Old 21st January 2010, 16:29   #91
yzfrj's Avatar
Thanked: 119 Times
Originally Posted by ph03n!x View Post
That's what I meant, thanks for that
While you are right in what you explained, I have to stand on what I said - a H4 HID without a projector will scatter light because of the reflector (compared to it getting focused by a projector). While on highway drives, I have been blinded several times over by modern cars that have HID without projectors- and that's why I'm against such a setup. Am sure there would be others in the forum who would concur...
Maybe you are right buddy. In some cases.
I've been blinded once by an "E"
The fact we have to note is that lot of blue/white/purple coloured lights that are fitted are not really HID's they are just Halogen's with coloured glass. I see them a lot on 2 wheelers, here in chennai at least.
Even I thought the same before getting these.
In fact me and couple of my buddies found an empty piece of road and tried driving/riding/walking against the HID fitted swift. We were surprised to find it was less blinding than the 130/100 Halogen's.
guys can u suggest the type of hid bulb used in fortuner?? also which brand I should go for?
Dilip, most cars/SUV's have H4 type bulb. I'm pretty sure fortuner has H4's for primary headlamps. So all you need is a "kit" with H4 type HID bulb. Go for any reputed brand with Bill and warranty.
Stay away from chinese stuff as you will be wasting your money.
I've heard of Bosh, Autogauge and lot of so called "reputed" HID's. I'm not sure how "genuine" they all are. Personally I'd go with Philips.
yzfrj is offline   Reply With Quote
Old 21st January 2010, 18:42   #92
ph03n!x's Avatar
Thanked: 120 Times
"Bosch" HID kit that is widely around is not genuine I happened to open and check a "Bosch" kit, and sure enough, it had ballasts that had Chinese markings.
ph03n!x is offline   Reply With Quote
Old 21st January 2010, 19:51   #93
Akshay1234's Avatar
Thanked: 7,208 Times
buddy why not have a look at the fortuners headlamps first before just blindly answering. if you see the headlamps of the fortuner you will see that there is a separate projector for low beam and a reflector for high beam. it is most likely h1 or h7 and it will be written in the owners manual.
Akshay1234 is offline   (1) Thanks Reply With Quote
Old 21st January 2010, 19:56   #94
Roy.S's Avatar
Thanked: 108 Times
Even my Bosch wiper blades were made in china. Perhaps the entire manufacturing base is slowly being shifted to china? Or is the market being flooded with non genuine stuff?
Roy.S is offline   Reply With Quote
Old 22nd January 2010, 02:28   #95
ph03n!x's Avatar
Thanked: 120 Times
Guess I wasn't clear again - the accompanying papers were in Chinese - however something in English caught my attention - made in china using bosch's technology (or something similar - is that a decent way to say i copied?!!)
Old 22nd January 2010, 17:59   #96
yzfrj's Avatar
Thanked: 119 Times
Well in that case, I stand corrected. Thanks.
Not every one owns one and not everyone has the owners manual.
You say most likely H1 or H7, I said H4.
It seem you ain't got the manual too
Old 22nd January 2010, 21:07   #97
Akshay1234's Avatar
thats because h4 is when there is a single beam for high and low beam. when there are separate beams for high and low as in the case of the fortuner the 2 most common types of bulbs are h1 and h7. hope you get what i meant. i should have explained it better.
Akshay1234 is offline   (2) Thanks Reply With Quote
Old 24th January 2010, 14:39   #98
jaguar.runs's Avatar
Thanked: 80 Times
Fellas, I would like to draw your attention to some basics
Projector beam head utilize a lens in front of the lamp to focus the light and the normal reflector headlamps use a mirro behind the lamp to focus the light.
Ref : Headlamp - Wikipedia, the free encyclopedia
HID is OE in lot of cars with reflector type headlamps (For Eg: fully loaded Mitsu Outlander available in Middle East) and I have seen several cars retro fitted with HID in a normal reflector type head lamp which had a normal beam pattern.
Yesterday I had a Swift behind me who was using some cheap HID and it was a pain be in front with his light reflecting from the ORVM.
The key is to use the right quality lamp, in this case a lamp with the right length. if the lamp is too short, the beam will spread and will be a nightmare to the oncoming traffic and the vehicles in front of you.
Surprisingly projector beams are considered to be more disturbing to oncoming traffic than normal reflector type head lamps.
The wikipedia page provides more info.
One more advice is to get your head lamp level adjusted so that when using low beam, the light should not go above the waist line/ORVM of the car in front.
jaguar.runs is offline   Reply With Quote
Old 25th January 2010, 17:24   #99
kingofmyworld's Avatar
Thanked: 248 Times
Saw a video on youtube which is a demonstration of hid under water, He dipped the ballast entire into water and powered it, It was working all fine. But I still am not sure whether its true or not. So my question here is, Are HIDs water proof?
kingofmyworld is offline   Reply With Quote
Old 25th January 2010, 22:41   #100
dilipkumar7278's Avatar
Thanked: 24 Times
Guys
Fortuner has H11 for low beams(projectors) and HB3 for high beams. For fogs HB4 is used..
Dilip
dilipkumar7278 is online now   Reply With Quote
Old 23rd April 2010, 11:26   #101
NKR
NKR's Avatar
Thanked: 23 Times
Default Thanks for the information on basics/further advice requested
I own a Skoda Laura 1.9 Ambiente 2009 model and am based in Kochi. I am planning to fit the Philips 6000k HID. Since the Laura ambiente has different bulbs for the high and low beam,I was told by a auto electrical fitter that i need to fit 2 sets each(total 4 bulbs with ballast etc) of xenon for the high and low separately. On consulting the Skoda service they have advised against the fitting of Xenon. Can you please help me out with these
1. Is it safe to fit Xenon as replacement for halogens
2. Do you require 2 sets of bulbs
3. If xenon is not safe which halogen is the best, I was also recommended the philips H7 is it good
4. Finally does any one know of a reliable fitter in Kochi
Thanks and regards
NKR is offline   Reply With Quote
Old 23rd April 2010, 12:40   #102
naveen.raju's Avatar
Thanked: 3,642 Times
@NKR
Philips will be expensive. If you are willing to spend the cash, it is worth every penny.
1. Xenons are safe. They produce very less heat, long life, bright light when compared to halos.
2. Laura has separate bulbs for high & low. Low has a projector setup while high got a normal clear lens. (correct me if am wrong guys)
3. Number of options for halos - osram, philips, and many more
4. Emperor, overdrive. (Have personal experiences with them. I installed my cars HIDs and exterior mods here)
naveen.raju is offline   (1) Thanks Reply With Quote
Old 23rd April 2010, 18:39   #103
ghpk's Avatar
Thanked: 193 Times
Yes I've also seen many HID video's showing ballast put into tub full of water, but that is for demonstration only, actual intention would be to show that water contact would not damage the Ballast.
However it depends a lot on brand you use.
Old 23rd April 2010, 18:43   #104
akshay4587's Avatar
Thanked: 1,684 Times
I have been using a Chinese HID Kit on My bike Since early 2007,it has seen many heavy rains,Pressure washes,and Rivulet Crossing,flooded roads and what not.
It has held on completely.
the only thing in the entire kit that is not water proof is the Relay
Old 25th April 2010, 20:36   #105
NKR
NKR's Avatar
Thanked: 23 Times
Originally Posted by NKR View Post
Thanks and regards
Thanks a lot. After going through your valuable advice and the site and also speaking to others I have decided to install Xenons for the low beams and change the halogens to better ones made by philips on the high beams. by the way could you please give me some contact number of the installers before i take the final plunge..Thanks and regs
HID Xenon NOTORIOUS Technical Stuff 197 3rd April 2018 20:13
HID Kit / Projector / Xenon Lamps FAQ Takumi-san Modifications & Accessories 17 12th August 2015 14:34
HID Xenon fog / driving lamps for OHC gbpscars Modifications & Accessories 4 17th October 2008 11:14
For Sale: German H7 HID xenon kit gbpscars Shifting gears 2 13th September 2007 16:00
Help me out with XENON / HID lights fb1 Modifications & Accessories 16 19th May 2007 02:55
