Old 4th November 2013, 14:36   #1
raajks's Avatar
Thanked: 117 Times
Default Polo GT TDI: Bilstein B6 or B14 + Eibach springs?
Car: VW Polo GT TDi
I have been debating on which would be the best setup to go for,
My driving ranges on the following road conditions
1) Track days
2) B roads
3) Smooth high ways
4) Gravel / Semi gravel roads
Needless to say, my driving is spirited to say the least.
What I am looking for from the suspension is
1) Make cornering explorations fun
2) Be versatile in varied road conditions
3) Has to be strong to withstand the abuse
Price is not a deciding factor for me but the fun and the driving aspects of the suspension would orient the buying decision!
Seeking the help of the gurus here!
Mods: I looked around for a comparison thread but could you find one. If you do find one that I could have missed, please merge!
raajks is offline   (2) Thanks Reply With Quote
Old 4th November 2013, 16:05   #2
Akshay1234's Avatar
Thanked: 5,945 Times
Default re: Polo GT TDI: Bilstein B6 or B14 + Eibach springs?
Bilstein B14 is a coilover if I'm not mistaken, so it is the B6 you may need springs with. With B6 + Eibach lowering springs you will be making the ride stiffer and the car a bit less practical, but yes the handling and stability will be much better. The B14s being coilovers will be able to keep you ride similar to stock but make the cornering, etc better. And you can adjust the lowering and find a height that you like. But these are more than twice the price of the B6s.
Honestly if you are not looking to lower the car just get B6s with the stock springs. The handling will improve a fair amount and the car will still be practical. Not to mention the remap and brake upgrade you can get along with them in the price of B14s.
Akshay1234 is offline   (5) Thanks Reply With Quote
Old 5th November 2013, 12:39   #3
brraj's Avatar
Thanked: 341 Times
Was enquiring petes bangalore for a demo vehicle to check Bilstein but sadly no test drives like what red rooster does.
brraj is offline   Reply With Quote
Old 6th November 2013, 22:00   #4
raajks's Avatar
Thanked: 117 Times
Default Re: Polo GT TDI: Bilstein B6 or B14 + Eibach springs?
Thanks Akshay, I am orienting towards the B14 as I dont want to lower the car.
While the remapification can be considered checked
The intent is to make the car more stable at high cornering speeds.
GTO's post on Polo R2 with its "All disk brake set-up" has been very encouraging.
raajks is offline   Reply With Quote
Old 6th November 2013, 22:23   #5
Thanked: 251 Times
Just wanted to point out that using the stock springs with B6's will retain the GC and not lower the car, while giving you most of the benefits you desire. I briefly had Eibach springs + Bilstein's in an erstwhile ride (Audi A4) and soon reverted to just the Bilstein's - they did most of the work in eliminating "dive" and "squat" and helped corner like the car was on rails.
I believe Santoshbhat has the B6's with stock springs on his Laura. He has written about them on his thread. Why don't you PM him for some impressions? I understand that the rides are different, but you might still get some useful inputs.
BackInTheFold is offline   Reply With Quote
Old 7th November 2013, 01:52   #6
azeemhafiz's Avatar
Thanked: 295 Times
I am pretty certain you mean B6. B14 comes with springs, are twice as expensive and will require you to lower the car.
azeemhafiz is offline   Reply With Quote
Old 7th November 2013, 02:32   #7
aah78's Avatar
Thanked: 1,469 Times
Arrow Re: Polo GT TDI: Bilstein B6 or B14 + Eibach springs?
If you don't want too much lowering, then the Bilstein B6's should pair well with the Eibach springs.
The B14s being coil-overs will substantially lower the car. This setup will probably be good for track use but coil-overs, generally, are harsh for regular road use even at the softest settings.
See if you like the Eibach Pro-System kit. It includes matched Eibach springs and I think they use Bilstein/Sachs shocks.
They have a Plus kits that also include sway bars but you'll have to check availability for the Polo.
aah78 is offline   Reply With Quote
Old 7th November 2013, 10:33   #8
Akshay1234's Avatar
You mean the B6s right? Get those with stock springs.
With a remap this car will be pretty quick, do make a thread on it.
Old 28th January 2014, 08:45   #9
megazoid's Avatar
Thanked: 116 Times
Car: VW Polo GT TDi
What did you finally decide on? Please update.
megazoid is offline   Reply With Quote
Old 26th February 2014, 01:41   #10
raajks's Avatar
Thanked: 117 Times
I am planning on going for the B16 for the Polo GT TDi
The details are as follows,
Volkswagen Polo (6R) 1.4 B16 PSS9 Coilover
Bilstein number or Part number: 48-168229
Type: Bilstein B16
Reason:
I want something that is more than a B6,
When I sat in the B14's of megazoid's Polo GT TDi, I found the rebound rate to be high on the b-roads.
B16s would offer adjustable rebounds.
Once I get it, I am planning on experimenting with the settings.
Old 17th March 2015, 00:01   #11
Thanked: 151 Times
Type: Bilstein B16
Reason:
Did you have them installed? How's the ride? Would be great if you could share your experience across a variety of driving conditions.
Also, how much did they cost you?
bosporus is offline   Reply With Quote
Old 19th November 2015, 00:50   #12
Prabhu's Avatar
Thanked: 22 Times
Default Bilstein B6 shock absorbers for Vento TDI
Guys,
I'm planning to buy Bilstein B6 shocks for my Vento TDI (1.6L, 2012 manufactured). Since Pete's is the only authorized dealer in India, I have emailed them my requirement. Surprisingly they quoted Rs 1,06,000/- including H&R springs and mentioned that GC would be lowered by 30-35 mm. Since I don't want to buy H&R springs along with B6 shocks, I have asked them to give me the price without them. The customer support representative called me back and told that currently Bilstein does not allow them to sell B6 shocks without H&R springs. I told them clearly that I don't want to lower the GC of my car hence I want to use the stock springs, but they are not ready to sell without H&R springs. I don't know how the B6 sale is tied up with some other brand springs. I don't understand the marketing strategy of Bilstein if this is true.
Hence I have searched online and found out below Bilstein part numbers based on Euro spec Vento TDI - POLO (6R, 6C):
Front: 35-168560, BILSTEIN - B6 SPORT
Rear : 24-067898, BILSTEIN - B6 SPORT
Please let me know whether the above part numbers are correct.
Also I have found a sellers on ebay(UK) who can ship the shocks internationally, please check the below links and let me know if I can go ahead with the purchase and fit these in a local garage:
http://www.ebay.co.uk/itm/Bilstein-B...8AAOSwyQtVgSLt
http://www.ebay.co.uk/itm/Bilstein-B...item4d2e5c5e09
Prabhu is offline   Reply With Quote
Old 19th November 2015, 02:33   #13
devilwearsprada's Avatar
Thanked: 595 Times
Default Re: Bilstein B6 shock absorbers for Vento TDI
Originally Posted by prabhu View Post
Guys,
Well, the policy sounds like a pushover just to sell the springs along but I would recommend you upgrade the springs too.
However, you can contact the nearest Pete's dealer and double enquire or just get KW or Koni Struts. Direct Imports work well too.
You can also check Car Fantasy. A couple of friends have ordered from there.
devilwearsprada is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 12:39   #14
Gannu_1's Avatar
Thanked: 8,709 Times
I wanted to change the shocks on my GT to the B6 as well and found that Peteís is the lone official retailer for Bilstein in the country (listed in Bilstein Germanyís website as well) and the charges were high (almost 2x). And the warranty offered was 2 years instead of the lifetime warranty offered globally by Bilstein. The B4 comes with a 2 year warranty from them. The only gripe being sending the shocks back to them in the event of a replacement claim - rare but canít be ruled out.
Purchasing from those eBay UK links will set you back by 455.9 GBP (46k INR) + PayPal charges. Duties will be levied additionally. Hereís a link from eBay Germany cheaper by 13k INR - 475.4 Euros (33.6k) inclusive of shipping from Germany. Ask the seller to attach the MSDS (material safety data sheet) along with the shipment in a pouch. Hereís the link if he doesnít have it.
As for the lowering springs, buy it only if you need a lowered stance. VW sells the OEM lowering springs from Eibach. Depending on the carís front axle load, you have 3 different sets you can purchase. For the 105 hp TDI, the front axle load is 940 kg.
Polo GT TDI: Bilstein B6 or B14 + Eibach springs?-fa-load.png
(Source: VW)
And the relevant part number is 6R0071677B as per Partsbase (link).
Amazon France has the kit for 245 Euros (17k INR) shipped to India inclusive of customs duties. Sweet deal IMO.
Polo GT TDI: Bilstein B6 or B14 + Eibach springs?-amazon-france.png
Gannu_1 is offline   (11) Thanks Reply With Quote
Old 15th January 2016, 11:51   #15
Prabhu's Avatar
Thanked: 22 Times
Finally my Bilstein B6 suspension arrived from Germany few days back. I have ordered the suspension from ebay Germany - http://www.ebay.de/itm/261827343434
Thanks to Gannu for providing the information. Overall buying experience is good. The product was packaged well and delivered through DHL to india. Up on arrival in India, the package was handed over to Foreign post office, Mumbai. Customs clearance was done in 3 days. Three days later, the package reached delivery office(Local post office) Hyderabad. Total shipping time was approximately 25 days. It costed me 49k including customs duty. Seller attached material safety data sheet to the shipment upon my request.
Cost of the suspension including shipping charges : 35,453/-
Custom duty : 13,608/-
- Prabhu
Polo GT TDI: Bilstein B6 or B14 + Eibach springs?-fullsizerender.jpg
Polo GT TDI: Bilstein B6 or B14 + Eibach springs?-fullsizerender1.jpg
Polo GT TDI: Bilstein B6 or B14 + Eibach springs?-fullsizerender2.jpg
Prabhu is offline   (7) Thanks Reply With Quote
Silver Skoda Laura TSI, 200 BHP & Bilstein Suspension. UPDATE: 70,000 kms up Santoshbhat Long-Term Ownership Reviews 251 29th February 2016 12:12
Difference between Polo R Cup's 1.6 TDI and Vento/Rapid's 1.6 TDI kryptonite Technical Stuff 21 12th February 2015 01:05
My Laura with a Bilstein B14 suspension & many other Mods Pz16 Modifications & Accessories 48 22nd November 2013 08:33
Corolla Mods - Eibach Springs, Xenon HIDs and Angel Eye Projector Headlights novice Modifications & Accessories 14 2nd July 2011 03:46
