Old 28th June 2013, 14:43   #106
binz's Avatar
Thanked: 412 Times
Default Re: Building a G16b - Turbocharged + ITBs
That is brilliant! Now - to revisit an earlier query of mine: is all that power usable onto the roads ?
Absolutely, at 19psi, with the 215 section, 17" rubber, stiffened/lowered suspension and mounts, you can go full throttle in any gear and there is no wheel spin or torque steer. In the drivers seat you don't feel the g's but the few people who have sat shotgun say nothing short of a Suberbike has given them the rush this car gives.
binz is offline   (5) Thanks Reply With Quote
Old 28th June 2013, 15:01   #107
audioholic's Avatar
Thanked: 6,147 Times
Default re: Race Dynamics' Baleno Build-up: ITBs/Turbocharged - Re-dynoed @ 256 WHP!
Could we too experience this now? Thats just amazing. So would you be using 19psi for daily runs or reduce the boost and increase when required? Even at 12psi, I think this will be a hoot when floored, which is quite enough for Bangalore roads aint it?
audioholic is online now   Reply With Quote
Old 28th June 2013, 15:35   #108
binz's Avatar
Thanked: 412 Times
Sure, send me a pm whenever you are free and Ill take you for a drive.
Daily drive would be anywhere between 12-15psi. I floor it everytime i see an open stretch and even 1 bar is an overkill. I've seen what boost does to the cylinders walls over time which is the only reason why I wouldn't run 19psi every day. That said, turning up the boost is a button away
binz is offline   (2) Thanks Reply With Quote
Old 28th June 2013, 17:20   #109
nipcarlover's Avatar
Thanked: 307 Times
Your car is on the TBHP Facebook page!
Just found this thread, and completely hooked. Awesome mods, my friend.
Can we please have a video of the car??? Especially the antilag???
nipcarlover is offline   (1) Thanks Reply With Quote
Old 28th June 2013, 17:25   #110
binz's Avatar
Thanked: 412 Times
Here you go, video from the rrp dyno room:
binz is offline   (8) Thanks Reply With Quote
Old 28th June 2013, 17:46   #111
d3mon's Avatar
Thanked: 622 Times
Awesome work!!
The manifold glowing red during the dyno run was amazing to watch.
Will the piping hold up to such high temps though?
Also, is there a chance of the turbo getting damaged when you close the throttle suddenly and the boost pressure has nowhere to go without a wastegate?
d3mon is offline   Reply With Quote
Old 28th June 2013, 18:06   #112
Thanked: 24 Times
congrats to you gents!!! sheer awesomeness. When can i ride shotgun. tell me the time and place
amarpreet99 is offline   Reply With Quote
Old 28th June 2013, 18:23   #113
binz's Avatar
Thanked: 412 Times
Interesting comments on that post. Its a wideband o2 sensor going into the exhaust, not a spark plug
Its not exactly antilag, but for lack of a better word that will have to do for now. Heres the video:
Originally Posted by d3mon View Post
Awesome work!!
The piping will hold, you will see the same thing happen on most turbo cars on the dyno.
A greddy Blow-off valve is installed, though not visible as it is near the intercooler. You can hear it though in the video ..
binz is offline   (1) Thanks Reply With Quote
Old 28th June 2013, 18:26   #114
stuntfreak's Avatar
Thanked: 463 Times
Super cool!
Really killer stuff.
stuntfreak is offline   (1) Thanks Reply With Quote
Old 28th June 2013, 19:36   #115
ACMohan's Avatar
Thanked: 106 Times
Great build man!
BTW, the sound of BOV resembles more like a compressor surge. Maybe my headphones playing the trick.
Cheers!
Have Fun
ACMohan is offline   Reply With Quote
Old 28th June 2013, 20:17   #116
theMAG's Avatar
Thanked: 1,574 Times
BTW_ what gearbox are you running? The stock gearbox would have disintegrated beyond 2nd gear!
Old 28th June 2013, 20:27   #117
binz's Avatar
Thanked: 412 Times
Bone stock gearbox! The build should really put and end to a lot of myths such as these ..!
Old 28th June 2013, 23:55   #118
Thanked: 7 Times
Absolutely loving your car and journey.
I think I'm going to have to make a trip to B'lore and ask for a ride (please!), shotgun, just to experience what this would actually feel like in the flesh.. (or metal, if you will.)
Good job!
Bingeljell is offline   Reply With Quote
Old 1st July 2013, 13:21   #119
swiftboost's Avatar
Thanked: 43 Times
Fantastic job guys. Congrats to you, Sanjay and RD team.
swiftboost is offline   (1) Thanks Reply With Quote
Old 4th July 2013, 16:06   #120
binz's Avatar
Thanked: 412 Times
It's been a couple of days since a newer firmware was updated on the RD 0901 ECU and the difference is huge. The car feels just like stock to drive and is just so responsive! Even with the low vaccuum readings, and minute difference in TPS signals mainly at part throttle, the ecu compensates to ensure I can potter around town without burning much gas while perfectly transitioning into a monster when it floor it. Completely blown away by the low speed driveability now. It been an extremely long journey getting here - there were times when I wanted to ditch the ITB setup completely; but karthik was dedicated to making it work right and he's pulled it off.
The next set of upgrades are already here; we're pushing up the power by another 50-75hp and refining the setup in the process.
The entire charge piping will which is currently stainless steel is going to be swapped with Aluminium. Looking to cut down front end weight by atleast 3kgs.
2.5" Lightweight Aluminium plumbing
No cutting/welding required, pre-bent pipes replace existing stainless-steel ones.
Next the TD05 - 16g turbo is to be swapped with a much larger T04e turbine which should see us hold power right till about 8000rpm.
The cam and valvetrain will be upgraded to meet our goals while still maintaining great streetability.
Gearbox and suspension upgrades are also on the cards and will take place in due time.
Thanks Joe
Good job!
Definitely!
Turbocharged Honda City VTEC story – A Race Concepts build! speedfreak Modifications & Accessories 8 12th December 2014 03:01
AutoTram Extra Grand : World’s Largest Bus @ 256 Passengers PetrolRider Commercial Vehicles 7 28th April 2013 11:29
My Turbo charged Baleno - now 116 whp @ 6psi Edit:145whp at 11 psi! binz Modifications & Accessories 128 13th February 2012 10:18
1st ever Dyno Graph of my Turbocharged Hybrid OHC (320+ WHP!) Ford Rocam Modifications & Accessories 316 15th November 2010 19:44
For Sale Nvidia 6600 Video Card with 256 MB DDR 2 RAM (Turbocache) killjoy Shifting gears 1 19th July 2006 21:02
