Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Closed Thread
Thread Tools
Old 16th May 2006, 20:00   #1 (permalink)
Question 90/100 headlamps without seperate relays/fuses/wiring. (baleno) How safe ?
Hi folks...
been a long time since I logged on in here - been very busy with work and i also got engaged so just haven't had the time to give some love to my computer.
Well anyway...hope yer all doing fine - and a big hi to all the new members who have joined in the past coupla months...
After getting sick of my baleno's stock lights and finding it necessary to use high beam frequently late night to be able to see cyclists and pedestrians , i decided to upgrade to 90/100 Philips BlueVisions....
Now I've read all the threads in here about how important it is to fit in seperate wiring and relays and a fuse to prevent your ECU from blowing up. However the dealer managed to persuade me to just swap the lights and not add any extra wiring etc as according to him, he'd done over a hundred installations of these bulbs without any complaints...
(forgot the name of th edealer - it's a car accessory shop bang opposite BK Tyres in Lajpat Nagar, N.D)
now , after reading T-BHP again, I'm getting a bit worried as to how safe my ECU is...
I was told that the stock relay and fuse will take care and that there should be no problems. Should I continue using these bulbs without going for the changes recommended by our many members or should I rush ASAP to Motorcraft and ask them to put in new relays and fuses - and when I go there (they tried to dissuade me from moving to higher wattage lamps), how do I manage to persuade them to get this done ? And how is the wiring to be done so that it doesn't affect my warranty (year and a half still remaining and I'd like to keep it).
Or can you recommend a good mechanic in Noida/S.Del who'd who this properly ? (if required , of course)
I was also told by another dealer that as the baleno comes with 90/100's abroad , it doesn't need any changes...is that true ?
looking for any and all advice...from people who took the precautions as well as those who didn't....
keeping my fingers crossed that my ecu doesn't blow up...
cheers
zaphod
__________________
Six Hamburgers and Scotch all Night,
A drive in a Mustang just to put me right
zaphod is offline
Old 16th May 2006, 20:56   #2 (permalink)
kb100's Avatar
This has been discussed threadbare... Try running 100/90's on stock wiring/relays at your own peril!!
It costs barely 400 bucks to do it... the alternative looks damn expensive!
__________________
A closed mouth gathers no Feet.
kb100 is offline
Old 16th May 2006, 23:17   #3 (permalink)
autozealot's Avatar
kb100 is correct. Its not recommended to use 100/90 on your stock wiring/ relays.
Buy a new wiring kit which directly connects to your battery, 2 heavy duty bulb holders, 2 head light relays & get them installed by a qualified car electrion.
It should be safe to do that I guess. But please check out with your suzuki dealer reg the warranty on the car.
az
autozealot is offline
Old 16th May 2006, 23:23   #4 (permalink)
....bump....
kb100, what do you recommend - getting a Roots wiring harness as ksethuram (IIRC) did or the changing the wirimg routine ?
I don't want to mess with the original wiring - no splicing or cutting....
what have most of you done - and what's the simplest and easiest way to go about it... ?
I'll be going tomorrow to the Sector-16 car market and getting it done - cana noidaite/delhite recommend me someplace good and reliable ?
zaphod
__________________
zaphod is offline
Old 16th May 2006, 23:26   #5 (permalink)
aZa
aZa's Avatar
Zaphod : First of congrats on ur engagement Secondly try out "CAR RAUNAQ" behind Haveli resturant. Talk to Mahesh or Salim they would help u out. I have Blue headlights too dunno how much wattage though i haven't changed the wiring yet ... In Noida Sector 16 Market these guys are the most reliable
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
aZa is offline
Old 17th May 2006, 00:28   #6 (permalink)
Thanks folks,
aza, i guess i'll have to go back to lajpat Nagar as the pack i got didn't contain the pilot lamps - i'll ask the chap to refund the money or give me a different set ...after that i'll head ove to car raunaq and get the necessary work done...
i guess i really cant take a risk with the electricals of my car.... i do have 90/100 halogens (yellow ones) in my esteem but thats a carbed model so there was no real risk except of blowing a fuse but with the baleno , its a whole different ball game altogether.
cheers
zaphod
__________________
zaphod is offline
Old 17th May 2006, 01:11   #7 (permalink)
drifter's Avatar
And also get ceramic holders for your bulbs. My regular ones were melting very often even with 100/90 bulbs....now im using 130/100 bulbs with the new holders. No probs.
Not to mention the importance of the relay. Get it done ASAP.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline
Old 17th May 2006, 10:09   #8 (permalink)
Rehaan's Avatar
Zaphod,
You really should search before creating threads!
If you do a search for "relay" in technical stuff you will get more than enough information.
Thread closed.
cya
R
Rehaan is offline
Closed Thread
Thread Tools
Where's the spare fuses in a Baleno ? Anyone ? supremeBaleno Technical Stuff 4 17th January 2008 11:35
Better headlamps for Baleno venkatrx Modifications & Accessories 16 11th January 2008 20:13
Amplifiers which don't require seperate power cables akg7091 Product Discussions 16 6th November 2007 23:35
Santro - loose fuses help!! LLL Technical Stuff 3 18th August 2007 18:44
Optra - Safe to use 100/130 watt bulbs? Boom Shiva Modifications & Accessories 10 23rd January 2006 14:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
