Old 14th April 2014, 10:15   #16
swiftnfurious's Avatar
Thanked: 6,429 Times
Default Re: Angels & Demons - The first mod to the Figo
Originally Posted by Mad Max View Post
...My first guess (and wrong one at that) was the projectors were heating up the glass area and somehow this happened.
Your HIDs would be max 55W! Or is it 35W? Even if it's 55W, it should still be the same wattage as a stock bulb and the heat should be in the same range. That would NOT damage the lamp I believe.
swiftnfurious is offline   Reply With Quote
Old 14th April 2014, 11:31   #17
Thanked: 726 Times
anurag - I called up 3M, HSR. They said they don't do headlight buffing. Maybe, I'll ask what their solution is to the problem rather than me asking for a specific service.
Swiftnfurious - thanks for the detail. Thought as much but I am an amateur at this stuff, at best.
Mad Max is online now   Reply With Quote
Old 19th May 2014, 19:53   #18
lovecars21's Avatar
Thanked: 765 Times
Added Sill plates to my Figo TitaniumAngels & Demons - The first mod to the Figo-imageuploadedbyteambhp1400509352.702822.jpg
Total 6 pc fitted.
Angels & Demons - The first mod to the Figo-imageuploadedbyteambhp1400509374.318996.jpgAngels & Demons - The first mod to the Figo-imageuploadedbyteambhp1400509385.868976.jpg
A car refrigerator in my Figo Titanium:
Angels & Demons - The first mod to the Figo-imageuploadedbyteambhp1400509429.469122.jpgAngels & Demons - The first mod to the Figo-imageuploadedbyteambhp1400509445.002160.jpg
Sent from my iPhone using Team-BHP
lovecars21 is offline   Reply With Quote
Old 19th May 2014, 21:16   #19
Red Liner's Avatar
Thanked: 1,114 Times
Originally Posted by lovecars21 View Post
Added Sill plates to my Figo TitaniumAttachment 1242158
Total 6 pc fitted.
Nice. How much did they cost you? Where did you get them done? Any wire splicing?
Red Liner is online now   Reply With Quote
Old 19th May 2014, 21:24   #20
lovecars21's Avatar
Thanked: 765 Times
Price of Figo Sill Plates: Rs. 990/- x 2 sets from ebay india
Price of Car Fridge: Rs. 5,000/- from ebay india
All fitments done by me keeping in mind I don't cut any wires.
Old 19th May 2014, 21:30   #21
lone_driver's Avatar
Thanked: 97 Times
Love the design of your car refrigerator . And looks compact too .
How much did it cost you ? What brand ? Does it draw power from the car's battery ?
lone_driver is offline   Reply With Quote
Old 19th May 2014, 22:10   #22
lovecars21's Avatar
Thanked: 765 Times
Its a product of Koolatron and price is already mentioned in my previous post.
Yes, it is connected to the 12v Cig lighter output.
Old 20th May 2014, 00:13   #23
createrkid's Avatar
Thanked: 292 Times
Does the cooler have any sort of impact on the battery? Sorry for the stupid question but how does it cool as compared to a normal refrigerator?
createrkid is offline   Reply With Quote
Old 20th May 2014, 00:43   #24
lovecars21's Avatar
Thanked: 765 Times
It doesn't impact the battery much but i generally use it only while i drive the car(i.e., the ignition is turned on)
It won't work like a normal refrigerator but will get the temperature 15 deg below the surrounding temperature. It helps a lot to keep drinks and water drinkable during scotching summers.
Old 20th May 2014, 00:44   #25
ghpk's Avatar
Thanked: 192 Times
Nice Fridge you have.
I gave a quick look on ebay.in and found only one of similar shape,
this should be a 11 Ltr model, which runs only on Voltage 110V A.C.
So I am guessing the ones available in India, are having sometime of Small Inverter which provides 12V D.C. from Car Cigg. Lighter to the unit which converts it.
The inside unit might be Similar like the Belkin and other Car Inverter we all know about, which comes in various Load Sizes, 35 watt, 65w, 150 watts etc.
So this is certainly MEANT to be plugged in while "Engine Is Running" running it with engine turned off, will either trip it, or drain your batter, as per its circuit design.
Now for the cooling Part, 11 Lts is not too Big, It can keep cool things cool, but I would not expect it to ICE Chill a Tap water, but I would not be surprised if OP says its possible in this car fridge.
Old 23rd May 2014, 21:47   #26
lovecars21's Avatar
Thanked: 765 Times
I have already replied to your query in my previous post.
Old 17th October 2014, 07:54   #27
sara.ramli's Avatar
Thanked: 327 Times
@Madmax, so how is your projector setup faring after a year and a half? Did you run into any issues or have to use the warranty at all?
I am planning to get the same brand installed in my Figo here in Chennai. The price being quoted is about 20k for the demon eyes version including labour.
Also, as requested by other members earlier, can you kindly post pics of the beam pattern and the spread that it produces on the road (low and hi)? That's the last thing I want to confirm, before going in for these. Tried a local Chinese import and the beam pattern was pointed (read pencil) and had to undo the installation because of that.
sara.ramli is offline   Reply With Quote
Old 17th October 2014, 08:55   #28
satan's_valet's Avatar
Thanked: 172 Times
Bumped into this thread late, however awesome setup Mad Max.
Any update on the white spots in the headlamps? Were you able to fix it?
satan's_valet is online now   Reply With Quote
Figo Suspension - to mod or not to mod KiloAlpha Modifications & Accessories 18 13th May 2013 19:00
Stories from The Land of Angels Funda Travelogues 29 10th April 2011 10:54
Exorcizing Demons within !! Torque-ative The Indian Car Scene 6 23rd December 2006 10:19
Moutain Dew Crusty Demons meet Revvmaster The Team-BHP Meet Section 6 7th December 2005 15:08
hi all speed demons............. DRAGSTER Introduce yourself 5 4th March 2005 18:14
