Old 17th May 2006, 15:55   #16
venkatrx's Avatar
Originally Posted by Boom Shiva
Btw, Xenons are 35watts, which is less than even standard bulbs, so they won't melt your headlamp.
This is good news
btw do you advise if its good idea to go for 'xenon hid conversion kit'? if yes which brand?
venkatrx is offline   Reply With Quote
Old 17th May 2006, 17:15   #17
kb100's Avatar
I am also told that now a days you get a H4 option... one with both LOW & HIGH beams... Anyone seen/heard about this?
kb100 is offline   Reply With Quote
Old 17th May 2006, 21:11   #18
EVO6's Avatar
I am using a P4 HID kit in my car and there are no issues with it..
P4 is the one available from WINTRENDZ...
KB100.. I have seen and driven a car intalled with one.. Its nice.. the phenomenon on which this works is that the Bulb assembly moves forward (Low beam) and backward/upward (High beam) in the Sealed Beam of the car..
Cheersss
EVO6 is offline   Reply With Quote
Old 17th May 2006, 22:27   #19
Thanked: 645 Times
The xenon bulbs burn much cooler than Halogens and the heat generated is much, much less. You don't have to worry about meltdown. Most of the kits that I have seen are single filament lamps.
jyobeb is offline   Reply With Quote
Old 21st May 2006, 12:25   #20
To answer some of the questions in a more educated way;
1). Xenon lamps will not melt the headlight housings as they run much cooler than halogen bi\ulbs.
2). Xenon kits available in the aftermarket are all crap as Xenon headlights are designed to be used with optics such as specifically designed projector lenses which you can see in the BMWs, Audi's, Skoda, etc.
3). Aftermarket xenon kits will just be bright with a lot of light scatter in the beam pattern causing it to be erratic and irritating to oncoming traffic. The end result; not much light on the road for the driver with the xenon kit and antagonizing oncoming heavy vehicles who are gonna swerve towards you :-)
4). For the best possible VFM upgrade if u have a halogen set-up is to get yourself some decent Sylvania SilverStar (the whitest and brightest stock replacement) headlamp bulbs. These are not those heavy blue coated bulbs but are just so mildly coated that they produce a white light and not the bluish white light.
Hope this information helps all.
Best,
Challenger is offline   (2) Thanks Reply With Quote
Old 21st May 2006, 21:57   #21
msprabhakar's Avatar
Thanked: 73 Times
Mine is "p4 HID Xenon" (6000K-cool daylight) fitted by a Thai engineer at the Autocar exhibition at Nehru Centre (Dec 2005) for 14.5K. The lighting is amazing and sharply focused on the road. Probably because of Baleno's clear lens and superior reflector optics, the beam pattern has a sharp cut off resulting in zero glare even if you stand right in front, which never fails to amaze anyone. A couple of appreciative drivers have actually stopped by to compliment the wonderful beam pattern!
The power drain is only 35W and fitting is purely plug-n-play, hence 100% reversible in barely a few minutes.
msprabhakar is offline   (1) Thanks Reply With Quote
Old 21st May 2006, 22:48   #22
nitrous's Avatar
Thanked: 282 Times
Thats a short and sweet product experience.
Thanks,man.
Old 21st May 2006, 23:45   #23
kb100's Avatar
Hey Challenger... I CHALLENGE YA!! ... lol
Where can I lay my hands on a couple of these??...(my Phillips 130/100's S*CK!!) you got any distributor/dealers number you can share?? (PM me if you have them!)
Old 22nd May 2006, 02:02   #24
Thanked: 157 Times
Thanks,man.
Do you have any contact number.. I am very much interested?
Buffetfan is offline   Reply With Quote
Old 8th June 2006, 18:26   #25
Thanked: 294 Times
Mods sorry for the pic size!!!!!!!!!!!!!!!!!!!
Note from moderator:
Do not post such large size pics. Use a service like imageshack for resizing. Post edited
Old 8th June 2006, 21:59   #26
Abix's Avatar
Dude low bass maker the xenons look tight!! question on the swift do u have the hi beam or the low beam?
Abix
Abix is offline   Reply With Quote
Old 9th June 2006, 00:17   #27
khanak's Avatar
Thanked: 128 Times
the corolla doesnt have xenons does it?
the xenons on the swift are more focussed i guess.
a lot of scattering of light from the corolla
khanak is offline   Reply With Quote
Old 9th June 2006, 01:51   #28
Thanked: 294 Times
Both the cars have xenon in the swift there is 6000k and in corolla it is 8000k. For dipper there is a second bulb along with the xenon which helps alot................
Old 9th June 2006, 03:10   #29
autopsyche's Avatar
Skoda Octavia with three Xenon HID Kits.
1 x H4 Hi Beam + Low Beam
1 x H3 Upper Fog Light
1 x H1 Lower Fog Light
PS: Have done other Accords, Corollas and Mercs with three kit setups.
One word... BLINDING!!
Arush
autopsyche is offline   (1) Thanks Reply With Quote
Old 9th June 2006, 10:38   #30
Thanked: 294 Times
good quality but man . need good pics this, try taking pic from the side it will surely make a good pic......anyway what is the K rating and make???????
HID Kit / Projector / Xenon Lamps FAQ Takumi-san Modifications & Accessories 17 12th August 2015 14:34
HID Xenon NOTORIOUS Technical Stuff 196 18th October 2014 21:18
HID Xenon fog / driving lamps for OHC gbpscars Modifications & Accessories 4 17th October 2008 11:14
For Sale: German H7 HID xenon kit gbpscars Shifting gears 2 13th September 2007 16:00
Help me out with XENON / HID lights fb1 Modifications & Accessories 16 19th May 2007 02:55
