Old 24th June 2006, 00:55   #16
condor's Avatar
Thanked: 4,907 Times
Originally Posted by sunith
just a question that came up in a discussion.
the tata sierra turbo weighs 1600kg, with a max output of 91bhp = 57bhp/tonne
while the scorpio crde weighs 2500kg(acc to their site), with a max output of 115bhp = 46bhp/tonne.
then what benefits will i get by replacing the sierra turbo engine with that of a scorpio?
The 2500kg you mentioned for the Scorpio is the GVW, not the kerb weight. GVW = full laden to spec'd load level.
if you have the scorpio engine in the sierra, you would have 115/1600kg = 71bhp per tonne. Atleast abt 68-69 bhp/tonne since the vehicle weight will be a little more after the engine transplant.
One point I'd like to make here is, for reasons of simplicity in doing the transplant [lesser modifications, and hence lesser cost & possible complications], you could check out the Tata TCIC engine [the one used in the Victa Turbo / non-Dicor Safari].
I have tried the TCIC and non-Turbo IDI engined vehicles, and find the TCIC to be pretty good.
Old 24th June 2006, 01:11   #17
Thanked: 1,642 Times
Interesting - since you brought up the topic, I did some research because I'd always thought the Scorpio was a sub-2 tonne vehicle. Turns out the Scorpio's GVW is only about 150kg less than my EX 4X4 Dicor. 4X2s should be the same, in that case....
Your sierra will get a boost with the TCIC engine, which is basically your Sierra engine witha turbocharger.
Steeroid is offline   Reply With Quote
Old 24th June 2006, 08:02   #18
condor's Avatar
Steeroid, your were right abt these being sub-2 tonne vehicles. I think there is a general mix-up between kerb weight and GVW [Gross Vehicle Weight]. GVW = kerb weight + max load.
Old 24th June 2006, 08:08   #19
so will it be possible to plonk the safari TCIC engine into the normal sierra engine? i mean will it be possible to transplant a turbo charged engine into a vehicle which is not initially built for that.
sunith is offline   Reply With Quote
Engine Transplant For 1000 axcman Technical Stuff 20 20th August 2011 13:27
performance mods for a lancer... MIVEC engine transplant drunk.monkey Modifications & Accessories 21 17th June 2008 13:28
Engine Transplant in Baleno Lxi 2006 premdiv Technical Stuff 35 21st December 2007 18:12
HELP Transplant Petrol Engine In TATA SIERRA malvechaitanya Modifications & Accessories 3 16th February 2007 22:20
Alto - Engine Transplant!!! urdudesamy Technical Stuff 6 2nd June 2006 23:36
