Old 10th September 2013, 00:55   #61
chevelle's Avatar
Thanked: 503 Times
Default Re: Buying, Owning, Driving and Maintaining a car in North America
Originally Posted by amitoj View Post
Interesting. Can you elaborate a bit more on that? What about overspray on the tires? Does it take care of that too?
Here is what i did.
Took a kitchen bag. Half way through the bag, i cut it 50%. This gave enabled me to wrap the whole disc without any issues. I just covered brakes from front to back and overlapped the cut portion to make sure no paint reaches the brake. Also, keep the bag away from the wheels too so it doesn't touch it when spraying.
When you are done with the spraying. Wait 30-40 mins after last layer so that everything is dried when you remove the kitchen bag from back. Make sure it doesn't touch the plasti-dip while removing. One can pull the bag to one place at the bag and simply take it out. Very easy. Dipyourcar.com has a tutorial on it.
As for overspray on tires, don't worry about it. When doing the lip of the wheel, it is important that you spray in such a way that it goes on tires too. Its a non-issue. After 5 coats and drying time, i just peeled it off. Another way is to use any rough cloth to just get it off the tires. In my case, the spray was all over the side wall. A simple wipe of cloth and peeling in corners fixed it.
Spraying plasti-dip and removing excess from tires was the easy part. 10 mins wait between the sprays was hardest.
chevelle is offline   (4) Thanks Reply With Quote
Old 10th September 2013, 01:36   #62
kraft.wagen's Avatar
Thanked: 254 Times
Originally Posted by ToroRosso View Post
Very Nice! . How many cans did you need for all the 4 wheels? Did you remove all the four wheels and sprayed?
Probably because of the photo angle, i kinda find the chrome look to be a bit more appealing .
I was thinking about doing it for the factory hubs on the car. But then again, that could be a sure shot way of portraying oneself as a douche bag as nobody really plasti dips the hubs.
What color is your 600rr alloy? Maybe you should try it on that.. I have a black powder coating so not messing with it now. But a friend did orange on his white ninja..
kraft.wagen is offline   Reply With Quote
Old 10th September 2013, 01:44   #63
ToroRosso's Avatar
Thanked: 87 Times
KW - Heh, Noways i am touching my baby. Its black btw. I was planning for the truck and car. I wanted to go for alloys for my car but darn expensive, so was thinking about a cheap option to make the factory hub caps a bit more appealing
Howz your ride? Are you able to ride her more often now? Did you manage to hook up with any local motorcycle group?
Edit - Did you do a comparo between your friends' Ninja (650r?) and your baby?
ToroRosso is offline   Reply With Quote
Old 10th September 2013, 02:24   #64
Jomz's Avatar
Thanked: 289 Times
Originally Posted by chevelle View Post
Phew! 2 Hours of hard work and finally managed to Plasti-Dip the Chrome Wheels on Corvette.
Attached are before and after pics of the job done. Not bad for first timer.
Love the new look. Good thing is its easily removable.
Now all is left to determine how to remove plasti-dip from the flag emblem in the middle. Next would be plasti-dip the roof. What does the gang think about that? Should i do it?
Try the brake calipers too, The calipers look kinda left alone.
Jomz is offline   Reply With Quote
Old 10th September 2013, 02:38   #65
chevelle's Avatar
Thanked: 503 Times
Can't do it without messing with the discs. Can probably do after removing wheels but don't have tools to remove it too. May be i can get Caliper covers or paint it. Will try to find a way but its been on my mind the day i got it.
Edit: I don't think i will plasti-dip. Too much risk of calipers getting hot and causing more problems.
chevelle is offline   Reply With Quote
Old 10th September 2013, 13:37   #66
puchoo's Avatar
Thanked: 750 Times
Default Re: Plasti Dip in India? A Spray-on Rubberized Coating...
Cannot believe i am discovering this thread and product today for the first time , so innovative and the possibilities are endless if the full range us available , definitely a worthwhile DIY project which i am going to attempt.
puchoo is offline   Reply With Quote
Old 13th November 2013, 15:37   #67
mumbayite's Avatar
Hey all,
Thinking of 'Plasti Dip'ing the kidney grills and the chrome inserts over the doors. Was earlier going to 3M it. But after checking the results on various - no - numerous youtube videos am feeling rather convinced to do it.
End of the day its removable. So no harm right?
Going to Order a few Black cans from Mr. Gandhi. Don't know if he stocks clear ones. Else order those too.
What do you guys reco? Go for PlastiDip or stick to 3M?
mumbayite is offline   Reply With Quote
Old 14th November 2013, 14:30   #68
Rehaan's Avatar
Thanked: 23,407 Times
Expect your results to be 85% of what it looks like on youtube.
Coming from a guy who sprayed his laptop, this is correct. If you're keen to tinker around and do something yourself, I'd say go for it.
cya
R
Rehaan is offline   (1) Thanks Reply With Quote
Old 15th November 2013, 11:45   #69
Thanked: 27 Times
I finally decided to give it a go and plastidip the windscreen on my bike; the results were very nice so I decided to give it a try on the plastic panels under the seat. I still had some leftover so I plastidipped the exhaust heat shield too(as its prone to scratches).
Pictures(taken with a phone, so pardon the poor quality).
Notice I removed the plasti dip from the side panels, no residue and no marks whatsoever. Just make sure you make the coats thick as I had made them a bit thin which made it hard to peel off; had to use nail polish remover for the overspray/thin coats.
Plasti Dip in India? A Spray-on Rubberized Coating...-img_20131029_155413.jpg
Plasti Dip in India? A Spray-on Rubberized Coating...-img_20131029_182624.jpg
Plasti Dip in India? A Spray-on Rubberized Coating...-img_20131029_182637.jpg
Plasti Dip in India? A Spray-on Rubberized Coating...-img_20131030_081956.jpg
Plasti Dip in India? A Spray-on Rubberized Coating...-img_20131030_082010.jpg
Plasti Dip in India? A Spray-on Rubberized Coating...-img_20131104_131138.jpg
sarsh11 is offline   (6) Thanks Reply With Quote
Old 15th November 2013, 12:04   #70
IronH4WK's Avatar
Thanked: 3,657 Times
thanks for sharing!
how many coats did you spray? also, the coat you put on the heat shield - won't that be affected by the heat from the exhaust?
OT :
Microsoft Sidewinder X6 and Logitech MX518! same pinch
IronH4WK is offline   (1) Thanks Reply With Quote
Old 15th November 2013, 12:16   #71
Thanked: 27 Times
thanks for sharing!
4 coats at least, some parts 5. And plastidip is heat resistant up to 300 degrees and only flammable when its not dry. The outside of the exhaust does not get nearly that hot so I guess its safe.
Can't believe you noticed that heh, a bit overkill for the DoTA/CS I *used* to play; but boys and their toys right?
sarsh11 is offline   (1) Thanks Reply With Quote
Old 15th November 2013, 12:20   #72
greenhorn's Avatar
Thanked: 1,460 Times
Just curious, apart from being peelable, is there any other advantage over regular spray paint?
Regular spray paint costs some 300-400 or so, and I'm planning to spray paint my wheelcaps. They're rather cheap, so not worth spending another 500 to make it removable.
Old 15th November 2013, 13:02   #73
Rehaan's Avatar
I was checking out the Z-2300 too
In addition to being undo-able, the grippyness of the rubberized finish can be an advantage in some cases, especially when its actually "dipped" in a can of the liquid stuff. Eg. making rubber handles for metal tools.
cya
R
Old 15th November 2013, 14:42   #74
mumbayite's Avatar
Update Guys.
Talked with Cosmotech (Mr. Gandhi's Co.).
They are all out of the matt black spray can stock.
Anywhere else I can get it from?
Checked on ebay. There is one guy selling from Bangalore. But its 2k for a can. I think Mr. Gandhi's Co was selling it for 1k a can ( which seems reasonable considering this thing is being sold in US for $10 a can ).
Anyone sourced it at a better rate?
Old 11th December 2013, 23:10   #75
revtech's Avatar
Thanked: 35 Times
Update Guys.
did you manage to source it from somewhere else ? they still dont have stock it seems.
revtech is offline   Reply With Quote
Vintage car valuations dip - The Economic Times Jai3033 Vintage Cars & Classics in India 22 19th March 2009 12:55
Maruti reports 27% dip in November sales DDGuy The Indian Car Scene 27 3rd December 2008 15:52
SUZUKI DZIRE- Takes a dip in Mangalore nbr Street Experiences 80 17th May 2008 14:35
Spectacular crash:New Dzire goes on test drive, takes a dip in river Shambhavi hskhan The Indian Car Scene 2 13th April 2008 09:12
Car sales dip as customers wait for more launches askicode The Indian Car Scene 5 4th January 2008 11:24
