Old 14th May 2015, 19:59   #166
DWC
DWC's Avatar
Thanked: 121 Times
Default Re: Plasti Dip in India? A Spray-on Rubberized Coating...
That doesn't look too bad. I was expecting some shiny finish, but looks cool. Cheers, will give it a go when I get the time.
DWC is offline   Reply With Quote
Old 6th June 2015, 11:57   #167
kp1992's Avatar
Thanked: 49 Times
I have decided to change the alloy colour of my igen i20 (sportz) to black (yet to decide between glossy or matte finish). Came across plastic dip and was amazed at seeing the results. On researching further I found that people have achieved it by wrapping the wheels.
Which one should I choose, taking into consideration the longevity and overall finish?
Vinyl wrap wont cost more than Rs 1500 (from ebay) whereas the plasti dip would set me back by Rs 4000 approx (for 4 cans).
Would surely post pics of the DIY mod once its done
kp1992 is offline   Reply With Quote
Old 6th June 2015, 12:22   #168
ajaypjayaraj's Avatar
Thanked: 1,077 Times
Plastidip videos on youtube and results seen there looks great. But don't expect it to be tough against scratches and every day abuse. I have tried plastidip as well as armourall (which costs double that of plastidip) and realised that these are good for car shows and temporary cosmetic customisation. They get scratched easily. That is what I learnt from experience. Hence if you want anything long lasting, go to a good paint shop. Wraps are also better when it comes to scratch resistance as compared to any of those dip paint spray products.
ajaypjayaraj is offline   (4) Thanks Reply With Quote
Old 8th June 2015, 13:29   #169
Thanked: 818 Times
I don't think you would need more than 2 cans to do 4 rims of an i20.
Fullrevs is offline   (1) Thanks Reply With Quote
Old 9th June 2015, 13:43   #170
kp1992's Avatar
Thanked: 49 Times
Thanks for the heads-up! I do need something that doesn't get scratched easily as the roads in Bangalore are pathetic to drive on with mammoth like potholes.
True, I too was wondering that 4 cans are more what is required. I recollect reading somewhere that a perfect finish would need 4-5 coats which made me decide on the numbers. Nonetheless, have decided to do a wrap job!
Old 10th June 2015, 02:39   #171
revtech's Avatar
Thanked: 35 Times
You'll need 3 cans for 4-5 coats on 4 rims to get a good coverage over them. you could possibly finish it in 2 but incase you run into some trouble and need to re-do you ll need 3. it would also come in use for a touch up which in all probability you will require.
you can get the original matte black dip. see how it looks and if you want it glossy either get the glossifier or metalizer if you like that look and add it over the already dipped rims. one can is enough for that.
once dipped however they are a task to clean. Brake dust, dirt, mud etc stick to it like crazy and its difficult to wash off since you cant scrub them. youll need a pressure washer.
good luck
rev
revtech is offline   (2) Thanks Reply With Quote
Old 10th June 2015, 13:04   #172
Thanked: 818 Times
Do let me know where you are getting them done. Also please post pictures once completed. Would like to see how well it turns out.
Fullrevs is offline   Reply With Quote
Old 10th June 2015, 15:42   #173
IronH4WK's Avatar
Thanked: 3,632 Times
yeah, me too. thinking of painting my spare wheel with matter black. would be nice to see demo before trying also, i just got about 3/4th of a can left; so want to see some results before ordering new cans
IronH4WK is offline   Reply With Quote
Old 11th June 2015, 00:07   #174
Thanked: 42 Times
Does anyone know where I can get my alloys sprayed in plastidip or equivalent. I know the cans are available, but I want a professional to do it for me.
raycers_honda is offline   Reply With Quote
Old 11th June 2015, 13:23   #175
i tried my level best but couldn't find it in delhi ! getting it online from US costs a bomb ! 12$ for a can !
khushpreet.97 is offline   Reply With Quote
Old 11th June 2015, 18:43   #176
kp1992's Avatar
Thanked: 49 Times
$12 Including shipping?? I called Mr Pankaj who's name was mentioned in earlier posts to get plasti dip cans in India. I was given a quote of Rs 1250 per can (including taxes and shipping).
You must be feeling relieved now
Old 11th June 2015, 19:20   #177
How many cans would you require to paint a Swift? Any idea ?
Moderator's Note: Please do not type using SMS lingo (u, n etc.) while posting on the forums. Please pay attention to punctuation.
Old 18th June 2015, 12:19   #178
Thanked: 818 Times
I would recommend you buy the large paint cans and the paint guns if you wish to do the whole car. The kit is available with Mr. Pankaj (Cosmotech) or he will happily source it for you.
Had done this to my spare wheel a long time ago just to get a feel for what it would look like. I wouldn't recommend Plasti Dip for the rims as it would chip-off quite easily.
Fullrevs is offline   (5) Thanks Reply With Quote
Old 18th June 2015, 14:50   #179
IronH4WK's Avatar
thanks! looks good, but not sure how long it will last. couple of questions for you:
- how many coats did you use? 4-5?
- isn't it better to dip the whole wheel instead of just the front? i know you did it to test, but if one were doing it for real?
- if the bolt holes are dipped, won't they rip off when the bolts are tightened?
- did you use the glossifier? kinda looks shiny.
- how long before the first tear?
Old 18th June 2015, 18:29   #180
Thanked: 818 Times
- That was just one single rough coat done simply for the fun of it
- I would definitely recommend dipping the insides as well and also applying as many layers as you can. The more number of layers applied the better the finish,durability etc. Do mask the tyre when spraying on the rims for safety.
- Would again depend on the number of layers applied. I do not think the dip would peel when the bolts are tightened.
- No glossifier used, just the shine from the tubelight above . I have felt that the glossifier reinforces the plasti dip as well as give it the gloss look.
- Just one rough coat applied and the spare hasnt been used. Those peels are due to me trying to yank that heavy 17"incher from the spare well tub in the boot
I would still strongly recommend going for a paint job for the rims. Some people have told me that brake dust does discolor the matt black dip and it sort of becomes brown later.
Alternatively, you could buy plasti-dip gallon cans with the paint gun, the finishes are a lot better as the cans can spray out uneven quantities.
Vintage car valuations dip - The Economic Times Jai3033 Vintage Cars & Classics in India 22 19th March 2009 12:55
Maruti reports 27% dip in November sales DDGuy The Indian Car Scene 27 3rd December 2008 15:52
SUZUKI DZIRE- Takes a dip in Mangalore nbr Street Experiences 80 17th May 2008 14:35
Spectacular crash:New Dzire goes on test drive, takes a dip in river Shambhavi hskhan The Indian Car Scene 2 13th April 2008 09:12
Car sales dip as customers wait for more launches askicode The Indian Car Scene 5 4th January 2008 11:24
