Old 6th August 2013, 10:35   #376
n.devdath's Avatar
Thanked: 2,150 Times
Default Re: Buying & Using a Pressure Washer
There should be a low pressure option. On my Bosch it is an adjustable wand which opens up to a fan shape, and that is suitable for car wash.
Which model is it? Where did you buy it from? What was the cost?
Old 6th August 2013, 10:52   #377
Parthasarathig's Avatar
Thanked: 494 Times
Bosch aquatak 100 plus model has that. As well as Karcher 3.550 and above.
You can get them both on snapdeal. Bosch for 9899, Karcher for 16149 (advantage of Karcher being able to suck water from bucket) which the bosch is not able to.
Originally Posted by M124 View Post
Guys, anybody having bought a foam lance from U.S.A kindly share the price. PETE'S website has a foam lance from MTM costing 18800rs
Lol the MTM foam lance costs about 119$ on any online website. Petes website also has a pressure sprayer costing 8800rs which ordinarily costs 300 bucks :P
What sort of foam lance are you looking for? You wont get much improvement with foam, unless you have a high powered machine. Not the basic pressure washer models. Im facing the same issue currently. So Id suggest go with the normal foam nozzle of karcher or any other pressure washer machine you have. And use a high foaming shampoo like Megs Hyperwash. That will be enough foam to satisfy most DIY needs.
The foam lances need to be maintained regularly and also a bit unreliable - from my experience of having one. So Id suggest not to take the trouble for that.
Which pressure washer do you have?
Parthasarathig is offline   (2) Thanks Reply With Quote
Old 6th August 2013, 11:19   #378
sagarpadaki's Avatar
Thanked: 1,337 Times
Originally Posted by rbp View Post
All,
What shampoo do you guys use for foam wash?
The one easily available is Megs Hyper wash. Partha here uses it. Maybe he will be able to explain better
sagarpadaki is online now   Reply With Quote
Old 6th August 2013, 12:56   #379
Thanked: 494 Times
All,
Sagar is correct. I use the Hyperwash. Its a versatile shampoo. Not just for foaming, it can also be used for the two bucket method as well which Im frequently putting to use.
Most of my sealants and waxes have stood up to the Hyperwash. Currently thinking of trying out other shampoos as well.
For foam nothing beats hyperwash. Here is a video
Parthasarathig is offline   Reply With Quote
Old 6th August 2013, 15:01   #380
Thad E Ginathom's Avatar
Thanked: 8,377 Times
Originally Posted by Parthasarathig View Post
Bosch aquatak 100 plus model has that....
Spot on. That's what I have. A pressure washer that does not come with this or similar is not really suitable for use on a car.
It's been a few years now, so my answers to the other questions are probably not very useful but:
cost? Far, far more than in Europe.
Warranty? Far, far less than in Europe
Thad E Ginathom is offline   (2) Thanks Reply With Quote
Old 6th August 2013, 15:41   #381
Thanked: 494 Times
ustrati
You are so right about this. It is only after listening to you repetitively that I bought with the vario lance. The dirt blaster aka roto lance, is dangerous. It peeled off my bikes sticker and also left me with a sore finger when I tried to fool around with it.
Vario lance is best for paint and automobiles in general.
Old 6th August 2013, 16:33   #382
Sorry about the repetition! But thanks for making it worthwhile
Even the ordinary jet is too powerful for paintwork. Contact with skin could be really dangerous.
Old 6th August 2013, 17:33   #383
thoma's Avatar
Thanked: 1,112 Times
Default Karcher or Bosch
Yours is an Indian (rather Chinese I guess) make or a European one? No quality issues I assume. How often have you been using it? How satisfactory is the cleaning if it is a month old muck? Will the additional 20bar pressure be useful in such instances if I go for the 120bar? Can the 100+ be used for continuous usage?
I'm really in split mind contemplating between an Aquatak 100 plus / 1200 plus and a Karcher 3.550. I'll have to travel 75kms if anything goes wrong with the Karcher though. But paranoid about Chinese quality. Though double the budget pinches my pocket, I was thinking of using the INR 16k washers (both the 3.550 and the 1200+) for continuous domestic uses like cleaning the veranda and garage floors, as these have an induction motor.
thoma is offline   Reply With Quote
Old 6th August 2013, 17:43   #384
Mine is the Bosch Aquatak Plus, as mentioned by Parthasarathig.
I may not be the best person to ask, as I am extremely lazy about cleaning my car! <Blush> I do not use the washer very regularly.
When I do use it, the pressure is fine. 1/10th would probably do. The wide-fan spray, used at a low angle to the surface, sweeps away loose dust and dirt, and pausing for a short time gets rid of bird droppings, etc. An occasional stain may require a finger-tip rub (keep jet away from flesh!)
It is also quite sufficient for removal of mud deposits under the car, in the wheel arches, etc.
What I don't like about it...
The detergent dispenser is a waste of time. I use a hand-spray bottle with diluted detergent in it.
The trigger jammed after just a few months. I haven't bothered to get it repared: I just use the unit off switch. I learnt the hard way never to let go of the lance with the trigger jammed open! Jammed open is better than jammed shut.
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 6th August 2013, 18:05   #385
GrammarNazi's Avatar
Thanked: 1,670 Times
Why not use a regular 0.25hp water motor? I doubt it'd cost >2k, connect a garden water pipe and a nozzle. Why use these all powerful pressure washers that can damage the paint?
Am I missing something?
GrammarNazi is offline   Reply With Quote
Old 6th August 2013, 21:10   #386
Thanked: 494 Times
The ordinary tap water that you get in your basement is even more powerful than that. Then why buy a pressure washer?
It serves multiple purposes. With one item you can clean car, underbody, patio tiles, terrace and so many other things.
All brands of pressure washers are available in India currently. From Bosch to Karcher, to Kranzle, Nilfisk and other British brands.
Id say go for Karcher. The foam nozzle works well, the vario lance is great and the build quality is solid. The aquatak feels like a puny machine compared to Karcher.
Plus, induction motors last long. You can run them continuously to clean tiles, bathrooms etc like I do. Also, the Karcher models are water cooled motors, so they have a longer life. Plus, the Karcher model sucks water from the bucket. So you can clean any place on earth as long as you have a power source and a bucket of water - no need for even running water. However, it will even suck out water from swimming pools, any water body.
Just get the model with 1 year warranty.
Old 6th August 2013, 21:43   #387
rm_arjuna's Avatar
Thanked: 55 Times
Default Re: Karcher or Bosch
I'm really in split mind contemplating between an Aquatak 100 plus / 1200 plus and a Karcher 3.550. .
K3.550 has induction motor compared to other karcher models & brands which should serve for a longer duration and can be used for extended useage like cleaning 2-3 cars at one go ,also the Pressure is very good compared to other models . trying getting from metro at B'lore should be lil cheaper , i got mine for 12k a year back .
rm_arjuna is offline   (1) Thanks Reply With Quote
Old 6th August 2013, 22:19   #388
I didn't know there were any British manufacturers! Turns out Kranzle is British, the others are German and Danish[?]
And I if I were buying today, I'd probably choose Karcher.
Old 6th August 2013, 22:56   #389
Thanked: 9 Times
Thanx for info about foam lance.
I am planning to get karcher 3.550. Have seen videos of karcher nozzle only spraying out liquid shampoo without any foam so thought of foam lance. which pressure washer do you have and where did you source the hyperwash from?
M124 is offline   Reply With Quote
Old 6th August 2013, 23:03   #390
Shubz's Avatar
Thanked: 989 Times
Is this a good buy?
http://www.ebay.in/itm/Karcher-2-120...ht_2100wt_1156
Been contemplating buying one. I get those deals on ICICI credit card for Bosch Aquatek too.
Help please? (@Partha boy!)
Shubz is offline   Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
