Old 4th July 2013, 22:12   #121
Nikhilb2008's Avatar
Thanked: 6,656 Times
Default re: Race Dynamics' Baleno Build-up: ITBs/Turbocharged - Re-dynoed @ 256 WHP!
You deserve kudos for your patience and your persistence in getting all this set up.
However, dont you think it's time to enjoy the 244 WHP and just DRIVE?
Enough modding. Now use the bloody power man! Or if you think you drive too much for a living, just give me your car. I'll keep it warmed up!
Nikhilb2008 is offline   (4) Thanks Reply With Quote
Old 4th July 2013, 23:07   #122
binz's Avatar
Thanked: 412 Times
Car is very much on the road and being 'driven' .. Hard! Once the LSD is in then the fun will really start .. For now it's just acceleration runs nothing more.
It's never enough! Everything was sorted till I was given a t04e and an aluminium plumbing kit .. Might as well use it
Ill give you the car when you give me the civic -
On track !
Old 5th July 2013, 08:11   #123
kutlee's Avatar
Thanked: 202 Times
are you wrapping aluminum too? prevent heat soak.
kutlee is offline   Reply With Quote
Old 5th July 2013, 08:22   #124
headers's Avatar
Thanked: 464 Times
+1,
I can keep it on the boil too.
IS there a dyno report or data to see how the torque and power curves are and we could learn from?
Also, putting in a larger TC might make it loose linear power delivery. Nevertheless, a good attempt in the making
Old 5th July 2013, 12:44   #125
binz's Avatar
Thanked: 412 Times
No Mahesh, not with heat wrap atleast - we may use heat reflective tape.
Heat soak isn't a big issue here - IATs are low. Post the intercooler the plumbing becomes ice cold while driving.
Originally Posted by headers View Post
+1,
I wouldn't put up a figure without backing it up - dyno chart is on the previous page.
I don't understand the second part, are you asking me or telling me? We lost linear power delivery a long time back!
Thanks!
binz is offline   (1) Thanks Reply With Quote
Old 17th July 2013, 18:41   #126
binz's Avatar
Thanked: 412 Times
The car is back at Race Dynamics for the next set of upgrades. Having reached the limits of the TD05, the turbo is being upgraded to a T04e. An upgraded cam is also on the way along with a limited slip diff. Looking to take up horsepower further using lower boost while making power all the way to 8000rpm!
Flanges fabricated and turbo tack welded into position
Down pipe being fabricated
binz is offline   (5) Thanks Reply With Quote
Old 17th July 2013, 18:45   #127
nipcarlover's Avatar
Thanked: 307 Times
Awesome!
What are the power/torque gains you are expecting to make?
nipcarlover is offline   Reply With Quote
Old 17th July 2013, 18:55   #128
theMAG's Avatar
Thanked: 1,574 Times
Whats the final targetted output of the build eventually? Or is this going to be a technology-demonstrator build with frequently changing specifications ?
Old 17th July 2013, 19:04   #129
binz's Avatar
Thanked: 412 Times
Originally Posted by nipcarlover View Post
Awesome!
There is no final targetted output, will keep pushing it till something breaks, then rebuild it to that point(and maybe shove it into a single seater).
It really is just a fun daily drive
binz is offline   (4) Thanks Reply With Quote
Old 18th July 2013, 15:28   #130
binz's Avatar
Thanked: 412 Times
Replaced the fabricated stainless steel charge pipe with a Mandrel bent aluminium one. Looks much better now!
binz is offline   (6) Thanks Reply With Quote
Old 18th July 2013, 21:05   #131
Thanked: 24 Times
this is really good !!!!. where sis u get the mandrel bending done ? I so want to get mine done too !!!
amarpreet99 is offline   Reply With Quote
Old 29th July 2013, 15:02   #132
sharkashwa's Avatar
Thanked: 23 Times
Hey! Been following this for a while....
Any updates on the LSD and high performance cam install??
sharkashwa is offline   Reply With Quote
Old 30th July 2013, 15:27   #133
binz's Avatar
Thanked: 412 Times
The Cam has come, LSD might take a week or so. Have been out of town so things should fall into place this week.
Stock G16b Cam | Reground Cam
The pipe was part of a piping kit. Didn't get anything bent locally.
binz is offline   (2) Thanks Reply With Quote
Old 30th July 2013, 16:12   #134
black12rr's Avatar
Thanked: 274 Times
Good build , can we have complete pic of the engine bay please .The output of turbo as I see is starting from turbo ,taking a left turn behind the exhaust ,then take a right turn to reach ITBs . Isn't it a looong intake ?
black12rr is offline   Reply With Quote
Old 30th July 2013, 17:03   #135
binz's Avatar
Thanked: 412 Times
Hi, complete engine bay pictures are posted earlier in this thread. Do go back a couple of pages.
All Intercooled turbo setups, especially front mount setups have long charge piping - whether aftermarket or OEM.
binz is offline   (3) Thanks Reply With Quote
Turbocharged Honda City VTEC story – A Race Concepts build! speedfreak Modifications & Accessories 8 12th December 2014 03:01
AutoTram Extra Grand : World’s Largest Bus @ 256 Passengers PetrolRider Commercial Vehicles 7 28th April 2013 11:29
My Turbo charged Baleno - now 116 whp @ 6psi Edit:145whp at 11 psi! binz Modifications & Accessories 128 13th February 2012 10:18
1st ever Dyno Graph of my Turbocharged Hybrid OHC (320+ WHP!) Ford Rocam Modifications & Accessories 316 15th November 2010 19:44
For Sale Nvidia 6600 Video Card with 256 MB DDR 2 RAM (Turbocache) killjoy Shifting gears 1 19th July 2006 21:02
