| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #16 (permalink) | |
| Senior - BHPian | Quote:
And I am talking about 2.4LTR Mivec Engine.
__________________ -The Boyracer 2000 Suzuki WagonR VX 2003 Mitsubishi Lancer SFXi (soundstream ICE) 2008 Suzuki Access 125 | |
| | #18 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ If I hold a hammer, everything looks like a nail. | |
| | #20 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Minneapolis
| Quote:
1st of all an EVO ECU is for a Turbo charged car, it can never be used with a normally aspirated engine, the entire Compression ratio, AF ratio is different. this is sufficient to rule out any further discussion that you can plonk in an ECU.But even if u still do ...lets assume that even if it fits perfectly What about air intake, camshafts,valve springs,valves,fuel pressure regulator, fuel pump,fuel injection rail,throttle body, plugs, exhaust system etc ? you need to take care of everything else also to get some noticeable difference. Even if you plonk in all the above parts mentioned you will have to tune it extensively with a wideband AFR to make sure your ECU is burning your fuel correctly. also taking care that the uprated components are not damaging your piston,crank etc or you may have to upgrade them too.Plz understand a ECU is not plug and play component across engines....think twice ![]() Why do you think we have tuner companies like Vishnu, AEM,HKS,Greddy, Apexi, JUN,Mines etc etc ...becoz its not that simple to mess around with ECU , electronics of a car and get power.. Last edited by chetanhanda : 24th June 2006 at 08:15. | |
| | #21 (permalink) |
| Senior - BHPian | Chetan, You are right. It takes Lots of expertise in preapring a cedia into an evo and also the money. That's where The millions of dollars are spent by companies. But it's no tough job if done with dedication and right guidance. the cedia in its current form with the right upgrades and an IC turbo should do around 160+ easily. And I am talking basic mods here.
| | #22 (permalink) |
| BANNED | If anyone wants to know more of the 4G63 engine.. here's the link. http://en.wikipedia.org/wiki/Mitsubishi_4G6x_engine Last edited by 2L8uLoose : 24th June 2006 at 11:18. |
| | #23 (permalink) | |
| Quote:
Sure !! agreed .. it will definately require some expertise than just a plug and play and its not a tough job if u have the guys with the tools,experience,cash and time.. and just to reiterate .its definately not plug and play... | |
| | #24 (permalink) |
| Senior - BHPian Join Date: Jul 2004 Location: Mumbai/Tokyo
| The Cedia can be tuned upto 200+ bhp. Its very modifiable and if done it right, can smoke one of the best cars on roads. The engine has enough space for an 4g63 to be fitted. If the Lancer can run on the Evo block, so can this. It just needs a good technician at work to do the job right. Moreover, the 2ltr Mivec can also be pumped into the engine. X
__________________ ------->> X <<------- |
| | #27 (permalink) |
| BHPian | The Cedia engine is 4G94. It doesn't have anything in common with the Evo 8/9, other than probably the cast iron block. Even the bore and stroke and very different. The Cedia does have the same chassis blueprint as the Evo, but there's a lot of extra strut and sway bars on the Evo and the suspension is miles apart. As far as the Cedia's potential goes, its key party piece is the cast iron block, because of which it can be designed to handle "some" boost, unlike stock aluminum blocks. The stock pistons and connecting rods can withstand up to 7 psi of boost, but I know some people who are running 17 psi after upgrading the pistons and the con rods. You'll also need to get the turbo intake manifold if you're bolting a turbo, and the good thing is that the one from the 4G63 (SOHC) block fits. However, keep in mind that the Cedia is SOHC and port injected and a lot of the commonly available Mitsubishi engines are DOHC and direct injected. In the end, I think it's just easier to drop in the 4G64 block (2.4L) onto it, since it almost has the same mounting points and get can 160 bhp in stock form.
__________________ 2008 Subaru Impreza |
| | #28 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| The stock gear box of cedia can handle upto 250 BHPs, [info from one of the TOP teams in INRC] the engine block can handle the power too, the engine comes with so less power is mainly for the "Milage Kya hai market" and the poor fuel quality [read 87 octane] found in most of the places and price factor, that's the reason for the SOHC head. With a good turbo on the cedia engine and a good Standalone, the power will go upto 210 bhp easily. can get more with some other mods.Cedias from team MRF do go upto 200bhps in NA form [All parts are from Rallyart], they have feastas giving out 160-190bhp [parts from cosworth] |
| | #29 (permalink) | |
| BHPian | Quote:
While getting 200+ bhp is possible, reliability will be a big concern, and the engine will probably last only a couple of years if you're lucky. I'd say running a medium sized turbocharger with upgraded engine internals and operating within "safe" limits, you're looking at 180-190 bhp at the most. After that, it's all trial and error. Also, the 7th generation Lancers in North America (Cedia in India) are sold with the SOHC heads (I have the same one), and the DOHC heads are mostly for the MIVEC valvetrains, and hence are limited to JDM or Ralliart versions. They only switched to DOHC heads all over the world for the 8th generation Lancer, and so far its looked quite promising. I'd still say that the cheapest option to get more power would be either a bigger engine or even blueprinting the engine and running low to medium boost.
__________________ 2008 Subaru Impreza Last edited by sujaylahiri : 27th November 2008 at 06:23. | |
| | #30 (permalink) |
| I was talking about the engine choice for the Indian car, It is based on the the fact that mileage plays biggest role in engine [tune] for companies, the prototypes tested by HM for India had around 25 Bhps more than what the production version is tuned for, but fuel efficiency was not that good [according to most of the buying public] that's the reason for such a low power outputs. By the way the cars tuned for MRF are NA and so high compression internals are used to get the power and yet they are quit reliable. And with a turbo build the stock internals will handle around 200 bhp reliably, and it will be cheaper than transplanting an old [used] JDm engine, If the turbochagering is done correctly and sensible outputs are targets than the it can be quit reliable, Upgrade the internal and the engine can be taken to higher state of tune. Defiantly the engine won't last for like 200,000 km with mods, but even the evo engine don't last that long.But the it will be cheaper than 3-4 lac for the [evo- or MIVEC]engine conversion and the rebuilding of the same. |
| Thread Tools | |
Similar Threads | ||||
| Need Help with Importing a Lancer EVO X | abhinav.gupta88 | Luxury, Imports & Niche | 8 | 5th August 2009 23:13 |
| Fastest EVO in the world Mitsubishi Lancer Evo 7 RS | BUSA | The International Automotive Scene | 11 | 5th February 2008 23:07 |
| Seen a lancer EVO VIII | safari_turbo | Super-Cars & Imports in India | 30 | 6th February 2005 09:54 |
| My Lancer EVO VI | Dippy | Shifting gears | 15 | 11th October 2004 17:27 |
| Lancer Evo-X | nikibusa | The International Automotive Scene | 12 | 22nd July 2004 03:11 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
