Old 29th May 2006, 09:55   #1
raghuram.cg's Avatar
Thanked: 20 Times
Default Can the Cup Console in Newer Zens be fitted onto the Old ones
Hello,
Has any one tried fitting the cup console that is available in the new Zen onto the old Zen(Jellybean ones)?
I saw that the screws that hold it together are the same and they are in the same position, but I did not get convincing reply from RNS technicians as to why it wont fit.
Can someone help please.I want to fit it on my 2002 mpfi lxi and 98 vx Zen's.
TIA
Raghu
raghuram.cg is offline   Reply With Quote
Old 29th May 2006, 12:26   #2
swale84's Avatar
Raghuram.
Yes you can do this,
infact ive fitted the console in my old Zen..
THe console costs around 200 rupees...You also need to buy a floor mounting bracket..(around 30 rupees) you'll have to take off the current gear lever plastic surround, remove the floor bracket and replace it with the new wider one......
The problem though is that, the screw holes in your floorboard won't match the holes in the new console, so you will have to drill 2 new holes in the floor or else just one but then the alignment wont be perfect, slightly skewed to one side
Suhail
swale84 is offline   Reply With Quote
Old 29th May 2006, 14:24   #3
Thanked: 20 Times
Thanks Suhail..I will try this out.
Raghu
Old 30th May 2006, 05:27   #4
hellspawn's Avatar
Infractions: 0/1 (10)
yup...can be done have done the same thing...
hellspawn is offline   Reply With Quote
Old 2nd June 2006, 20:55   #5
One more small query. Is it possible to have new look tail light & head lights in Old zen ? New look zen has so good looking tail light,
Can I fix them on old model ?
prakash2757 is offline   Reply With Quote
Old 2nd June 2006, 21:04   #6
swale84's Avatar
since the shape is different, i think you'll also have to change the hatch....... unless someone finds some other jugaad
Old 2nd June 2006, 23:48   #7
Kaizer Sozay's Avatar
yes i have also fitted the cup console in my old zen, but the rubber part of the gear shift remains loose inside as the new zen comes with a rexine cover , you can stick it with stickfast
Kaizer Sozay is offline   Reply With Quote
Old 3rd June 2006, 01:23   #8
swale84's Avatar
Yeah but its covered up with the rexine cover of the new console, so its all good innit?
Old 4th June 2006, 23:15   #9
Thanked: 20 Times
Can someone post some pictures.Suhail said that a bigger bracket is needed.Did all you have to do the same?
I havent had a chance to try this out yet - but will do very soon.
Raghu
Old 5th June 2006, 11:10   #10
subbarao's Avatar
Thanked: 39 Times
Default New console
Hello,
I have fitted the new console boxfor my old ZEN2001 by the RNS, changing the bracket's but i avioded the drilling the new holes, but it will be fitted with 2 screws for existing holes.
subbarao is offline   Reply With Quote
Old 6th June 2006, 15:06   #11
speedsatya's Avatar
Thanked: 712 Times
i too have in my car right from the day the new zen was launched ....one of the holes does not match ...but no problems as such ...and no ..i dont have to use any glue
speedsatya is offline   Reply With Quote
Old 17th June 2006, 16:40   #12
Thanked: 20 Times
Thanks - The problem is none of the dealers are having it.I tried mandovi , bimal and RNS.
They said they will call once it comes - but no phone yet.I think I have to go again and check it out.
Raghu
The Breakfast ride thread ( The ones we attended & the upcoming ones ) harishnayak Superbikes & Imports 6 13th December 2011 11:54
Can the Thar's 4wd be fitted onto the Scorpio 2wd? n.devdath 4x4 Technical 34 21st December 2010 13:45
About e-zens and b-zens... BikerSG Modifications & Accessories 253 6th April 2010 00:23
Newer cars spew more CO2 than old girishbhat The Indian Car Scene 24 3rd June 2008 21:26
Can Indica Xeta foglights be fitted onto an OHC? Dippy Modifications & Accessories 16 8th January 2007 22:03
