Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 24th May 2006, 10:45   #1 (permalink)
Default Help with Zen
I have been through a lot of threads on modification of Zen but havent been clear on a few things. Can someone please explain the following
1. Difference between standard replacement and conical k&N filter - advantages and disadvantages. at present i am running on stock carb zen engine and do plan to install a header and freeflow in the near future which is the recommended air filter
2. The use of strut brace. How does it work and help in handling.
3. Changing of the cam to the esteem cam - how will that improve th performace of the car. Can the cam be changed without any other changes in the car.
4. Can anyone help me with sourcing of a tacho meter.
Praneet71 is offline   Reply With Quote
Old 24th May 2006, 11:28   #2 (permalink)
diven_b's Avatar
Originally Posted by Praneet71
hey,i dont know much about carb cars.but atleast in mpfi..the standard replacement filter goes in the oe box in place of the original filter.....and the conical filter comes in place of the air box and is exposed.......the advantage of conical is better performance but takes in more dust.i think changing to an esteem cam will improve performance....u can get the tacho from most accessories shops...
diven_b is online now   Reply With Quote
Old 24th May 2006, 11:39   #3 (permalink)
swale84's Avatar
Hey Praneet, It wil probably be easier for you to get the tachometer in Mumbai, from a place like opera house. I couldn't find any when I searched in Pune, even the shops that did have them didn't have too much variety. if you travel to Mumbai or know someone who does frequently, I would suggest you get it from Mumbai. This is information from over a year ago, maybe now you will find something good in Pune. Best of luck with your search.
swale84 is offline   Reply With Quote
Old 24th May 2006, 14:05   #4 (permalink)
Thanks diven b and swale84.
Old 25th May 2006, 05:06   #5 (permalink)
Fuelled's Avatar
First check this out buddy
http://www.team-bhp.com/forum/vbpicg...?do=view&g=191
And now as for ur queries..
1) the conical filter offers more surface area hence the engine breathes better .. gives better performance
For accompanying a free flow a conical is better.
2) Strut brace is placed on the suspension towers on both ends and it helps maintain the suspension geometry during cornering(which changes due to body flex), thus giving better handling
3) Not sure about performance.. and the fit either.. it depends on the size of the new head vs the old head
4) Tacho would be around 5k. But donno where to look for it.
__________________
You're not drunk if you can lie on the floor without hanging on.
Fuelled is offline   Reply With Quote
Old 26th May 2006, 00:31   #6 (permalink)
Kaizer Sozay's Avatar
Hi I too have a zen MPFI , & have done the following changes.
1) Stock K&N, didnt go for the conical coz the guy said that stock is good enough & i am happy. Also got the free flow from automech buit retaining the original muffler didnt want the car to be noisy, but have found a great improvement in power.
2) strut brace costs 1200 at automech, really good on turns at high speed, i felt a difference when i drove to goa.
3) Cam part i dont know havent done it.
4) tachometer .got simple one from Pricol costs just 950 buck and is good, nothing fancy. try any acessory shop they should be able to source one for you.
Happy driving
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 26th May 2006, 15:53   #7 (permalink)
kaiser buddy thanks so much
Thread Tools
Wanted: Maruti Zen vxi or Zen Carbon ollie Shifting gears 0 20th January 2007 10:32
S-Zen?(Swift engine in a Zen) raghuram.cg Modifications & Accessories 4 26th November 2006 17:24
No more ZEN for Zen Lovers abhibh The Indian Car Scene!! 65 8th May 2006 17:17
Used Zen vs new Zen shuvc Hatchbacks 12 18th August 2005 19:16
E-Zen & B-Zen.... MustangMan The Indian Car Scene!! 3 2nd July 2005 21:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
