Old 28th September 2013, 22:19   #466
abishek2222's Avatar
Thanked: 161 Times
Originally Posted by shashank.nk View Post
Is the .3 not good at all
It definitely is good enough But for 500 rs more your getting double the quantity to fill soap. and you can control the soap flow rate with the valve on the .6 less wastage. .3 not enough to spray entire car and no valve just plug in and turn on.
Could try asking the eBay seller, think his contact number is listed
abishek2222 is offline   Reply With Quote
Old 28th September 2013, 22:33   #467
shashank.nk's Avatar
Thanked: 734 Times
Yes it can hold more shampoo certainly but the issue is many have complained that the knob hardly does anything to adjust the flow rate.
Will contact that seller and see if he can arrange for a .6L one
shashank.nk is offline   Reply With Quote
Old 28th September 2013, 22:58   #468
thoma's Avatar
Thanked: 1,073 Times
Default Re: Buying & Using a Pressure Washer
Out of the 2 sold in the snapshot of the ebay site last page, one was for me. The 0.6 can hold more shampoo is definitely a plus. You can do one car and a bit more in one shot. Otherwise, there are two adjusting nozzles, one yellow on top for max/min foam and the other at the end of the lance, rotating tip, I guess for adjusting the spread.
Initially, I filled in shampoo + liquid only 1/3rd of the container for a test dose. No foam was coming for a long while, only water from the pump mains. It was then I found out and decided to close the small opening on the other side of the yellow max/min foam adjuster with my thumb. Voila, foam started to pour out in spurts. But by then the liquid was empty and the container crushed inside a bit due to vacuum. Lucky that it was a solid container, it didn't burst. Soon, I filled it more this time and tried. Now, there was no need to close the small opening with the finger. Sad that the foam nozzle comes without any instruction manual.
thoma is offline   (1) Thanks Reply With Quote
Old 2nd October 2013, 01:06   #469
thoma's Avatar
Is this a new series of model that Bosch is selling now?
thoma is offline   Reply With Quote
Old 2nd October 2013, 22:42   #470
jojoinassi's Avatar
Thanked: 95 Times
YES
This is the new Bosch pressure washer.They have discontinued the old ones - they had lots of complaints.But the sales guy was saying that these won't have the induction motors(?)
btw I just got a Black and Decker today.I'll try using it tomorrow
jojoinassi is offline   Reply With Quote
Old 3rd October 2013, 15:56   #471
jojoinassi's Avatar
Thanked: 95 Times
Used the washer to clean the car today morning
The car was not very dirty - could clean it well without the cloth.(the tar stains remained though)
The pluses
1. Very good for the alloys(normally i find it difficult to clean the inner portion) and the wheel arches
2. With the washer,the whole process seems more enjoyable
3. Could clean many difficult to reach places
Disadvantages
1.Took almost the same time
2.Since i was new to this,was finding it difficult to adjust the spray properties
Overall,I'm happy. Lets see how it fares in the long run
Old 10th October 2013, 12:14   #472
kailashnj's Avatar
Thanked: 276 Times
Default Re: Bosch Aquatak 100 Plus
Originally Posted by manim View Post
For a thorough wash after very long drives I do the following:
1) A quick flexi-jet spray to wet the full car and remove large dirt.
2) Spray shampoo using the Detergent-nozzle.
3) Wipe the car with cloth with the shampoo-foam to loosen the fine dirt/stains/oil, etc.
4) Spray again with the flexi-jet.
5) Hand wipe with cloth to dry.
The end result is a sparkling clean car!
I hav the bosch aquatak 100 plus. How do you use the detergent bottle to spray shampoo. Does the detergent spra work like the Foam Lance. If yes, How do you prepare the solution. I had once tried using the detergent bottle to create the foam spray but it did not spray any foam instead it did was spray soap water. kindly help.
kailashnj is offline   Reply With Quote
Old 10th October 2013, 15:46   #473
thoma's Avatar
As per my knowledge from the forum, the Aquatak does not produce a good foam. For a perfect foam, you need to get the foam gun separately. For reference, this is from an Aquatak 150 Pro.
Anyone have laid hands on this?
Old 10th October 2013, 18:05   #474
sagarpadaki's Avatar
Thanked: 1,272 Times
True, Bosch foam gun is a farce. It's the most useless accessory .
There are foam guns specifically designed for Bosch that you have to buy from eBay UK. It costs an insane 130 pounds.
Old 10th October 2013, 19:06   #475
manim's Avatar
Thanked: 380 Times
Post Re: Bosch Aquatak 100 Plus
I mix car-shampoo (some local brand) with water (around 50:50 ratio).
When I spray I do not get perfect foam though.
It is more like soap-water but with a little bit of foam/bubbles.
After this quick-spray I use a wet-cloth to wipe along with this soap-water.
I do a final pure-water spray with the wide-jet to clean the soap-water and get a sparkling result!
manim is offline   Reply With Quote
Old 10th October 2013, 19:12   #476
kailashnj's Avatar
Thanked: 276 Times
While using the detergent bottle of aquatak, do you also keep your water connection to the pump active or do you just use the water also for the spray.
Kindly confirm...
Kailash
Old 14th October 2013, 19:54   #477
Hey guys,
Does anyone have any reviews on the new power washer range from Bosch?
Some details here.
Basically it seems like a decent product with 120 bar pressure. How does this compare to the Karcher K2 series?
rajeshb is offline   Reply With Quote
Old 21st October 2013, 09:41   #478
djoel99's Avatar
Thanked: 17 Times
Just bought SKIL high pressure washer from flipkart for 4500Rs. just prefect for home use. I am quit satisfied with it.
djoel99 is offline   Reply With Quote
Old 29th October 2013, 17:27   #479
drsingh's Avatar
Thanked: 468 Times
A nice deal for those who want a SKIL.http://www.flipkart.com/bosch-skil-h...7-3c66390e8c3b
drsingh is offline   Reply With Quote
Old 30th October 2013, 23:33   #480
Thanked: 151 Times
Originally Posted by bharatbs View Post
Picked up the K 3.550 at Metro Kanakapura after much contemplation, it was price at 12,999 and the K 2.110 was priced at 5,999. There were multiple units available, but I would still advise you to call them before visiting their store.
Did you use the K2 series using bucket water? I have read that it can't suck water from a bucket(only K3 series can do that). Did you take any videos of using bucket water as source or did you have any special attachment to use it this way?
aditya_rao is offline   Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
