Old 16th May 2006, 13:18   #16
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by speedbuster
Off topic:
I heard that in canada, people hardly use Horns?
They use it only when it is absolutely necessary..
If u blare ur horns too much, u can be sued...
pity india...I see people blaring their horns in open stretch of roads...
not only in canada....
adn @ Kb, yah I did fix it. Need to add a relay as it now works in palce of teh factory ones
Old 16th May 2006, 16:53   #17
wolfinstein's Avatar
The OEM Pau-Pau horns in a lancer are from Boch's...However a few years ago, when i could'nt find a shop selling them I went for " Roots " work pretty well..!
wolfinstein is offline   Reply With Quote
Old 16th May 2006, 21:04   #18
kb100's Avatar
Roots makes some sexy equipment!!... Excellent build quality! .. Check out their ceramic holders for high wattage bulbs... MmmWAAAAH!!
kb100 is offline   Reply With Quote
Old 17th May 2006, 06:16   #19
mithun's Avatar
Thanked: 58 Times
When I went searching for a 2 or 3 Pin air-horn, all the shopkeepers said that they have stopped stocking air-horns because it's illegal. Although I knew that it's illegal since most of my drive involves through rural areas where there is almost 0% noise pollution.
So what is the cost of a typical 2 or 3 Pin air-horn ?
And is it still available in your cities ?
Old 20th May 2006, 21:18   #20
jkdas's Avatar
available at tvm ! even teh Nautilus!
Old 1st June 2006, 18:25   #21
headers's Avatar
Thanked: 464 Times
Default Stebel Nautilus - where in Chennai
Where could we get this at Chennai?
Originally Posted by Boom Shiva
Optra.
Was having major issues with ricks, bikes and just about everybody taking advantage of the fact that I won't drive aggressively. Previously I;ve used the Stebel in my Lancer and it had great results there too.
Challenger, I'd recommend the Stebel Nautilus over the Hellas because it is really compact and doesn;t have pipes, trumpets etc. Yet it delivers almost the same output (139db is no joke) and has worked for years without trouble.
Also, because it's small, it is easy to fit. I tried fitting Stebel twin trumpet air horns earlier because they looked so big and loud. But they're not really meant for a car. So you have to find all kinds of space to squeeze them into, and then when you shut the bonnet you find half the sound is muffled, so no point in having an air horn at all. The Stebel's size and shape make it easy to fit right near the air vents in the front bumper, so you get maximum effect.
Costs about 800-900 bucks max. Wiring and fitting might be a bit more, but it's definitely worth it. Ironically, I use the horn less now, because I know that I can actually do something about the jackass in front of me.
Old 1st June 2006, 19:14   #22
Jaggu's Avatar
Thanked: 8,670 Times
Anybody seen this Nautilus in Bangalore??
My other car is an Accord! Pre-owned 2003 Honda Accord 2.3L MT honeybee Test-Drives & Initial Ownership Reports 93 25th January 2018 17:34
Honda Accord VTi vs Honda Accord V6 Dinesh99 Technical Stuff 48 9th March 2010 02:08
Air Horn on Accord 2008 FaeLLe Modifications & Accessories 5 23rd February 2009 12:37
Sixth Gen Honda Accord Horn Issues Tejas@perioimpl Technical Stuff 3 6th October 2008 16:38
Honda Accord Coupe Concept (Possible new Accord) amit The International Automotive Scene 3 10th January 2007 10:04
