and keep him in the car - remember a hungry dog is an angry dog, so do not feed him.
9. Sell your car and hitch a ride with that cute neighbour.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 9th July 2009, 10:23   #36
mithun's Avatar
Thanked: 49 Times
prince_pervez : Please start a new thread with pics. It would be useful to everyone.
Old 12th July 2009, 13:01   #37
UniqueMods's Avatar
Thanked: 49 Times
prince.
how come your gear lock is mounted on the left side of the gearshift ?
yours looks like and Hyundai original manufactured by minda. i have the same brand.
my Santro's on the right. have attached some pics.
are these locks fit-able on either side?
UniqueMods is offline   Reply With Quote
Old 12th July 2009, 14:17   #38
Thanked: 31 Times
Originally Posted by UniqueMods View Post
prince.
Hi Unique Mods! Yours is a Pin type install. Mine is a 'U' type.
With the plate and the visible lock (which should act as a deterrent)
on the right side, it would be a cause for discomfort for the driver.
On the other hand having a Pin type, like yours, on the left side would be a problem for the driver everytime, he (the driver) wants to lock/unlock it.
I the picture gives you a better idea.
By the way your install is
Old 14th July 2009, 11:13   #39
mithun's Avatar
Thanked: 49 Times
Which one is costly U-type or Pin type ?
Old 14th July 2009, 11:37   #40
Thanked: 31 Times
I can comment on 'U' type.
Ranges from 1100 to 1500.
If the company has a franchise in the town where you live installation would be free. If you courier it and you have no franchise of that company, but there are fitters of some other brand, then installation should take around 150 - 200 bucks.
Old 14th July 2009, 11:49   #41
inferno's Avatar
prince.
I guess they can be fitted on either side, as I got pin type gear lock installed on my NHC and its on left side. I must say, its lot more convenient than having it on right side.
One of my other friend had it on right side and it created so much inconvenience that now he has stopped using it !
inferno is offline   Reply With Quote
Old 14th July 2009, 11:53   #42
Thanked: 31 Times
Depends, if you are used to it, and can manage to get the key in the slot without looking then, yes it is comfortable. For me, I would want to be sure where my key is going.
Old 14th July 2009, 12:32   #43
inferno's Avatar
Its not about the key, but the pin doesn't come out unless we push the seat a little more backward than normal. So moving the seat everytime one wants to lock and unlock is irritating.
Old 14th July 2009, 14:43   #44
UniqueMods's Avatar
Thanked: 49 Times
i guess mine,installed on the right side is fine as i can unlock and lock without moving the seat.
UM
Old 14th July 2009, 14:45   #45
Thanked: 31 Times
Ohh if that is the case then I'd prefer a 'U' type any day. Just slot the gear lever in neutral and slap on the gear lock (click sound) with one hand (left) and thats about it.
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Can a gear-lock cause the gear cable to loosen up? libranof1987 Technical Stuff 0 22nd December 2011 21:29
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
